Question about Frigidaire FRS26H5AS Side by Side Refrigerator
No water getting to ice maker on Frigidaire FRS26ZSH
I had no water at the door dispenser, so I replaced the dual water valve which fixed that.But still no water to the ice maker! The ice maker is brand new and still no water! It is not frozen up the ice maker seems to not call for water. The temp setting is on the coldest setting!Is there any other thing that control this process to look at!
watugot
  • 290 Answers
SOURCE: frigidair frs22zrf side by side w/ front ice and water
From what you are describing, it sounds like you need a valve. Another common thing I run into is the cooling tank inside the fridge freezing. This will usually affect water through the door only. Remove the crispers and you should see a large coil of plastic water line attached to the back wall of fridge. You can check to see if it is frozen by blowing through it from the end of the line you removed from valve. BEWARE, if you blow through it, water will come out dispenser if line is not frozen. Have a towel at front of fridge.
Posted on Oct 03, 2007
Krazytech
  • 725 Answers
SOURCE: Frigidaire plhs267za side/side water dispenser leaks while ice maker cycles
You have a bad diode on the water valve connection frigidaire has a kit for this fix..
5303918287, 5304418384 DIODE KIT frigidaire
Posted on Sep 07, 2008
SOURCE: Ice Maker Slow Making Ice and Water Dispenser No Longer Dispenses
Try replacing the filters, they might be slowing the water flow.
Posted on Sep 20, 2008
My Frigidaire model FRS24ZGE leaks water from the bottom of the freezer door after using the water/ice dispenser. Any ideas on a fix?
Posted on Jul 18, 2009
Krazytech
  • 725 Answers
SOURCE: I have a Frigidaire Model FRS26ZSH need water filter instruction
Filter Status Press and Hold five seconds to reset light. (This light will tell you when to replace the water filter.)
press the button to the right of water filter to release filter...
Posted on Sep 19, 2009
Frigidaire side by side FFHS2322MBKA ice maker stopped working, but still dispenses water
Change the Water Solenoid Valve. This is a dual solenoid valve, one side is for water thru the door ... the other side supplies water to the ice maker and probably is bad. good Luck! Handy Henry
Feb 17, 2017 | Frigidaire Refrigerators
Ice maker in Kitchenaid KSCS25FT does not refill. Makes ice cubes when filled manually. How to fix?
When an ice maker produces ice after filling with tap water and then cycles and does not refill with water that is an indication that the=> 2319734 Dual Water Inlet Valve
is defective. Replacing the water valve should get you back into the ice making business. The 2319734 Dual Water Inlet Valve has two sides. One side is for the dispenser and the other side is for the ice maker. When one side goes bad you end up having to change the complete dual valve set. Here is a link to a Whirlpool Ice Maker Trouble Shooting Manual Here is a link to another source for the 2319734 Water Control ValveI will be here should you have questions please ask, Thanks Sea Breeze
Apr 09, 2013 | Refrigerators
Ice Cube maker in Frigidaire FRS23R4 refrigerator not wotking
The first thing to check is to see if there is any ice in the fill tube, where the water comes in, preventing any more water from coming in. If there is none then the water valve is bad, even though the water in the door works. Its a dual solenoid valve so if one goes bad they both have to be changed
Jun 05, 2012 | Frigidaire Refrigerators
Frigidaire Gallery Professional Series - FRS26ZSH My ice and water maker have stopped working. First the water stopped then about 5 days later the ice maker stopped.
you will need to replace the water inlet valve, this runs your water and ice,, before you replace it take your water line off and hold it in a pot, then have someone turn the water back on , this will let you know for sure you are getting water to the valve,, if no water comes out then you have a water line prob,, have that fixed then hook it back up and turn it on, then you will need to run the water for about 2 -3 minutes to purge the air out of the line,,, if you rplace the valve you will need to purge also
Jan 19, 2011 | Frigidaire FRS3R5EMB Side by Side...
Water dispenser on front of refrigerator door does not dispense water. Ice Cube maker continues to make ice cubes. Defrosting doesn't fix problem.
Water dispensing solenoid is bad. You need to replace the solenoid valve. This typically is independent of the ice maker.
Jun 02, 2009 | Frigidaire FRS26R4A Side by Side...
FRS26ZSH Water Dispensor Not Working
I have a GE 2005 Side by Side Refrigerator. Model GSS25JERF, Serial # FH242429. I get all kinds of Ice but no water. I replaced the water valve (p/n WR57X10050) and the Dispenser Display, 4 button ( p/n WR55x10443) Still no water dispensing from the water valve. What next ?????
Feb 28, 2009 | Frigidaire GLRS264ZA Side by Side...
Ice maker and now water dispenser does not work
Do you get water to the connector at the bottom of the freezer door ? if you do then the water pipe in the door is probably frozen - read new door ! if not then check thw electrical connector at the bottom of the freezer door as they have a habit of corroding.
Feb 22, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Jun 12, 2008 | Frigidaire FRS-26DR7D Side by Side...
Water coming out door and into icemaker
welcometo the world of FRIGIDAIRE!! only company i know using that DIODE within the harness, im unable to lok up the part number for the DIODE kit, there are 2 of them, i would call the manufacture and ask them to supply you with number... just seems a ltiile wierd that ice maker fill troughdoor andyour water fill the ice machine, i see that you tried switching wires and lines still thesame result, please excuse the silly question but did you try to just switch the wires to the dual valve??? not worrying abouth the lines. just askin.
Mar 21, 2008 | Refrigerators
Mar 03, 2008 | Frigidaire PLHS267ZA Side by Side...
Frigidaire FRS26H5AS Side by Side Refrigerator Logo
190 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
