Question about GE 24-Hour Plug-In Big Button Timer 15076
How to set a big button ge timer - GE 24-Hour Plug-In Big Button Timer 15076
GE heavy duty timer model 15117
1) Copy following links to identify timer, and download possible manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#13660
http://waterheatertimer.org/GE-timers-and-manuals.html
2) After programming is complete, press clock button to start timer programs at next set point.
It is not necessary to push Mode button. Some people report that Mode button is problematic with these timers.
3) Add comment and include photo or detailed description of timer for possible identification of timer, and possible manual
Dec 04, 2012 | Hardware & Accessories
Need instructions to program GE emp700ul-pc cat#15147
1) Following links will help identify timer, and download possible manual:
2) Mode button could be a problem: After programming is complete, press clock button to start timer programs at next set point.
3) If timer does not show, then Add comment and include photo or detailed description of timer for possible identification of timer, and possible manual
Dec 04, 2012 | GE Hardware & Accessories
Review ge 15312 settings
Copy following link to identify timer, download manual and link to detailed wiring diagrams.
http://waterheatertimer.org/GE-timers-and-manuals.html#15312
This timer has too many buttons, and programming steps are seriously layered. I think they were trying add programming options, and to avoid confusion found with other brands dawn-dusk timer programming, by adding confusing options and issuing a manual with tiny print.
http://waterheatertimer.org/pdf/GE-15312-sun-smart-Manual.pdf
Look on page 1 of manual on right side, just above 'random security options' heading: Manual says you can use + - buttons to scroll through programs.
OR: Press set-up button twice and P1 ON will display: Display should also display selected setting.
Press set-up again to see P1 OFF, etc
OR: Press set-up twice, and press Enter once.
Press auto button to exit programming, and current time should display.
Nov 13, 2012 | GE Hardware & Accessories
Do I set the GE timer # 15089 to Auto on or Auto off for it to be activated. I had it on Auto on however the light stayed on all the time.
I don't have repair for defective timer.
Open following link to identify timer and download manual:
http://waterheatertimer.org/GE-timers-and-manuals.html#15089
Timer should be set to Auto ON for timer programs to run.
Auto OFF is temporary override, and timer resumes schedule at next set point.
ON is always ON
OFF is always OFF
If timer is not operating as expected:
Test outlet for correct polarity and electrical problems using cheap circuit analyzer from hardware store.
Timer programs can have conflicts. Make schedule before setting timer so there are no overlaps that cause timer not to function as expected.
Current time has not been set. Set current time including current day.
Set button has been accidentally pushed, and a number or CTD appear in display.
Timer needs to be reset to clear conflicting programming or error. Push reset button with paperclip and try programming again.
Timer is not able to handle intended load. All timers work for incandescent bulb. Connect timer to incandescent lamp and see if problem continues.
Timer is defective. Buy another timer from Home Depot and return defect in new package.
Aug 17, 2011 | Jasco Ge 7 Day Digital Timer 1 Outlet...
My ge model 15117 heavy duty timer will not go off in the auto mode. I changed it from auto to off to turn my pump on and then went back to auto and now did not turn off when timer expired
I cannot repair defective timers, and there are complaints about this timer's MODE button.
Most people complain they can't get mode to set.
Avoid the MODE button after programming timer.
Reset the timer by pushing CLOCK PROG MODE buttons. Then re-program the timer per instructions, and then press CLOCK button to exit programming and timer is in Auto mode and ready to work.
No need to press MODE after programming timer.
Typically, this timer has limited 1 year warranty.
http://waterheatertimer.org/pdf/GE-15117-Manual.pdf
http://waterheatertimer.org/GE-timers-and-manuals.html#15117
15117 is not heavy duty timer. Both outlets combined are rated 1000 watts incandescent and 1/4 HP. Check nameplate on your pump for HP rating.
For limited-lifetime-warranty timer, rated 1/3 HP, choose Intermatic HB800RCL 2-outlet timer.
Cost twice as much as GE 15117.
For 1HP outdoor pumps choose Intermatic P1121
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
Aug 08, 2011 | Sport & Outdoor - Others
Have set the timer to come on at the same time every day and off at the same time every day but when I put it Auto mode does not turn on. What step am I missing
You posted under GE dial-type power strip timer.
GE has 2 different models: 57698 & 15090
15090 has instruction manual, and 57698 doesn't.
http://waterheatertimer.org/GE-timers-and-manuals.html#57698
GE also makes 15077 digital power strip timer:
The digital power strip has Auto mode.
1) If programming has overlaps, or if programs are set for conflicting days, then timer will not operate as expected. Review programming steps by pressing PROG button.
2) If current time is not set, then programs will not operate. Press and HOLD clock button while setting current time.
3) I test timers, and sometimes manuals are confusing so I write out the steps to make sure I understand correctly.
4) It is possible that timer is defective.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 30, 2011 | General Electric GE 24-Hour Power Strip...
I just bought a GE 24 hour mechanical time # 15152. How do set it? The dial is very confusing. I understand that I must first pull all the buttons up and push down the ones I need. If I set it to go...
GE 15152
http://waterheatertimer.org/GE-timers-and-manuals.html#15152
Light side of dial is am hours
Dark side is pm hours
Set timer ON from 5pm to 11 pm:
When segments are down, timer is ON.
Lift all segments, except segments between 5 and 11.
Rotate dial until current time lines up with arrowhead located on inner dial.
Move switch to TIMER ON
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Jan 16, 2011 | General Electric GE 24-Hour Timer, 2-Pin...
How to program a digital timer
You posted under a photo that looks like Woods 49063 or GE 28441
Link below shows this particular timer with manuals for each:
http://waterheatertimer.org/Woods-timers-and-manuals.html#Oval
If your timer does not show on link above, add a comment with as much description as you have, with button locations and color and purpose of timer.
To program the GE timer:
1) Set current time
Press and hold Time button: and then push hour and MIN button to set current hour and current minute.
2) To program:
Press and hold PROG button for 1 second
Prog 1 ON will display
This is program1 ON
Press hour button and MIN button to set program1 ON hour and minute
Prog 1 OFF will display
This is program1 OFF
Press hour button and MIN to set program1 OFF hour and minute
Prog 2 ON will display
This is program1 ON
Press hour button and MIN to set program1 ON hour and minute
Repeat steps to program up to 6 different ON-OFF programs
When programming is finished, press TIME button to return to current time.
3) Set MODE
Press mode button once and ON displays, this means light is ON
Press mode button again and OFF displays, this means light is OFF
Press mode button once and nothing displays, this means timer programs will run as you set them
Dec 12, 2010 | Woods Indoor 24 Hour Digital Timer (59203)
Have GE digital timer 15117. Can't figure out how to make the display show AM/PM so I can set it correctly. Clock hour/min just cycles through 12 hours without noting AM or PM setting. Can't program...
GE 15117 manual
You might try a new AA battery.
Some guy wrote in this week and said he bought 6 timers and all the batteries were bad except 1.
Some timers, like Woods TD1300, and others have the 12 hour or 24 hour option.
You press and hold Time button to choose 12 hour or 24 hour
But GE 15117 manual says nothing about this option.
GE 15117 timer is same timer as Woods 59403
Several folks have written in past couple weeks about the Woods 59403 timer skipping over functions.
The best I can guess is your timer is malfunctioning like the other people's timers.
Woods 59403 manual is identical to GE manual, and says nothing about 12 hour 24 hour option either
http://waterheatertimer.org/pdf/Woods-59403.pdf
I test timers for programming and wiring difficulties.
Yesterday 3 timers arrived here, and 1 didn't work.
I took it apart and tested the electronics, and something went bad.
When these timers don't work, you get your money back or throw them away.
Dec 04, 2010 | GE Hardware & Accessories
My 1987 GE Dryer, Model # DDE5300GALWH,will not run all the time.
sounds like you need a new timer you can actually take the timer apart to check for a burnt connection
Jan 07, 2010 | GE Dryers
GE 24-Hour Plug-In Big Button Timer 15076 Logo
885 people viewed this question
Top GE Home Experts
Douglas Dinnebeil
Douglas Dinnebeil
Gene Haynes
Tom Chichester
Are you a GE Home Expert? Answer questions, earn points and help others
