Question about Lutron LG-600P Lumea Single-pole 600 Watts Incandescent Dimmer
Lights don't come on right away - Lutron LG-600P Lumea Single-pole 600 Watts Incandescent Dimmer
Our masterbedroom light started flickering, sometimes making a little buzzing noise and then it stopped working. Now the living room light which is right next to the bedroom flickered a couple of times and...
I found this posted in the car section, but I will post an answer anyway.
You have a short in the house wiring. Could be in the switches, or the light fixtures, or the wiring going back to the breaker.
Yes it could be a fire hazard if not repaired.
If you can't get it fixed before you leave town, I would turn the breakers off for that section of the house.
Dec 14, 2012 | Cars & Trucks
My 2000 pontiac grand prix is smoking. I added coolant and oil. It overheats right away. What's the problem? Oh yeah...it just started doing it today.
they are known for bad head gaskets and intake gaskets, have it diagnosed at the shop and don't drive it or you can do serious damage to the engine.
Sep 05, 2012 | 2000 Pontiac Grand Prix
How can I figure out why fuse 15A keeps blowing? My dashboard lights don't work nor do the back lights. My breaks and signals work but at night when I turn the car on the regular lights in the back...
There is a shorted wire somewhere in that circuit. Check to see if any wires are pinched under a bracket or brace where he was working. I have seen it where it was a light bulb the was bad. Need someone familiar with a volt/ohm meter to help trace problem. Good Luck. You did not state where he had been working.
Apr 17, 2012 | 1996 Honda Accord
SERVICE ENGINE SOON LIGHT ON BUT NO DAYTIME RUNNING LIGHTS OPERATING
You need to get the eingne codes read first . It sounds like you may have some kind of electrical issue with the daytime running lights . However it may or may not be related to that . The first thing you need to do is get the codes read . Most auto parts stores will do this for free if you don't have a code reader . Find out why the engine light is on it likely solve the problem by replaceing a sensor or simple electrical part . Don't geuss at this find out and you will save a lot of money most problems are related you find the right thing and all of the problems go away . But you need the engine codes first
Sep 13, 2011 | 1997 Chevrolet Malibu
There's a flashing green and red light when my car is on and the sub attached to the amp is making a heartbeat like noise when the light goes green and then the light goes red right away. everything is...
Check the wires for short circuiting at the car body or speaker wires. Triple check really everything.
Make sure the connectors are 100% connected to the wires. There maybe some resitance if the amp isn't getting enough power from the battery.
Aug 19, 2011 | Jensen JXP680 Car Audio Amplifier
How do I start the playskool sit and spin
First you have to sit down criss cross on the sit n spin, then you have to grab the center piece and pull on it,it should spin right away, if there are any lights or music they should begin to play. If they don't they should light up after you put batteries in it.
Jul 21, 2011 | Hasbro Playskool Sit N Spin - Pink
My 1998 chevy lumina won't start right away and
The cooling system shouldn't be losing much coolant.
If you're putting in coolant regularly
If you're seeing slick oil in the coolant
If you're hearing noise in the engine while driving
You may have a crack in your engine block and your engine isn't being lubricated properly anymore. This will cause noise and leaks, make a motor run really rough and cause rough starting.
I suggest you bring your vehicle in for a coolant system pressure test and a chassis leak check. This should be a free service from any auto shop that wants your money for repairs.
Spark plugs usually degrade your performance slowly and don't make noise while doing it unless in extreme cases.
May 24, 2011 | 1998 Chevrolet Lumina
The engine seems to have oil, but the light is on in my 1995 nissan altima
The oil light means you have low oil pressure but not necessarily low oil.
Low oil pressure can lead to serious engine problems and should be fixed right away.
Jun 17, 2009 | 1995 Nissan Altima
Lutron LG-600P Lumea Single-pole 600 Watts Incandescent Dimmer Logo
35 people viewed this question
Top Lutron Electrical Supplies Experts
jdthefixer
ken skalski
Are you a Lutron Electrical Supply Expert? Answer questions, earn points and help others
