Question about Freud FT750T Laminate Trimmer
I want to rout out for hinges with a freud trimmer will adding a block to the bottom of base plate work? will i be able to see the area i need to rout
    President:
  • 1,996 Answers
You might be better off replacing the plastic base with a piece of 1/4" clear lexan (plexiglas). you'll be able to see through that.
Otherwise, you can make a simple jig that stops the trimmer at both ends (at the length of cut for the hinges) and controls the depth of cut by registering against the edge of the door. Make the jig base itself of 1/4' MDF or some such and longer than you think you'll need it to be so you have a way to clamp it or pin it down to the door.
If that sounds too complicated, try measuring the distance from the edge of the bit to the edge of the trimmer, in both directions, and marking the corresponding length away from the hinge position with a piece of blue masking tape or something, so you'll have an easily visible reference line when routing. You can mark it a little short and clean up the end of the cut with a sharp chisel.
Finally, run a test on a piece of scrap before you try to fit the hinge to your finished work.
Posted on Mar 26, 2009
Need a diagram of fuel gas lines on a 131 poulan
Lots of research has shown a lack of diagrams on fuel line routing. Your carburetor has the purge/primer bulb on top of it. Just to help you understand how it works....the bulb uses a vacuum effect to pull fuel from the tank directly into the carburetor and the check valves in the plate under the bulb (known as the primer base assembly) push any air and old fuel inside the carb back into the fuel tank. On your model, the line inside the tank with the fuel filter on it will come out and go to the carburetor body BELOW the base assembly. The other line coming out of the tank (fuel return line) will go TO the nipple on the base assembly. The lines should be nice and soft and so should the bulb. They all have to be replaced periodically as alcohol, heat and age deteriorate them. Please post back if needed.
Nov 06, 2010 | Poulan/Weed Eater No. Te475 952711797 17"...
I need a base plate for a Freud FT1702VCEK to make a router table will a FT1700 work.
I don't think I understand, because all routers come with a base plate, and to make a router table, you would want to remove the base plate from the router, and use the holes underneath that.
But there was a whole lot of discussion about the very same subject on a router forum, so maybe you will find the answer you need there?
http://www.routerforums.com/guide-bushings-templates/12216-freud-ft-1702-vcek-combo-router.html
Oct 13, 2010 | Freud FT1702VCEK 2 1/4 Hp Router With 2...
Square base plate and circular template guide missing. where are they available from?
Woodhaven sells all kinds of router accessories, or you can call freud, or you can make them yourself. We always made our own, to fit the job. It is nice to have the original for a template though.
Feb 22, 2010 | Freud FT2000E 3 Router
How to disconnect the water and electrical, and remove the left door of a side by side G E
This should not be very difficult. Unplug refrigerator. Remember that any water remaining in water tank inside the fresh food section will once the line is disconnected at lower left hand hinge area will pour out by gravity once the snap connection is disconnected. Allow the water to flow into a pan until empty. Then unsnap the electrical pin connectors at bottom and top hinge under the cover if present. You may also need to remove the kick plate at base of the refrigerator to be able to reach some of these connections. Most water connections you will need to push the outer ring in to loosen the line. Use care as not to damage the water lines then remove hinge screws being careful to remember location and position of screws washers and plastic hinge covers. If you need more answers please let me know, Thanks Sea Breeze
Jan 24, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
How to divide 12 11/16 inches into 71 3/8 inches?
you will need 5 full planks = 68 1/4 inches and the last board will need to be 3 7/16 inches wide.
Nov 15, 2009 | Freud FT750T Laminate Trimmer
Need to find new base screws sstripped on tightening of old base. Where can I buy replasement.
Go to FREUDTOOLS.com buy from them I have several times good folks 1 800 334 4107. don't try a substitute until you talk with them.
good luck!
Oct 04, 2009 | Freud FT1000EK Plunge Router/Laminate...
Door will not latch
There are a few ways you can fix this problem by trouble shooting a few things.....#1 If there is room inside the door opening, and your door still closes you can "SHIM" one of the hinges out. Top or bottom can be shimmed depending on where the latch for the door is hitting the Strike Plate. Close the door and watch where the latch is closing on the frame. If it is hitting above the Strike Plate then you can shim the Upper hinge, Shim bottom hinge if latch is hitting below Stike Plate. You can use anything Thin( as Thick as the hinge plate or thinner) a wooden shim, a piece of plastic, something to bring the honge out a bit. Unscrew the needed hinge from the wall and insert "SHIM" between hinge and wall and retighten screws. This may adjusting enough so the door will latch. You may also use this method sort of in reverse. Instead of shimming the hinge, you may be able to recess in deeper into the frame or the door, creating the same affect. You will need to remove the door and use a wood chisel to sink the hinge(s) deeper. #2 If that does not work you may have to relocate the strike plate up or down, creating a new area for the latch. Follow the same proceedure as solution #1 to see where the latch is hitting the strike plate. Remove and reposition the strike plate so the latch hits in the center of the hole in the strike plate. Mark the strike plate where the new postion needs to be and use a wood chisel to recess the strike plate in its new position. Than you can patch the old area with wood putty. I think #2 is the easiest, depending on how your wood work on the door framing is......I have used these tricks before, and I hope they can help you out......Joe
Jan 10, 2009 | Hardware & Accessories
How can i take the bottom stand of my monitor before i mount it t
Generally speaking, LCD monitors have a plastic cover that snaps onto the back side which covers the hinge and screws holding the base plate 'post' to the monitor. Remove the cover, and remove the screws. The post that engages the base plate will come off with the hinge intact.
tom
Dec 21, 2008 | Hyundai Computers & Internet
Belt replacement
I Can help ..... Remove 2 phillips screws under lint filter pull top of dryer forward and then raise like hood of a car Remove 2 5/16 Hex screws holding front on dryer Disconnect door Switch let front hinge down a tiny bit and up and off Belt is routed with idler hinged into base of the dryer 2 slots
Oct 05, 2007 | Whirlpool LER5636P Electric Dryer
Freud FT750T Laminate Trimmer Logo
195 people viewed this question
Top Freud Tools & Hardware - Others Experts
Jim Goldsmith
Jim Goldsmith
jairo sanchez
Are you a Freud Tool and Hardware - Other Expert? Answer questions, earn points and help others
