Question about Minolta bizhub 200 Copier
Code sc35-02 on biz hub pro c500 - Minolta bizhub 200 Copier
My Bizhub pro 920 Error Code SC35-02
Posted on Jul 23, 2013
Code sc35-02 on biz hub pro 920
To reset failure codes, perform the following:
1. Enter the 25 mode (turn the machine ON, while pressing the 2 and 5 keys).
2. Select [1. software SW settings].
3. Using the arrows on the left of the touchscreen scroll to DIP SW 3.
4. Using the middle arrows scroll to BIT 1.
5. On the touchscreen select OFF (0).
6. Power the copier OFF/ON.
The machine should go to "Ready to Copy" if the code comes back. Have a technician look at it DO NOT CONTINUE TO RESET the code it is for the Hot Part called the FUSER. It can catch on fire! And that will ruin a perfectly good day!!!!
Mar 07, 2017 | Konica Minolta bizhub Office Equipment &...
What is the utility key when trying to reset a fuser abnormality code on my konica minolta pro c500
Sir,
TO reset that code on C500 is not done with the utility button.
1. First power off the machine.
2. Hold down the 2 and 5 button and power on the machine.
3. Wait for screen then select Soft switch settings.
4. See a new screen, in the first box on your left put a 3
5 in the second box put a 1
6. In the third box you are going to change the 1 to a 0.
Exit. power off the machine. Wait ten seconds power on. If the code comes back have a technician look at the machine do NOT RESET again you are resetting the codes for the Fusing unit the Hot part could CATCH on FIRE!!!!!!!! or do more damage to circuit boards.
Sep 11, 2014 | Konica Minolta bizhub Office Equipment &...
Error code c1144
I have 5 biz hub 654s. There is no "utility" hardware button. Instead, open the front cover (marked "biz hub 654") - switch off the main power - white switch in an orange rectangle. Wait 30 secs. Flip back on- then QUICKLY close the door while holding down the yellow RESET button. "Trouble reset" appears - tap it - OK appears below it. Use main power to power down. Wait 30 seconds. Power back up. Works every time.
Nov 01, 2012 | Konica Minolta Office Equipment & Supplies
Error message sc36-05on my biz hub pro c 500, we cleared a paper jam now this error comes up
Thats a low temp fuser code. You need to reset the code by going into "25 Mode" and reset dip switch 3-1 _ 1 to 0
Oct 11, 2009 | Konica Minolta bizhub C250 All-In-One...
KM Bizhub Pro 920 gets an error: SC21-04.
Wire cleaning problem, there are several motors in the copier that have the job of cleaning Very HighVoltage Drum Charge Wires and Image Transfer and seperation High Voltage wire The wires have a corona (Not beer:)) form on them and need to be cleaned.
Mar 25, 2009 | Konica Minolta Office Equipment & Supplies
To enter service mode on biz hub c 500 what is the key order?
Lost my access to add employee name to scan docs Biz 500/420
Jan 22, 2009 | Konica Minolta bizhub C250 All-In-One...
Fix code 4522 on a Konica Minolta Biz hub pro c6500 (I think this is the color reg. sensor) just need to know where it is to clean it?
This sensor points at the transfer belt. It is located on the left side of the image unit cavity. Kind of hard to reach, and it's under a shutter that can be lifted with your finger. Pull the image assembly out of the machine. the reg sensor, and color sensor are on the left wall of the cavity.
Jan 12, 2009 | Office Equipment & Supplies
Minolta bizhub 200 Copier Logo
121 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
