Question about Philips 55PW9363 55" Rear Projection HDTV-Ready Television
The color just wont display right. a television guy who I brought the tv from said there is nothing wrong with the tv. the dvd plays fine with the
right color in the other tv but not in the phillips rear. Is there a certain
hookup we need to do as far as a video upconverter as far as the dvd is
concerned.
I assume you purchased the tv in the current condition you are describing. Philips are notorious for having cloudy glyconol coolant. The coolant is situated in a chamber between the light tubes and the lenses and is required in order to keep the tubes running cool or they would otherwise crack from the excessive heat from the light tubes. The coolant normally becomes corrupted in the blue tube first, with the red and green tubes following closely behind it. The Video that is able to project through the cloudy coolant causes a picture that is washed out, fuzzy, and can even cause rainbowy colors depending on how many chambers are cloudy.
If you want further proof that the glyconol is corrupted, you can have someone remove the rear cover and take off the lenses from the light tubes so you can see directly into the coolant chambers to determine which ones are cloudy. Replacing the coolant is an involved process. You should attempt to return the tv to the sales person for a full refund if possible and explain the tv is not okay as he said.
Posted on Apr 28, 2009
Aug 19, 2014 | Vizio E550VA 55 in. LCD TV
Dec 04, 2010 | Mitsubishi WS-55809 55" Rear Projection...
Nov 23, 2008 | Toshiba 55H70 55" Rear Projection...
Nov 09, 2008 | Philips 55PW9363 55" Rear Projection...
Aug 08, 2008 | Samsung HCL5515W 55" Rear Projection...
May 09, 2008 | Mitsubishi WS-55809 55" Rear Projection...
May 05, 2008 | Hitachi 50GX30B 50". Rear Projection...
Nov 25, 2007 | Samsung HCM5525W 55" Rear Projection...
Blue should converge on top of "yellow".Bad connection(s)
on blue convergence IC.Replace both IC's for durable repair.
Check pico fuses.Reset convergence alignment.
Oct 17, 2007 | Samsung HCL552W 55" Rear Projection...
Aug 08, 2007 | Philips 55PP9401 55" Rear Projection...
Nov 17, 2014 | Philips 55PW9363 55" Rear Projection...
Oct 13, 2014 | Philips 55PW9363 55" Rear Projection...
93 people viewed this question
