Question about Seiko Smart Label Printer 220 Thermal
Windows 7 SLP-220 driver - Seiko Smart Label Printer 220 Thermal
Slp 200 windows 7
Seiko has really downgraded its legacy product support and it has minimized its application and driver software available for download. To find software for your SLP 200 you'll have to good to a third party site like Drivers Guide. The link below is for version 7.0.3
Seiko SLP 420 Free Driver Download
Important tips when finding and downloading application/ driver software from non-OEM sites
1. Never install any application from a non-OEM site that says it will scan your computer to determine what files you need. - search using the manufacturer name, model number, and current operating system on the computer you want to install the device on.
2. Only install the files you found. Never download any software suggested.
3. When installing the downloaded files, always select Custom Installation to make sure you only install the software you need. In this case only the application and driver files, nothing else ( no driver updating, security scanning, toolbar, etc. programs).
In the specific case of the Seiko Smart Label printer make sure your printer is not hooked up until the Seiko software tells you to.
Jun 23, 2014 | Seiko Smart Label 240 Thermal Printer
Need to instal slp 100 application to windows 8
I think you're out of luck. Seiko has really downgraded its legacy product support and it has minimized its application and driver software available for download. You can try using a Windows 7 package. To find software for your SLP 100 you'll have to go to a third party site like Drivers Guide. The link below is for version 7.0.3 while it says its for the SLP 420 it's actually compatible with several models
Dec 17, 2013 | Seiko Smart Label Printer 100 Thermal
WHERE CAN I GET THE DRIVER FOR THE SEIKO 220 SMART PRINTER
The official Seiko site is:
Software Driver Downloads
However, Seiko has deleted its legacy printer support so you will have to find your 220 drivers from a third party site. The 220 is pretty old so you need to use an older driver and it may not support newer operating systems
Seiko SLP 200 USB Driver Free Driver Download
Note: With Seiko Smart Label printers make sure your printer is not connected to your computer until the Seiko software tells you to.
Nov 20, 2013 | Seiko Smart Label Printer 220 Thermal
Smart label 200 windows 7 driver
However, Seiko has deleted its legacy printer support so you will have to find your drivers on a third party site. I've included links to your drivers below:
SIISLP200 Drivers Download for Windows 7 8 XP Vista
Oct 02, 2013 | Seiko Smart Label Printer 220 Thermal
Every time I want to save a label I get "not valid slp label library." I have a Smart Label 200, use SL software version 7.0.0.412, on a Win 7 Home Premier, Dell 8800 SPS machine.
First of all I want to know this problem is occurred first time? If
yes then uninstall the software and restart your machine. Then install
again. Hope so your problem will be solved. Otherwise you should
download Smart Label v7.0.3.418 and try to install the new one.
Thanks.
Aug 21, 2011 | Office Equipment & Supplies
Recommended product key
It is my pleasure to guide you.
After doing some research I found what may be what you need. This comes from http://social.microsoft.com/Forums
QUOTE
Wednesday, October 13, 2010 9:00 PM
Darin Smith MS, Microsoft Contingent Staff, Owner
Computers, which are built by large manufactures that come with Windows Pre-Installed, come with two (2) Product Keys:
A) OEM SLP: This key comes pre-installed in Windows, when it comes from the Factory. This key is geared to work with the OEM Bios Flag found only on that Manufacturer's computer hardware. So when Windows was installed using the OEM SLP key (at the factory) Windows looks at the motherboard and sees the proper OEM Bios Flag (for that Manufacturer and that version of Windows) and Self-Activates. (that's why you did not need to Activate your computer after you brought it home)
B) COA SLP: This is the Product key that you see on the sticker on the side (or bottom) of your computer. It is a valid product key, but should only be used in limited situations (such as if the OEM SLP key stops self-activating for whatever reason). The key must be activated by Phone. (Note: All manufacturers that use the OEM SLP system are required by contract to include a Certificate of Authenticity (COA) sticker, that has a COA SLP key, on the computer)
Your Windows is using an OEM SLP key, but (for whatever reason) cannot see the special instructions in the computer's motherboard and is unable to Self-Activate.
To fix the issue, you will need to change out the OEM SLP key with the COA SLP key. The normal way to do this is to click the 'Start' button, right-click 'Computer', select 'Properties' and then click 'Change Product Key' (located in the lower right-hand side of the window). Enter the COA SLP key and follow the instructions in the Change Product Key Wizard.
Alternate steps to change the product key
1) Click the Start button
2) Type: slui.exe 3 and hit the Enter key
3) Type in the Product key from the sticker on your computer
4) Click the Next button.
5) You will be asked if want to Activate, click ok
It will attempt to Activate by the internet and will return an Invalid Key error (this is ok, continue to step 66)
6) Click the Start button
7) Type: slui.exe 4 and hit the Enter key
8) Select your location in the drop down menu and click the Next button
9) The next screen provides the number to call to Activate by Phone
NOTE: when you call that number, you will first hear an Automated Voice. If the Automated Voice gives you an option to talk to a Live Activation Rep., select that option. If not, do not enter any numbers. This should force the Automated Voice to transfer you to a Live Activation Rep. Trying to Activate thru the Automated Voice will not work, in your case; only thru the Live Activation Rep. will your Activation be successful.
UNQUOTE
I learned something new while doing this research. I like doing new things that is why I do this.
Good luck and please post back that you are successful or that I can be more helpful.
Jun 09, 2011 | Computers & Internet
I dont have the installation disc to install zyxel G-220 v3 wireless USB drive onto my computer, and I can not find it on the zyxel's support and download library. where can I find this software online and...
You can download the software from http://verizon.net/zyxel There are 3 folders, one for Windows XP, one Windows Vista, and one for Windows 7. You can extract the folder you need for the version of Windows you have. Then you can use the Found New Hardware Wizard to install the drivers.
Jan 21, 2011 | Zyxel G-220 802.11g/b Wireless Adapter
Http 400 bad request
download latest expoyer 7 ok and update cam software and windows driver if any
Jan 24, 2008 | Sony SNC-RZ30N Network Camera
Seiko Smart Label Printer 220 Thermal Logo
69 people viewed this question
Top Seiko Office Equipment & Supplies Experts
Oloyede Monsuru
Andrew Taylor
Andrew Taylor
Are you a Seiko Office Equipment and Supply Expert? Answer questions, earn points and help others
