Question about Rainbow Technologies D4 Bagless Vacuum
Dissasimble a rainbow vacuum
I need to put the new switch in
  • Rainbow Tech... Expert
  • 324 Answers
See this
Rocky
Posted on Sep 19, 2009
How to get to the rainbow SE vacuum off/on switch.
Hi, here is a walkthrough on how to get to that part here. Steps 1 - 14 on how to access it, you will need to take apart the housing to get at it. If you need a new switch you can find that here. Rainbow did redesign this switch, so you will need to look at the wiring diagram if you are installing a new switch.
GoodVac.com Technician
www.goodvac.com
1-800-775-6586
May 18, 2014 | Rainbow Vacuum Cleaner Power Switch D3,...
Can you put a regular on and off switch on a rainbow canniser E
This link below shows you how to get to the switch on rainbow e
http://www.youtube.com/watch?v=yNNk19uP_rw
this link is where you can get a replacement switch but you can use any rocker switch that fits.
http://www.goodvac.com/Rainbow_SE_main_unit_parts_s/799.htm
Jul 27, 2012 | Rainbow 75th Anniversary Canister Vacuum
I need a wiring diagram for a rainbow d4c
Are you talking about the power switch. The new power switches have 4 wires sautered to the power switch, where the old ones have 6 wires that slip in and lock into the power switch.
The blue ones are for your power cord, and the black ones are for your vacuum motor, and your power nozzle plug.
Secure one motor wire and one power nozzle plug wire to one of the black wires out of the new switch, and secure the other two, to the other black one from the power switch. It does not matter which ones that you match together. Secure one of each of the power cord to the two blue wires from the power switch. It does not matter which one of them goes to each wire neither. It is AC so power goes both ways.
Use twist on wire nuts to secure the wires to each other, and put some electrical tape around each of them, after you secure them securly with the wire nuts.
It is best to secure the cluster of wires to each other with a pull tie, after you are finished wiring everything.
If you have any more questions let me know. I am a Rainbow seller, and a Rainbow expert also.
Thank you,
Ralph
May 25, 2010 | Rainbow Technologies D4 Bagless Vacuum
Need to replace clips that hold motor to the basin on Rainbow vacuum
There are small brass colored pin going through the latch half way between the upper portion and lower portion, where it is attached to main body of the Rainbow. Take a small nail or dowel put it directly on one end of the brass pin and tap till it comes out. Put the new latch where the old one was and insert the pin till it stops. Then tap slowly so as it pushes though the other side you can line up the hole. When the pin is flush, you are done.
Apr 14, 2010 | Rainbow Technologies D4 Bagless Vacuum
I am taking the old motor out of my Rainbow SE
Switch is not serviceable.
I think you are talking about old model switch (originally installed in your Rainbow) To remove 6 wires from the switch - push a pin where the wires go into the switch. It will release wires so you can pull them out. Make sure to draw a diagram how to connect them back.
If you need a new switch - go here
Nov 28, 2008 | Rainbow 75th Anniversary Canister Vacuum
My Rainbow stopped running
did you ever find out the problem with your rainbow? Mine did the same thing today- turned on the switch yet nothing happened. Think it needs a new switch???? Do you know how to get canister apart after taking out first screws?
Jun 29, 2008 | Rainbow E series Canister Wet/Dry Vacuum
I have a d4c rainbow vacuum, need help replacing the electrical cord
There is no reset button, but some of those old switches are very touchy . . . if there was some  corrosion, you may not have a good contact (was enough of the new wire insulation stripped away, before putting it into the switch) . . .
I prefer splicing, rather than going all the way to the switch  . . its just a matter of cutting out the old cord and splicing in the new cord in a convenient spot up in the motor compartment. . . a Rainbow purist would run the new cord all the way up into the power on/off rocker switch that's built into the top of the handle and then wire the new cord in there, directly at the switch . . . that way means no splicing . . . I've done it both ways, but I prefer to splice and use wire connectors inside the motor compartment . . . because going further, all the way up directly into the on/off switch just to avoid splicing the new cord in requires taking more things apart . . . and risks screwing up the power switch . . . that's not worth the extra time and trouble, IMHO.  (This from someone who has dismantled and refurbished over 200 D4C and SE models)
Jul 26, 2007 | Rainbow 75th Anniversary Canister Vacuum
Vacuums Logo
265 people viewed this question
Top Rainbow Technologies Vacuums Experts
JoeVacs
Are you a Rainbow Technologies Vacuum Expert? Answer questions, earn points and help others
