Question about Toro Lawn Mower With Toro Power Tools
Personal pace don't work (Toro Model 20095) how do I adjust it?
Personal pace don'twork - when I pull the P.P Bar up, the cable down by the engine moves and the spring just beside the cable lengthens out but the PP does not move - I have to push it -- there is no action from the personal pace at all -- it's just like having a mower that does not have the self-propelled feature. My Toro is a 21 in Super Recycler , Model # 20095. On page 10 in the Toro manual -figure 18 (using the self-propel drive) there is a very small # that is G003221 ( I don't know if that is the cable # or just the figure # but it is there. How do I adjust this or do I need to replace something?
  • 147 Answers
SOURCE: toro self propelled mower will not move
This is a very simple solution, When you pull the lever it simply pushes a pulley into the belt to make it tight. Most of the time the belt has come off or maybe the cable broke. Turn the mower over and you will see the belt. My money is on the belt off.
Posted on Nov 06, 2008
  • 81 Answers
SOURCE: Toro Personal Pace self propel problem.
Your self-propel is probably belt driven. Belts can make an awfully lot of noise when unhappy. Possible it has rolled over and is running on the wrong side of the belt or is worn and just needs replaced. Hope this helps.,
Posted on Jun 19, 2009
SOURCE: Toro model 20038 self propel problem
Try taking the back wheels off and lubricating the joint cogs and wheels with ,say, 3 in 1 oil . The dealer recommended doing this once every couple of years as preventative maintenance when I bought mine , and it has solved sticking problems for me .
Posted on Sep 12, 2009
  • 5 Answers
SOURCE: I have a Toro Personal Pace Recycler mower with a
It's not that hard. I've never done it on my Toro GTS 5.0, but I have done it on a Briggs and it's pretty much the same. Start by removing the 10mm bolts around the perimeter of the engine shroud. DON'T remove the 4 top bolts on the recoil housing. You might have to remove the fuel tank first. Drain it, then loosen the 2 8mm screws and lift it straight up. No need to disconnect the fuel line, just set the tank aside. After removing the 10mm bolts, the shroud should lift right off. Flip it over and you will see the recoil pulley. Remove any leftover cord from the pulley. Now you need to wind the pulley against the spring in the direction it goes when you pull the cord. It might wind 2 or 3 revolutions but don't overdo it. Now you will need some sort of clamp to hold the pulley in place as you line up the slot in the pulley with the opening where the handle goes. Next, feed the new cord through the opening and into the pulley and tie a knot to keep it from slipping out. Carefully release the clamp and let the pulley slowly wind the new cord onto itself. Finally, attach the handle on the other end of the cord and test it. If you can pull the handle and the cord comes out and it retracts normally, re-install the shroud and tank.
Posted on Oct 03, 2010
diodeic
  • 1622 Answers
SOURCE: How do i adjust the
There are four problems I can think of.
1. The belt has broken or slipped off the gears.
2. The gears could be broken.
3. The wheels could be worn out and won't propel the mower.(I doubt this one)
4. The lever you move to engage the wheels isn't working.
Start with the lever and check to see that it is connected and intact. If it is then take the cover off of the wheel where the belt and gears are located. Be sure you remember which bolts go where and how you removed the cover! Then look for anything broken or out of place.
I think you can fix it. The parts should be easy to find since you got it from Sears. Good Luck!
Posted on Apr 15, 2011
Toro model 20332. Have put new transmission, belt and new drive wheels on back. When I use the personal pace bar it makes a grinding noise. Doesnt make noise unless I push that down.
Sounds like either the gears on the wheels or ends of the trans shaft are bad, or the internals of the trans are bad. Are the parts actually new-new, or used and new to the machine, you didn't specify. What happens when you manually spin the pulley on the top of the trans in either direction?
Aug 14, 2016 | Toro 20332 22" Personal Pace Walk Lawn...
Toro Model 20070 lawn mower starts and runs, just does not seam to have a lot pf power does anyone have a lack of power issue with their Toro 20070 Pace Lawn mower. Runs fine just no balls
could be dirt in the carby , blocked fuel filter or lack of adjustment in the accelerator cable
I will go for a cable adjustment as they slip under the clamp on the carby bracket when the throttle is pull wide open
May 30, 2016 | Toro Power Lawn Mower
Toro 20333 self propel. Doesn't engage. l
Is the tension spring gone? How is the cable? Usually there is a spring at the end of the cable in which when you pull back on the bar with your hands, this tightens the belt so that it engages with the engine allowing the wheels to turn.
Oct 06, 2015 | Toro 20332 22" Personal Pace Walk Lawn...
Toro Personal Pace sounds like it is running at half power
got oil in it, or do you add oil. Left outside alot, fuel line clogged. Is the gas old. Check the blades and the exit portion of the clippings. Does it have a drive train for ease of moving. those can bog down a mower. good luck
Apr 30, 2013 | Toro Lawn Mower. 22 in. Personal Pace with...
Replace right rear hieght adjuster on a toro self pace mower
Remove wheel, remove screws mounting adjuster, straighten or replace.
Oct 02, 2012 | Toro 22 in. Personal Pace with Blade Stop...
Toro 2009 personal pace mower transmission went out
You should post this question in the lawnmower section so the proper expert will see it..
Aug 29, 2012 | Toro Lawn Mower. 22 in. Personal Pace with...
How do I replace the torsion spring in the handle of a Toro Personal Pace lawnmower?
Thanks so much Jamie. I had the top of the handle off but couldn't get any
further. I had to use a screwdriver on one side to get the brass bar out of the
plastic channel (I was afraid I would crack the plastic but didn't). I was able to remove the bar from the handle by myself with lots of effort ( BTW in your
solution did you mean your son pulled vertically up on the handle while you pushed vertically down on the bar?). I had one foot on one side of the handle and pulled up on the other side while pushing down on the bar. Isn't the web and Google amazing. The Toro sight didn't have a service manual. So I just typed "How to replace the torsion spring on a toro lawnmower" in Google an the question came up. I think Toro has a design issue with an overstress point on the spring. That part is on back order at the factory.
I did it.
May 01, 2012 | Toro Personal Pace CARB Walk Power Mower
How do u adjust the personal pace toro...doesnt pull itself like it did.
Up on the left side of the handle should be the bracket that holds the drive cable to the handle bar. Take two 7/16" wrenches and loosen the clamp that holds the cable. Slide cable down towards the deck about 1/4" , then re-tighten clamp. Test the mower to see if it adjusted, might have to go 1/8" or possibly more. Hope that fixes it, some of these mowers have had a problem with the transmissions gears going bad from improper adjustment or lack of grease in the gear box. Also make sure the drive belt is good.
Aug 31, 2011 | Garden
My Toro Personal Pace 22"
pull your spark plug and see if it will pull then, if so then it is hydro locked with fuel which can be caused y a bad fuel cap, not venting or a stuck open needle in carb causing gas to flood cylinder
Jul 27, 2011 | Toro Lawn Mower With Toro Power Tools
Toro Lawn Mower With Toro Power Tools Logo
133 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
