Question about Technics SL-BD22 Turntable
I just changed the drive belt. Immediately following that, the motor is intermittent; it has worked a bit, but also cuts out for no apparent reason. Once it cuts out--happened twice--I cannot get it restarted. It did restart once; I had opened the bottom and fiddled around, but didn't do anything that I was aware of. When the motor is off, the unit is still receiving power; the red strobe light is on. Any ideas?? thx!!
  • victor_udwin Mar 13, 2009
    I solved this myself by pulling the brass capstant drive wheel up and towards the center of the platten. I jused my fingers to do the job.
  • 141 Answers
Motors get burned out spots after many hours of playing eventually in time. it just so happens that when the motor stops, sometimes it stops in that dead spot, or may have more than one deadspot, which will require replacing the motor or better yet replace the whole turntable since everything will be new!
Posted on Jun 05, 2009
1994 Ford camper van intermittantly cuts out for no apparent reason?
why does the post show suzuki and ford in 1 blue box.
im clueless to that, but if a gas motor , the answer is the same ,for all.
: bad motor.?
bad spark, not ever tuned up.
bad fueling
stuck open EGR?
bad electical power to the EFI system, killing spark and injections all at once
it takes tools to find this,
cuts out , means stalls, can you safe the stall with fast right foot.?
do electric devices of any kind on car cut out , as engine stalls.
diagnosis takes hands on, and tools.
Apr 03, 2013 | 1990 Suzuki Swift
Frigidaire front loading washer drainage
Hello - Is the washer draining or not draining? If it is not, this particular issue could be caused by a variety of reason. I would suggest trying the following steps:
1) Verify a circuit breaker isn't tripped
2) Advance the timer control dial slowly 360 degrees-
If the washer starts spinning, then that means the motor and drive belt are fine but that there is something wrong with either the timer control dial or the agitator solenoid. Call in a professional for this.
If the washer doesn't budge, then verify that the drive belt(s) is attached and not broken by removing the back panel. If the belt is broken, replace it. If it is loose, then tighten it by loosening up the bolt holding the motor and moving it on its swingarm (much like a car alternator) until there is a 1/2 to 3/4 inch deflection in the belt.
Some washers use reversing motors. It's possible the motor works on the spin cycle but not on the wash cycle. If so, call a pro.
3) Visually inspect the lid safety switch- Is it loose or cracked? If so, the washer might work intermittently, stopping at different cycles.
4) Check motor and drive belt- Remove the main access panel (usually in the back). Is the motor spinning, but the drive belt isn't? If so, then you have a drive belt problem.
Oct 01, 2012 | Frigidaire Washing Machines
Drum wont turn but the moter does
Hello Deanna - This particular issue could be caused by a variety of reasons. I would suggest trying the following steps:
Sep 30, 2012 | Frigidaire Affinity ATF7000E Front Load...
How many units does the AC belt run , what are the consequences of cutting the AC belt?
depending on the car your serp belt may control all functions from alternator to power steering as well as the a/c make sure it was the a/c compressor that caused this it could have been coolant from the radiator or the high pressure release valve if its running rough it might be an issue with injectors is the check engine lite on. I would recommend a garage or dealer
Jul 07, 2012 | 1994 Buick Roadmaster
Have a Precor M9.1 treadmill which cuts off after about 5 to minutes of use. It can be reset immediately and will run for another 5 to 10 minutes before cutting off again. The belt is well aligned and...
When a running belt has excessive wear, it creates a lot of friction which causes the drive motor to work harder. When the drive motor works harder it will start overheating. If the belt is not lubricated periodically, it will ruin the deck, the drive motor, and cause other electrical problems such as tripping the breaker [after a while, the circuit breaker on the treadmill will need to be replaced.
It is suggested to lubricate the belt every month. At this point, you may need to replace both your deck and your running belt.
With your model and serial number, you can visit our website and view the products we have available for your particular machine.
Precor Repair Parts for 9 1 9 10 Treadmills SPORTSMITH net
Mar 22, 2011 | Precor 9.21 Treadmill
Simpson espirt 650 6.5kg spins wildy, can hear
Hi
Firstly check ..the drive belt will be loose.. You will have to replace it immediately.
Secondly the bearing on the motor drive has got damaged.... change the bearing....
No third reason...
Regards
Berry
Feb 04, 2010 | Washing Machines
MTD 705 drive to mower deck became intermittent then stopped completely. Drive belts perfect and engine running and driving normally. Presumably some form of clutch drive to mower deck is burnt out? Easily...
Yes, unfortunately, it's the clutch mechanism.If the machine has seen hard work for prolonged periods of time, or if it is three years old or over.
Apparently, it's 'normal'.
The most unfortunate thing is though, that they're damned expensive!
(Depending on what country you are in).
Not the best news I know, but that your 'fixya'
Good luck finding a cheap new one.
Jul 11, 2009 | Mtd Garden
What is the secondary air malfunction an a 99 olds cutlass 3.1
there is an electric air pump that pumps air into the engine exhaust manifold(s) under certain conditions such as when engine is 1st started to help clean up the exhaust emissions, the electric motor that drives the pump fails, u will need to replace the secondary air injection pump assembly to correct your problem, see this allot at the shop.
Jun 08, 2009 | 1999 Oldsmobile Cutlass
Intermittent agitation and spin, mostly just hums, burning smell after replacing drive coupling
sound as if the motor or someting else is sticking release the belt on the motor. check belt for damage. check motor by turning it by hand to see if it is free.
May 12, 2009 | Washing Machines
Technics SL-BD22 Turntable Logo
238 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
