Question about Brother Sewing Machines
Correcting bobbin tension on my brother NX400
Mongo32
  • 111 Answers
SOURCE: seting the bobbin tension on brother xl-5600
loopy underside means upper tension and or threading is wrong
Posted on Jul 08, 2009
bargainbox
  • 1388 Answers
SOURCE: The lower (bobbin) thread on my brand new Brother tangles
Please TRY the solution BEFORE giving your considered rating.
Specific detail on bobbin case adjustment (with picture) near halfway down reply, the remainder will help you achieve a balance of top and bottom tensions.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks
Best Wishes
Martyn
Bargain Box in Australia
Posted on Sep 08, 2009
madelinesalo
  • 59 Answers
SOURCE: BROTHER INOVIS D 1500, CANNOT REGULATE BOBBIN
the problem is your bobbin, a little lossen it so that the thread easy goes up. and adjust your tension.
Posted on Mar 30, 2010
  • 4 Answers
SOURCE: my bobbin thread is not drawing up on my brother
Yes its the tension, however it can be tricky, and you really should have some experience working on the mechines Give us a call we can help you out.
303 770 6321
AAAA TEVA
Posted on Jul 07, 2010
  • 79 Answers
SOURCE: I am using my new
Hi. You "feel" that the machine is threaded correctly? You should probably completely pull the thread out and start over, making certain that it is threaded correctly. Once that is done, double check to make sure the thread is pulled all the way into the tension discs. Make sure also that you have lowered the presser foot. Is the bobbin inserted in it's case correctly? Every aspect is critical to proper function. You may also want to revue your manual.
Posted on Sep 23, 2011
My brother vx-1120 needle wont pick up bobbin thread to make a continuous stitch
Install a brand new needle. Make sure it is installed correctly.
Remove the bobbin/bobbin case from the machine. Check that the bobbin is turning the correct direction and the bobbin tension is threaded correctly. Reinstall the bobbin case and confirm that it is latched into place.
Retest your machine. Slowly turn the handwheel and watch the needle descend and see if it picks up the bobbin thread. If not, then there is probably a sewing machine timing issue. Take it for service.
Nov 01, 2016 | Brother Sewing Machines
Brother LB6800PRW Bobbin Tension?
I suggest having the top tension checked by a sewing machine technican,, and since the bobbin case screw is painted with green ,, I suggest having it checked also to make sure the tension is correct on it. also make sure the bobbin is inserted correctly--counter clock-wise..
Dec 17, 2014 | Brother LB-6800PRW Project Runway Limited...
Tension problem. bottom thread loopy.
Make sure the bobbin is the correct one for the machine first. Try another bobbin on a scrap of material. Bobbin will fit into the bobbin holder going the incorrect way. Make sure the thread is unwinding in the correct direction. mine has a arrow for the correct position. Hope this helps.
Aug 21, 2014 | Brother XL2600I Free Arm Sewing Machine -...
Bobbin tension to loose and flips
Hai, I think you put the big size bobbin. So only jumping the bobbin. Please try to put the correct size bobbin.
Apr 03, 2014 | Brother PE770 Computerized Sewing Machine
How to thread the bobbin on a brother vx-810
The sewing on the bottom is loose because you don't have enough tension on the TOP thread. First, make absolutely sure you are threading the machine correctly. Next, while using 2 different colours of thread, tighten the top tension dial one number at a time and then checking the stitching, continue tightening the top tension until the sewing is even on the top and bottom of your cloth.
Apr 02, 2013 | Brother Sewing Machines
Brother NX400 SEWING MACHINE after changeing thread top and bottom it now makes a nocking noise?
try rethreading the machine again, make sure to use every thread
guide
make sure to not over fill the bobbin
make sure the bobbin is inserted correctly into the bobbin
case, this is very important
make sure the bobbin is turned the correct way in the bobbin case
the machine won't work right if the bobbin is not turned the right
way
clean under the needle plate and in the bobbin area for lint
Nov 02, 2012 | Sewing Machines
I am using my new brother CS-60001 sewing machine for the first time and I can't stop the bobbin thread from tangling. I feel the machine is threaded correctly, the bobbin thread is tightly wound and...
Sep 06, 2011 | Brother CS6000i Computerized Sewing...
I get loops on top and/or bottom of fabric during sewing. I have tried to adjust upper thread tension without any success. On brother website it is said that it might be lower tension or incorrect bobbin...
Top tension back to 4 and leave the bobbin tension as is.
Make sure you have a new needle for the type of fabric being sewn installed with the flat side to the back of the machine. A bent needle can sometimes go unnoticed.
Always thread the machine with the presser foot up and this will give proper tension to the stitch.
Check the manual to be sure you are threading correctly (always with the presser foot up) and that the bobbin thread is feeding in the correct direction from the bobbin spool and through the guides.
Take hold of the thread at the needle as you lower and raise the needle to pull up the bobbin thread. Take both thread ends under the presser foot and to the back of the machine.
Mar 11, 2010 | Brother LS-2125 Mechanical Sewing Machine
Sewing Machines Logo
27 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
