Question about Kenmore Elite TRIO® 7854 (25 cu ft) Bottom Freezer French Door Refrigerator
What's your problem?water dispensing solwly with new filter
There is water dispensing but slower then original with new filter M# 795.78753.800
Can the water filter housing be the cause of slow water when the filter is in place?
Even a new filter will reduce the flow some what. I think the pressure to the filter is low or restricted . that will cause a reduction in flow, no it should not leak, check on the seal.
May 27, 2015 | Whirlpool Refrigerators
Hello, I have a frigidaire side by side fridge and freezer ( LGUS2642LF2). Water stopped coming out of the dispenser and the ice cubes are coming out but is taking a very long time. I first replaced the...
Good Morning Friend,
I understand that you are having trouble with receiving water out of the dispenser area of your Frigidaire refrigerator, model# LGUS2642LF2.I also see that you have changed the water filter as well as checked and replaced the inlet valve with no positive results, other than it sounds like it wants to dispense water and makes a humming sound. I suggest resetting your refrigerator, by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. Once power has been restored, try getting water out of the dispenser. If you are still having trouble, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine what the cause of your refrigerator not dispensing water. Hope this is helpful.
-Best Regards-
WP
May 17, 2014 | Frigidaire Refrigerators
Frigidaire water dispenser won't work with new filter
The dispenser has a dual water control valves that control ice maker water and dispenser water. To find your parts you will need your refrigerators model number most time found around the fresh food sections door. Below I have a tutorial that may help you determine what may be the problem with dispensing water. Hope this helps, Thanks Sea Breeze
Oct 05, 2012 | Frigidaire Refrigerators
My water dispenser stopped dispensing water, I purchased a new filter (which I'm not sure I was sent the right one, my model no. is not listed as compatable), and it did not fix the water dispenser and...
What brand and model number is it. reply with it and ill give you the right part number for your filter
also give me the number of the replacement filter you have.
Gene
Aug 15, 2011 | Refrigerators
Ice maker not making ice could it be the filter i have not replaced it in a year
yes absolutly could be the filter,a easy to tell if it's the filter is if the in door water dispenser is slower than when new since both icemaker and dispenser would be affected by clogged filter
Gene
Jul 30, 2011 | GALAXY Microsystems 25.4 cu. ft....
I cannot find the Water Dispenser filter. The red light alerting me to change the filter has come on and I am at a total loss. Please help.
inside the fresh food side in the back at the top shelf. filter is round and twist out and new one twist in . easy job to replace / the part # for your model is 12527301 ( orher # is WF401S ) EITHER # IS SAME FILTER .. . THANKS **** HOPE THIS HELPED ..
Jul 22, 2010 | Amana ARS266ZBS Side by Side Refrigerator
Water dispenser problem?
grandfunk, by your post, it sounds like the line is frozen over. You will have to do some tests. First rule out the dispenser itself. While someone is calling for water see if you have 120V to the water valve. If you do, we ruled out the dispenser. Behind the toe panel there should be a water line with a john guest fitting going up the door. Disconnect it there and call for water. Catch it with a cup. If the water is flowing there, you might be frozen up in the door. I have found a couple of these models with that problem. If it's not flowing there, behind the lower drawers in the refrigerator section is the water coil tubing. Take a hair dryer and go over it lightly. It could be frozen over there. Check these things first and post back. Catriver.
Mar 19, 2007 | GE GSH25JFR Side by Side Refrigerator
Kenmore Elite TRIO® 7854 (25 cu ft) Bottom Freezer French Door Refrigerator Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
