Question about Plumbing
Danze valve on shower is binding.
The danze valve on my shower is starting to bind and becoming harder to shut off and on. I had this happen once before and replaced the valve about 6 months ago. What can I do to stop the valve from binding more and more.
    Novelist:
  • 117 Answers
I would take the new one off. Clean the inside and see if anything is on the disk and seat which would knock it out of alignment. If you have well water it could be calcium buildup. As for prevention - look to see what is causing the valve to become misaligned
Posted on Mar 12, 2009
  • 564 Answers
Try remove the Shower and Connect it Hard
Thanks  PREM
  • Prem  Kumar
    Prem Kumar Mar 12, 2009
    Use Some Lube to get it normal
Danze shower on off valve leaking. How do i repair it?
This a common problem with most shower valves.After time the internal parts of the valve wear and need to be replaced. You can purchase a new shower cartridge for about $50.00 at your local hardware or on line. Be sure to turn off the water before removing the old cartridge. Install instructions should be included or go to Danze.com
Dec 02, 2016 | Danze Home
New danze cartridge no water
Possible issue with pressure balancing cartidge, When you remove parts, turn off water, remove parts, slowly turn on water and see if brass valves lets water out. If yes pressure balancing cartridge or cartridge itself is defevtive.
May 18, 2014 | Danze Home
Danze shower no pressure except extrememly hot
these systems have a temp limiter and it sounds like thats your problem...pull off handle and see if that part is broke or binding...if so replace or reset...good luck
Jan 01, 2012 | Danze 20 X-plode Sport Fish Home
Danze UPC tub/shower valve leaks constantly at tub spout
shut off water and pull cartridge...go to lowes or plumbing supply and match up cartridge and replace...you may also just replace seats and springs if cartridge is ok....cheaper...but if not sure just replace whole cartridge...make sure hot is on left...
Aug 15, 2011 | Danze Home
I recentlly had a Danze model # D11200BT installed in my tub shower. The problem is every time you turn the water off there is a banging sound that comes out of the valve it self. The sa me thing happens...
You have what is called water hammer effect going on the water pressure is to high this can cause problems with all you plumbing fixtures. You need to have a water hammer arestor install or put a main line pressure reducing valve in.
May 29, 2011 | Danze Plumbing
Shower valve has a thumping sound when other faucets or toilets are turned on and off.when you turn shut offs to danze shower valve off sound goes away.could this possibly be the plunger in the valve?
Vfiippone,
I have the same issue with a Danze Sonora shower Valve. I called Daze and they sent me a new cartridge. After installing it I have the same problem. I also put a surge arrester on my toilet which had little effect. If you find the cure please post it.
Nov 04, 2010 | Danze D500058BNT Parma Shower Trim Kit w/...
Need an instruction sheet for cartridge replacement for Danze Sheridan tub and shower faucet
This link will get you to the Danze illustrated parts list for the Sheridan single control tub and shower valve.
http://www.danze.com/products/pdfs/D510055_ip.pdf
Aug 08, 2010 | Danze Sheridan Tub & Shower Faucet
What makes the faucet bind?
I'm just installing the exact same faucet and I found that the side to side motion was binding if I tightened the tap too much from the bottom with the nut & "c" shaped clamp with the 2 set screws. Not sure what it could be if yours was fine & started having trouble.
They have support contact info on their website that you may want to try: http://www.danze.com/customer_support.asp
Good Luck,
-David.
Apr 10, 2010 | Danze Plumbing
Danze control valves producing loud water hammer
It sounds like your flow diverter isn't closing properly. Try removing the flow restrictors from the shower nozzle and see if that helps.
Apr 06, 2009 | Danze D500058BNT Parma Shower Trim Kit w/...
Danze shower kit
your husband is 100% correct unless you change the shower head or take the one off that is there and take out the little plastic filter thats right inside where it screw on to the shower arm,, easy fix
Nov 09, 2008 | Danze D500558T Parma Shower w/ 4"...
Plumbing Logo
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
