Question about Kenwood DVF-3060
DVD player displays LOADING and would not open to take DVD
When the DVD Player is switched on it displays LOADING and would not open tray to take DVD even if you press the eject button. I have tried to switch it on and off. It first shows HELLO and then LOADING this happens for days on end. My other e-mail address is zakes@myself.com mobile 027 83 290 5522
4 Suggested Answers
SOURCE:
VOTIT
  • 2071 Answers
SOURCE: WILL NOT LOAD DVD OR CD
Manually cleaning the lens
To locate the laser lens, look around the door or drawer of the DVD player and you will see a small circular disc, which is often called the turntable or disc platter. Right off the edge of the platter you should see a small clear lens. There are some manufacturers that have had problems with the lens, depending on the age of the unit. In these problem players, moving the unit to a different location, turning the unit upside down, or sometimes even without moving the unit, the lens can become detached from the laser assembly and floats around inside the unit. You can re-glue it back with a little crazy glue, BUT it must be perfectly centered, and without getting any glue on it. So, if you don’t see the plastic lens, but instead see the laser pick-up assembly, look around for the lens inside the unit and glue it back on.
To clean the lens you must use very little pressure. Take a cotton swab and barely moisten it with plain, non-scented, or oily type alcohol. In a swirling motion, very gently rub the lens until you’ve covered it entirely. Then repeat using the dry end.
If the cleaning didn’t help, don’t despair just yet. You can see if there’s a problem elsewhere in the unit by using a few simple tricks and tips.
First thing you want to see if the unit’s laser is in good working order. This method isn’t foolproof, but most of the time works admirably. When you insert a disc, see if you can look up underneath where the disc sits on the turntable. Observe the laser lens going up and down. If the lens is trying to focus, that’s good! After a few seconds of the lens trying to focus, the platter should start to spin. On almost every CD/DVD unit I've encountered, the unit won't spin unless the laser has properly focused on the surface of the disc. If the unit spins up and and then shuts down, you should check and make sure the laser pick-up assembly slider mechanism is working without any obstructions and that the small chrome rail that it slides on is slightly greased. Don’t go overboard with the grease though, as too much can cause all sorts of problems.
The slider mechanism, depending on the age of the unit and the manufacturer, consists of the small chrome rail, a drive motor, a small gear assembly, and (in some units) a small belt that drives the slider unit via the motor. This small belt causes all sorts of problems. If the belt is broken or slipping, it can cause skipping, dropouts, or simply no start up at all. Also, if the belt breaks in the middle of the disc, the drive mechanism gets hair or dirt wrapped up into the gears, or the pick-up assembly doesn’t return to the start position (called home), the unit will (99% of the time) refuse to release the disc, causing it to become stuck inside the unit. There’s a little micro or leaf type switch located at home position that sometimes gets dirty or breaks and, causing this problem also.
If the disc starts to spin slowly and doesn’t come up to speed, the spindle motor that’s attached to the turntable platter is a common problem. There could also be a problem with the spindle motor driver controller IC or the power supply regulator that supplies voltage to the driver IC. If the disc starts to spin and then spins really fast, or stops and starts to spin backwards, your problem is the laser pick-up assembly or the servo control circuit. If you continue to have problems after cleaning and checking the other things listed above, you may have a problem with the player's alignment. Of course, one of the problems you'll face checking alignments on a DVD/CD player is that you’re going to need to use an oscilloscope on most of them. If you have the proper tools and equipment, the first thing to look at is the RF pattern of the unit while its playing. It should be a sharp and clear pattern. If it's dull and smeared, then the laser could be weak.
Also, in these units are very critical alignments called the focus/tracking gains and offsets. When these alignments are off, it can often cause intermittent troubles. As the unit ages and parts change value, so do these alignments, and will need to be checked. In my time as service technician repairing DVD/CD players, 65% of the laser pick-up assembles I have tested were good and only needed a small adjustment. Today's technology makes it unfeasible for a shop to hook up a DVD/CD player, and even some recorders, to their equipment and make these adjustments because of the cost involved.
Hope this may help;
Regards,
VOTIT
DON'T TO FORGET TO RATE
Posted on Aug 25, 2008
SOURCE: My Memorex DVD Recorder (MVDR 2102) won't open
Power is not turning on
was working until yesterday Jan. 8th 2009
Posted on Jan 10, 2009
  • 4234 Answers
SOURCE: DVD tray makes noise when it rotates
This noise can be casued by two things:
1) The tray is not completely in the loaded position and the "clamper" is rubbing. Replace the loading belt and the loading sequence will complete and the noise should stop.
2) The "CD table" that is part of the spindle motor assembly has slipped a bit. This will make the CD/DVD ride too low and strike the lower tray support. This will require that the table be "re-aligned" to the proper height which may not be possible on your model without special measurement equipment. The height is critical to proper operation of the unit.
Try replacing the load belt first and report your results.
Thanks,
Dan
Posted on May 30, 2009
The tray on DVD won't open when pressing OPEN button DVD/CD is inside
Often the tray is powered by a rubber belt. If the latter breaks or slips the try will not open/close. The motor will work and tell the electronics that all is well because it has done its job but it really hasn't since the tray is inert!
Sep 10, 2017 | RCA DRC247N DVD Player
I have a GPX D200B DVD Player and cant get the Disk Tray to open.
unplugged the dvd player and then re plugged, power on then press the eject button. if still the loading tray won't open, at this time you will need to remove the cover of the player to access the loading tray mechanical assembly. then check for an stuck up or broken rail plastic loading assembly it was installed drive by the loading motor.if ok, check the limit switch might not get contact which the processor not turn on the supply for the motor.
Nov 15, 2012 | Televison & Video
Good morning, I have a sansui DV-X2300 dvd player. The problem is that it auto opens and closes by itself. I mean that when i press the middle button on the player (that close/opens the player, i...
You are having a loading tray sensor problem. It is a small leaf switch on the under side of the loading tray. It must be having a contact problem. How it works is when you close the tray at the end of the tray's travel this switch closes and shorts sending a signal to the microprocessor to shut down the loading motor, same happens when you press eject. Sounds simple but is little difficult to access for a first timer. One you get to it all you need is some switch cleaning spray ( even WD40 will work wonders ).
Take professional help it will just take 10 minutes and will cost you only labor charges. You can mess up the timing if you get it wrong and the loading tray may not work properly.
Jul 03, 2011 | Televison & Video
I nudged the loading tray with my foot when changing a disc. As a result the tray is not opening or closing, presumably because it is no longer aligned properly. Is this likely to be something I might fix...
Mechanical timing and alignment is the problem of your dvd player.
This comes when you accidentally force the disc tray to close.
You need to open the cover of the dvd player..take out the dvd mechanical loading system try to eject it manually by turning the gear with your hand.
Make sure that the cd loader reaches the limit switch before it closes. This will return back the right timing and alignment.
Feb 04, 2011 | Denon DVD-1930CI DVD Player
ACOUSTIC SOLUTIONS DVD PLAYER WON'T EJECT JUST KEEPS DISPLAYING LOADING. THE DVD INSERTED MAY HAVE BEEN A DATA DVD BY MISTAKE
Hi
I made that same mistake. I had to unplug the dvd player, open the dvd door and with a screwdriver turn the wheel under the tray and manually make the tray come out of the door.
Hope it helps
Alison
Feb 21, 2010 | Televison & Video
Dvd tray will not open
If you press the open key and it say open on the display then yu have a cut belt / blowm loading motor or power preoblem insdie the set. If it does not say open/close on the display then you could have a faultt button or processor.
May 12, 2009 | Televison & Video
Sanyo dvw 6000 dvd/vcr player
DVD loading mechanism doesn't load completely that's why opens after attempt of loading.
You need to open top cover of unit and inspect loading belt might be lose, tray timing can be out of phase, some wire got stuck with tray while loading etc.
Oct 02, 2008 | Sanyo DVW-6100 DVD Player/VCR
Heed to unlock an samsung dvd ht-x30
1. Remove Disc from Tray.
2. Switch Off Player
3. Wait 30 Seconds, Then Reconnect Mains.
4. Turn On player with Remote Control. Wait for player to Finish Loading and Display 'No Disc'.
5. Press Enter on Remote Control. (There will be No On-Screen Response.)
6. Press 8, 4, 2, 6, 9 on the remote. (There will be No On-screen Response.)
7. Press Enter on the Remote Control. Player will Automatically Turn Off.
8. Turn Player On.
9. Open Tray
10. Close tray.
11. Turn Player Off then On Again.
12. Player is Now Region Free
May 05, 2008 | Televison & Video
BLOCKED MESSAGE ON YAMAHA DV-S5450 DVD PLAYER
The DV-S5450 may use a belt-loading mechanism. The belt is typically black rubber band with a diameter of approximately 2 cm. It is commonly found in front-loading CDROMs for computers also. Often, as a result of age, usage, humidity, etc the belt snaps, rendering the loading impossible. The loading motor doesn't just pop the tray in or out. It also engages a clutch assembly that raises an inserted disk or lowers a disk to be ejected; this explains why you can't simply force out the tray. Clearly in your case all the electronic signals are there and the loading motor does turn.
Solution: switch off and unplug the unit and then open it up. Do a quick inspection to see if you can locate the broken rubber band. If you can, remove it and take it along with you to the nearest repair shop for exact replacement. If you are finicky around technical work, simply a competent person do it for you. Good luck.
Jan 18, 2008 | Yamaha DV-S5450 DVD Player
Samsung DVD-V5500 DVD tray intermittently wont open
Sometimes the loading belt can cause this problem or else have seen the tray in switch assy cause this as well.
May 23, 2007 | Samsung DVD-V5500 DVD Player/VCR
Kenwood DVF-3060 Logo
70 people viewed this question
Top Kenwood Televison & Video Experts
Jaime Hernandez
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Are you a Kenwood Televison and Video Expert? Answer questions, earn points and help others
