Question about Maytag MDB9600A Jetclean II Built-in Dishwasher
Water will not drain out of dishwasher
Have an older model Maytag JetClean dishwasher. Was in this house 5 years ago when I moved in. Cannot find where the model # is on it. Was working perfectly fine and then the next load of dishes I washed, the water will not drain out of dishwasher. Have tried several cycles where it is supposed to drain out water, but still is not draining at all.
  • Anonymous May 24, 2009
    water is sitting in the bottom of my dishwasher....maytag jetclean bought in 1992
  • 214 Answers
I would remove the drainhose from sink and try draining in to a pale.if it does not then you will need to remove drain hose and clean out.Also you may need to clean out all screens in pump just remove with torx screwdriver easy when you get into it
Posted on May 07, 2009
My older model Maytag Jetclean doesn't clean.
The white residue may be lime from the water coming into the house (and, obviously the machine). Run some COLD water into a large clear glass pitcher and let it stand overnight. If there is lime it should settle overnight to the bottom of the pitcher. If no residew, get some commercial dishwasher cleaner and run the machine full hot and on all cycles at least 3 times to thoroughly clean it out...Good luck!
Dec 27, 2012 | Dishwashers
Maytag MDB3700AWE bottom wash arm does not move Freely by hand
Yes, the wash arm should spin freely. Recommend that you remove the arms and search for what is stopping it.
In addition to hard water, the ultra-cheap dishwasher powder really does/can leave calcium-like deposits behind. Use brand name powder for 30 days and you will see a difference. Never use gel or tablets in any dishwasher.
Adding a whole-house water softener would eliminate 90 % of your problem. The other 10% will be taken care of by not buying ultra generic powder.
Mar 12, 2009 | Maytag MDB9600A Jetclean II Built-in...
Maytag Jetclean problem
Hi!!! 10 years is alot for a dishwasher..You could have a plugged drain pump.Check your drain pump.All make sure that the water inside your dish water is hot inside it should read over 100 plus..Good luck..
Jan 03, 2009 | Maytag MDB9600A Jetclean II Built-in...
Soap dispenser doesn't open
My recommendation is to switch over to a tablet and merely put the tablet on the floor of the dishwasher bypassing the soap holder all together. It should work just fine that way. good luck.
Dec 29, 2008 | Maytag 24 in. MDB8600AW Jetclean II...
Maytag Dishwasher: MDB/C-2 Suddenly Stopped Worked
I have had this dishwasher since 2003 and haven't had a problem whatsoever. This is one of the best dishwashers I have purchased out of the 4 I have had.
Jul 21, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Knob wont turn - have to turn it manually!!!
Emsie, the model number posted has a electronic control so Im not sure where we are going with this. A couple of things to check. Some models have what they call a foam guard routine. This can cause the machine to stop several times during wash because of oversudsing. (too much soap). You want to make sure the water temp going is is at least 120 to 150 degrees. The heater will only raise the water temp 1 degree every 4 or 5 minutes. This can cause long cycles. You might have a bad timer. If you remove the toe panel there should be a tech sheet attached to it. This will give you good information on your dishwasher back.
Oct 28, 2006 | Maytag MDB9600A Jetclean II Built-in...
Maytag MDB9600A Jetclean II Built-in Dishwasher Logo
228 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
