Question about Oki Electric Industry C330dn Led Card Printer
Oki c330dn service error 980, how can I reset this?
I HAVE REPLACED THE BLACK CARTRIDGE WITH OK, PER OKI INSTRUCTIONS. STILL THE ERROR, AND IT WILL NOT ALLOW THE PRINTER TO BE USED. HEEELLLLLPPPPP!
4 Suggested Answers
don_farr
  • 1018 Answers
SOURCE: REPLACED OKI C33OO'S CYAN TONER CARTRIDGE AND
Are you using a third party toner cartridge or a refilled cartridge?
If you are, DON'T!
Don
Posted on Jan 29, 2010
canontech
  • 1219 Answers
SOURCE: I have a OKI C6150 got a jam now I have a Fatal #980
Inside fixing unit are also thermoswitch and thermistor wich can burn out, but also the fixing lamp too. You must dissasemble it and by DVM test the circuits, if the circuit is opend on thermistor, that means that he is burnd out.
Posted on Jul 08, 2010
ktsv08242
SOURCE: oki MC361 980:Error
help! plz
Posted on Dec 13, 2012
OKI C330dn Call Service fatal Error:980
That particular error indicates a fuser failure. Try turning off the printer and re-seating the fuser. If this does not clear the message then the fuser needs to be replaced. With such a low number of prints warranty should cover it.
Aug 29, 2014 | Oki Electric Industry C330dn Led Card...
Oki c710 error 980 reset
Per the technical manual - Media wrapped around the fuser error. Turn off the power. Replace the fuser....
It is possible to unravel the paper from the fuser.
Feb 15, 2014 | Oki Electric Industry OKI C710dn - - color...
Error message 381
pulling the paper out can damage the roller feeder. also make the roller out of sync with the other rollers, i think to reset it you will need to activate ink cartridge change this can some times sort out the problem. remove the cartridges and leave out it will reset and say not inc. when it does this put the inc back in and it should reset.
Jun 14, 2017 | Cisco Oki C330Dn Led Printer - Color -...
My Okidata C330dn has a "Service Call 991:Error" code. How do I resolve this without a service call?
probably one of colour cartridges (usually not original from OKI) is updetting the printers logic Swap they around (even if you have to use old cartridges), find offending one and replace.
Simple.
Sep 29, 2013 | OKI C Office Equipment & Supplies
Service Call 069: Error
My printer (Oki C330dn) experienced a hardware issue that placed it in a mode where it displays a 'Service Call 069: Error' on startup after the hardware problem was corrected. I used the following button combination at startup, which corrected my issue. Press and hold the BACK, DOWN ARROW, and OK buttons and power-on the unit. Continue to hold the buttons until you see RAM CHECK and some asterisks then release. This forces the unit to ignore all warnings and errors while placing it in an online mode. My printer came up to a ready state and worked normally. The next time I turned it on, it started up without any errors.
Aug 17, 2012 | Cisco Oki C330Dn Led Printer - Color -...
Oki c 5600 980 fatal error
The error means that the media is wrapped around the heat roller of the fuser. The only way to reset this error is to replace the fuser unit.
Jul 20, 2009 | OKI C5500n Laser Printer
Service call 980:Error
hola
quiem puede ayudarme a desifar el error 980 de ld oki c6100
gracias
Apr 09, 2008 | OKI Office Equipment & Supplies
980: Fatal Error
From the Service Manual:
*Service call
980:Error
*Error by media
clinging to the fuser
*Media has clung to the fuser.
*Power OFF
Replace the fuser unit.
Suggestion -
Before you replace the fuser, take it out and check for a piece of stuck label, paper, etc. You can spin the fuser roller by turning the gear on the side.
Apr 07, 2008 | OKI C5800Ldn Led Printer
Oki Electric Industry C330dn Led Card Printer Logo
283 people viewed this question
Top Oki Electric Industry Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Victorman
Victorman
Tony
Are you an Oki Electric Industry Office Equipment and Supply Expert? Answer questions, earn points and help others
