Question about Air Tools & Compressors
How to turn up the air pressure on a speedaire 3z355
How can I adjust the torque settings?
PDF]SD Compressor Service Guide - Sanden
www.sanden.com/productlibrary/manuals/sd_service_guide_rev_2.pdf
6.6.2 Suction Gas Condition. 6.6.3 Ambient ... Internal compressor pressure can be relieved by removing shipping caps ... Never leave PAG oil exposed to air for a prolonged time. Tightly ..... Place rotor pulley shaft protector (Puller set) over the exposed shaft. 4. ... Replace retaining nut and torque to specification. 1/2-20: 20- ...
Speedaire Air Compressors - About Air Compressors
www.about-air-compressors.com/speedaire.html
when i try to start my gas compressor it backfires why 5.5 speedaire by dayton, serial ... cant find cylinder head torque specs for 35w347 need the torque specs to properly break .... I also need to know how to change the oil on the 1z943b motor ...
[PDF]80 Gallon Industrial Air Compressor - Mi-T-M Corporation
Dec 08, 2015 | Air Tools & Compressors
Regulator Problem. Both Gauges stay at same pressure when trying to adjust the outlet pressure for tool settings
It sounds like a contaminated regulator, possibly due to moisture if you have never drained the tank. If it is a cheap air compressor then the best course of action would be to install another regulator as it is not worth the time to try to rebuild the regulator as most likely it is not a quality part. I would look into Wilkerson or Speedair brand parts to fix your issue.
Nov 14, 2013 | Craftsman 15 gal Air Compressor 3 hp UMC...
I need Pressure Regulator for Speedaire 3Z355H
The pressure regulator does not have to be specific for your compressor. You just need to get the right line size and pressure range you are needing. You might be able to get one from Home Despot or Lowest, but I would look on Amazon. I am sure you can get it from Grainger, but you will pay a premium price. If you are on a budget, check Harbor Freight if you can.
Aug 27, 2012 | Dayton Audio Dayton Speedaire Air...
I have a Speedaire Model 3Z492, 2 stage air compressor. When it runs the safety valve (60psi) vents air. When it stops everything is ok. I replaced the safety valve and the same thing happens. Is the...
no. it's meant to vent air once the compressor reaches a certain pressure. on some compressors it's adjustable. others are not adjustable. it is actually possible to buy a higher pressure check valve if you need the extra pressure as long as the compressors internals can handle it.
Mar 17, 2011 | Air Tools & Compressors
I need i shop manual for a dayton speedaire model 3z244d
The dayton brand is sold by Grainger.
Check for the manual at grainger.com they also have a cust. service number that maybe can help you...
heatman101
Sep 28, 2010 | Dayton Audio Dayton Speedaire Air...
The motor runs continuously and the pressure is low. What are the possible causes for this?
You haven't given any model number information, but typically on any air compressor if it won't build pressure, either you have a leak in your piping, tank, hose or the compressor cannot move the required cfm of air. Could be a valve problem or piston, relief valve? Do you hear any air leaking. There are som many different models from cheap throw away compressors to thousands of dollar models. HArd to say without more information
Jul 19, 2010 | Dayton Audio Dayton Speedaire Air...
Hi - While being moved, Speedaire compressor (model 32180) fell on its side. Side opposite pulley and dammaged unit directly opposite of pulley. I have no idea what the unit is called or its function. Was...
Lee,
I'll email you the breakdown. The pump is probably actually a 3Z180, made for Speedaire by Champion. If you are looking for the assembly sticking out of the back of the pump, it is probably the centrifugal unloader, which vents the pressure after the compressor shuts down. You can get the parts from Grainger parts (888-361-8649), or your local Champion compressor distributor.
Nov 06, 2009 | Air Tools & Compressors
Can't find parts for a Speedaire Model 5Z705
not sure of a relay you are referring to but check Grainger for speedaire which they are sold there.
Apr 09, 2009 | Air Tools & Compressors
Air Tools & Compressors Logo
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
