Question about Electric Superwinch 12 Volt DC Winch - 8500-Lb. Capacity, Model# 1585200D
Winch will not hold a load
We lift load's around 1000 pounds but the winch will not hold the load we have to keep lifting the load is there a breaking system we can titghte on it?
  • Electric Master
  • 15,557 Answers
Is it slipping or stalling?
Posted on May 19, 2013
I need to 225 cubic feet of helium. How many pounds is that? Thanks!
The difference in the up and down force is 0.069 pounds. Therefore each cubic foot of helium could lift 0.069 pounds. In order to lift 100 pounds (which would include the weight of your load, the balloon, and the helium) you would need 1449 cubic feet of helium
Aug 23, 2017 | Office Equipment & Supplies
The special rod will not raise tire.Under load the rod mechanism slips from winch connection.What can I do?
try one that has the same or better end also try lifting tire up while turning and you can lower in down and lubercate it with spray lube and try again
Sep 30, 2014 | Cars & Trucks
The lift for the tonearm doesn't go up high enough and lift off record
The Rega tonearm lift / lower platform has a 1.25mm hex socket, if my memory is still working. Some cheap allen key sets are around with a bunch of the tiny keys included..check the Pound Shop.
After you undo it..just needs a tiny nudge up, do a tiny nudge, tighten and check...repeat if more height needed- and mind your stylus.
May 26, 2012 | REGA RP1 Turntable
Wire a winch
The 1585202 winch is capable of pulling 8500 pounds when provided adequate DC power. With no load (winding up slack the cable) the motor requires 84 amps and winds at 18 feet / second. When fully loaded (8500 pounds), the motor requires in excess of 320 amps and winds at 3.5 feet / second. That's an awfully large amount of current and it will need heavy duty power supply cables to work without overheating or melting insulation. I suspect your 1585200 is the same model with same electrical requirements, but did not include a fairlead, mounting plate, etc..
Superwinch has wiring kit #2007 for front mount (5 foot cables) and #2008 for trailer mounts (25 foot cables) and can simplify the installation with other accessories as well. They're a U.S. company and can be contacted them directly:
Superwinch, LLC
359 Lake Road
Dayville, CT 06241 US
Ph: 860-928-7787
F: 860-928-1143
www.superwinch.com
Dec 22, 2011 | Electric Superwinch 12 Volt DC Winch -...
2006 snow bear plow, winch will not lift plow, sounds like its turning but is not lifting plow consistantly, Is something loose?
Yes, Check where strap or chain is mounted to winch. It could be loose or have dirt or oil on it something to make it slip.On mine there's a brass piece that raps around the shaft, It got lose and dirty so I cleaned and tightened it. If you pull motor off winch to check gears [don't use gear] when reassembling it's too thick when it's cold. I used white spray lube. Hope it helps!
Jan 20, 2011 | 82" TruckSUV Snow Plow
Snow Bear Winch..... Will not pick up plow at times. Motor seems strong drum will not turn,,,slips. Is there a replacement part available without buying an entire winch? Thanks
Hi there, I had the same problem, my winch has a chain to lift the plow.I put oil on the chain to keep from rusting and thats what started my troubles.So I took the mount off that holds the chain on the winch and there's a brass piece that is squeezed behind it.Cleaned and tightened it and works fine now. If you take motor off winch to check gears[ DON'T USE GREASE] when reassembling! When its cold it doesn't want to turn, just use motor oil or spray lube
Jan 19, 2011 | 82" TruckSUV Snow Plow
Manual chain hoist keeps slipping load chain when under load (lifting and lowering). It will hold when you keep tension on the slack side of load chain. Any ideas?
sounds if the motor brake is not holding , this is a wear part and will require adjustment/replacement over its life time , the brake is located under the motor cover , but if your not sure what to adjust ,then im gonna suggest for safetys of you and the people around it' s sake you get a profesional to service this hoist
Aug 19, 2010 | Jet Equipment Chain Hoist 1TON 10 Ft Lift...
Washer making noise when on spin mode
Washer may not be level.
Loads may be too large.
Sometimes a smaller load will send all of the clothes to one side and it may make a pounding noise.
Check to make sure that your machine is level, then wash a smaller load to start and then wash a larger load. Good luck!
Jan 26, 2010 | Washing Machines
Anchor winch
There is a great chance the clutch has frozen due to corrosion.It need to be pulled apart at the clutch.Its not a big job and quiet easy.The plates freeze together and need to be "cracked" apart.I hope this helps
Sep 23, 2009 | Boating
Electric Superwinch 12 Volt DC  Winch - 8500-Lb. Capacity, Model# 1585200D Logo
154 people viewed this question
Top Electric Hammering Experts
John Trevino
Pieter Vleeshouwers
Pieter Vleeshouwers
Dan Webster
Dan Webster
Are you an Electric Hammering Expert? Answer questions, earn points and help others
