Question about Whirlpool Duet GHW9150P Front Load Washer
CONTROL LOCK LIGHT ON. CANN'T USE WASHER.
GHW9150P0 FRONT LOAD WASHER WON'T OPERATE AS CONTROL LOCK LIGHT IS ON. WHAT DO I DO?
  • 44 Answers
Pull plug wait 5 minutes then plug back in go into diagnostics
close door
push control/on
select drain/spin
select no spin by pushing spin speed touch pad
push prewash optionj four timesw within 5 seconds
c:00 will light up
in order to advance to next step
push prewash option 2 times
if it does not enter diagnostics you must replace main control board
Posted on Mar 12, 2009
FRIGIDAIRE FRONT LOAD WASHER WON'T START. DOOR LOCK WILL NOT LOCK. DOOR LOCK LIGHT IS OFF. PULL START HANDLE OUT/ NOTHING. HEAR CLICKING WHEN TURNING SELECTOR SWITCH/BUT WILL NOT LOCK DOOR OR TURN LIGHT ON...
Good Morning REDS, thank you for your inquiry!
I understand that your door indicates it is open and your washer will not operate. Try resetting the unit by either unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and turn on the washer. Select a normal cycle, confirmed the latched is securely latched and verify if the washer will start. If the washer will not operate then it possibly have a faulty door lock assembly or a communication problem with the control board. At this point, it would be advisable to contact an experienced appliance repair tech to assist further.
Sep 11, 2013 | Frigidaire ATF6000ES Front Load Washer
Kenmore front load washer door won't latch lock light on
On some Kenmore front load models, if the black gasket around the door opening is unseated (for example, because you drag some heavy wet laundry over it) the door will not engage the lock and stay closed. This is a feature to prevent the washer from leaking when the gasket is not sealed. To fix it, simply reseat the gasket and the door will close and lock.
Jun 21, 2012 | Kenmore 44102 Front Load Washer
Control lock is on and cann' turn off
Hi
Thanks for using FixYa. To unlock the controls you?ll need to press and hold the END OF CYCLE button for 10-15 seconds. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
'Control Locked' light, can it be reset easily?
Press and HOLD the lock button for 3 seconds,then release it.
Jul 25, 2010 | Kenmore 45996 Front Load Washer
Control lock light is on and dryer wont operate
push and hold lock for 5 secs
if that does not work you may have a contol issue
Oct 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Control locked
Press the control lock button again for how long the machine says.
Jul 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Control locked light on
First remove the plug for 5 minutes and this will reset the system.
Check to see if the light beside the LOCK ICON is lit on the status lights. If it is, then the controls are locked. Press and hold the OPTIONS and SELECT buttons simultaneously until the lock light goes out. This should free up your controls so that the washer will operate normally.If the console will not respond, then you could have a failed control or a stuck button.
Apr 03, 2009 | Whirlpool LHW0050PQ Front Load Washer
Kenmore HE3 front load washer the control lock is on and I don't
Look close at the panel.... it will tell you what button to hold in for 3-5 seconds
Good Luck!
Feb 24, 2009 | Kenmore Elite 45986 Front Load Washer
Whirlpool duet 9400 Washer won't do anything?
Hi.
Please read the Fixya article below explaining how to fix the problems related to control lock on Whirlpool dryers and washers.
The front light lit on my Whirlpool.
Regards.
Dec 27, 2008 | Whirlpool GHW9400 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
96 people viewed this question
Dan Webster
Dan Webster
Sal De
