Question about Whirlpool 24 in. DP840D Free-standing Dishwasher
Dishwasher rack rotting
The rack for the dishwasher is breaking off in little pieces. The pieces appear to be "burnt" chunks/specks in the dishwasher. At first glimpse, the rack appears to not handle the heat well after so many cycles of washing. Please advise why this rack is rotting? Recall issue? Replacement cost, if any?
  • Anonymous Apr 07, 2009
    I have a DU810 model and have the same problem. The dishwasher was installed broadly in our housing division, and our neighbors (whose house was built about 6 months before ours) don't have any problems. I have an email out to Whirlpool. We'll see what their response is.
  • GARY COLLISTER Aug 14, 2012
    Have you heard from them yet? I have the same problem, and I won't buy another plastic interior DW ever again.
  • Whirlpool Master
  • 3,361 Answers
Depends on the age.
Eventually dishwasher racks deteriorate.
It is rusting from the inside out.
Replace the rack.
Posted on Mar 12, 2009
Door on Kenmore Dishwasher dropping out pieces of black insulation on the floor and into the dishwasher basin. What is it? Can the insulation be replaced or is it new dishwasher time?
If it seems noisier, these black pieces are pitch (a hard tar-like substance) that's coated on dishwasher doors to make them quieter. Just to be safe, though, it might be a good idea to show them to somebody in an electrical shop.
Jan 23, 2015 | Kenmore 24 in. Elite Built-In Dishwasher...
Tip
How to Stop the dishwasher from breaking my glasses
This shelving costs $16 plus $20 for powder coating.
Very easy to assemble taking about 2 hours.
It will stabilize your dishwasher trays so glasses wont fall over. Therefore wont break.
Buy 2 large Baking racks with 1 cm holes from Myers for $8 each.
Use your Angle Grinder to cut to size, making sure the cross wires running from left to right are on top of the long runs. This is because your glasses would slip all the way to the front, if you mounted the racks up the wrong way.
Basically I cut off only one side of the rack, using the cutoff piece for the middle hole.
Next flatten those legs that wont let the rack sit flat down, by using your vice and hammer.
See the diagram below how wide the framing supports wires are apart, that is why nothing stands up on them.
You may have to discard other supplied movable racking.
But the inserted racks, with a hole cut in the middle rack to allow a raised support wire some space, are very stable.
Now after cutting hammering and bending the racks loose some coating and will rust with little rust marks appearing on the edges of all your crockery and cups.
Therefore you will need to powder coat them any colour for years of protection.
Just find a powder coater in the yellow pages and give him the cutout racks.
To save money I told him to coat my Black racks to any colour in his machine, which turned out white.
Note the glass which now stands up stable and straight.
on Feb 06, 2015 | Dishwashers
Tip
Clean a Dishwasher
How To Clean A Dishwasher
  1. Using a small brush (old toothbrushes work well) dipped in hot water and white viniger, go around the door of the dishwasher taking care to get into the grooves and crevices of the rubber seal. Most likely, you'll be surprised at the debris that has built up, especially at the bottom of the door and around the hinges on the side.
  2. Pull the bottom rack out and examine the drain area. Wipe around it to be sure there are no hard chunks that can plug the drain, cause damage to the pump or scratch dishes. You'd be surprised at what dishwasher repairmen find - bones, crab shells, chips of glass, and even small pieces of gravel!
  3. Using a clean wet sponge or dishrag, wipe the cleaning solution from the gasket and the door.
  4. Then place a dishwasher-safe cup filled with plain white vinegar on the top rack of the dishwasher. Using the hottest water available, run the dishwasher through a cycle - except for the cup of vinegar, the dishwasher needs to be empty.
  5. The vinegar will help to wash away the loose, greasy grime, sanitizes, and helps remove the musty odor.
  6. Baking soda is also effective at freshening and brightening your dishwasher. Just sprinkle a cupful around the bottom of the tub and run it through a short but complete cycle using the hottest water. Baking soda is also helpful in removing stains.
on Jun 19, 2011 | Dishwashers
My dishwasher leaves black specks all over the glasses inside and out. They are better if left on the bottom rack but this wastes a lot of space. Dishes placed on the top rack will come out fine if the...
After you load up your dishwasher check that the top arm spins freely. Something might be stopping it. eg Big plates like I have. I can only put them on the sides.
As for the white parts , hard to tell without a picture.
Apr 06, 2017 | Dishwashers
Our Bosch dishwasher will not turn on. It appears to have stopped in mid-cycle - there is water below the dish rack. The circuit breaker on the main electric panel was not tripped. Thanks, Paul
check the dishwasher electrical box connection. remove kickplate. box is on r/h side. remove cover. you will probably find the wires and marettes burnt. simply repair the wires. this happens from time to time if the connection is not the best. hope that helped
Aug 18, 2009 | Bosch SHV68 Built-in Dishwasher
Tip
How to Cleana Dishwasher
How to Clean A Dishwasher
on Jun 15, 2011 | Dishwashers
Upper spray arm broke off
I hope it did not break, only came off. I had the same problem. You have to unscrew the round part from the ceiling of the dishwasher, put the three pieces together, easy, and then screw the whole thing back. No tools needed. Top rack can stay on while working. It helps if the dishwasher is empty. If the threading is good, this should solve the problem.
Mar 06, 2009 | Frigidaire Professional Series 24 in....
Dishwasher won't drain
The problem is probably a simple one to fix. Remove the panel on the lower front of the dishwasher and disconnect the drain hose. Check in the hose for debris, like pieces of a broken plate.
Next remove the pump and look inside of it for pieces of debris. I am betting that you will find a chunk of glass or bone in the little pump. REassemble everything and your dishwasher should be fine.
Jan 16, 2009 | Tappan 18 in. MDR251RE Built-in Dishwasher
Black specks
is that a glass? can't tell. is there water curculating to the top rack? if not you probably have a bad chopper
Sep 16, 2008 | Kenmore 15899 Built-in Dishwasher
Does not clean dishes on top rack
DG:
There is a rubber boot connecter in the back of the top rack which slips over a pipe coming up the back of the unit. This is how the water gets to the top rack. That boot is subject to rot and breaking. Check and see. It should be easy to replace, if you can get the part.
May 11, 2008 | Kenmore 24 in. 15689 Built-in Dishwasher
Whirlpool 24 in. DP840D Free-standing Dishwasher Logo
349 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
