Question about Apple iPod nano
The window does not show the display.
It only shows black lines, but it still plays music if I get lucky and push the right buttons
    Problem Solver:
  • 12 Answers
Your screen is broken. You can either buy a new iPod, or get a screen off www.ifixit.com
Posted on Mar 16, 2009
Stove clok is not showing time
try pressing the clock button after setting the clock .^-^
Mar 09, 2015 | Kenmore Kitchen Ranges
Phone line doesn't ring
First, lets get rid of the static. Try Feature #86. This will turn off background music. When a music source is not attached you get static.
Enter programming by using Feature XXX66344 password 266344. The display should show "Terminals&Sets" press the top right button with an indicator in the display. The display should show "Show set: ____ enter the extension number that you want to check or program. The display will show ***:name. Press the top right button three times. The display will show Show Line:____ with options to Scan or List. If you select Scan it will show the lines assigned to that phone. If you select List it will start with the first line in your phone system showing one of four states 1- Unassigned, 2- Ring Only, 3- Appear&Ring, 4- Appear only. Change the selection on the line by using the CHNG soft button. This is where line assignments are changed from the four states for each extension.
The only other thing that will keep an extension from ringing is "Do Not Disturb" or DND. Feature 85 and #85 will turn this feature on and Off.
Jan 31, 2014 | NorStar Meridian M7310 Phone
I am trying to get the Mephisto, Master, to move as white first. I have set the operation mode at +top but it still opens up game playing computor as black
My name is Paul and I can answer your question about making the Mephisto Master Chess computer play the white pieces.
1. Set up the pieces so that you are playing black or have black pieces closest to you.
2. Push the option button and push your finger or a chess piece down on square G1 making sure that you have a symbol with the appearance of a cross to the left of the word top.
3. Push the clear button once and you will recognize that the display is showing that white has the turn.
4. push the enter button one time to force white to show its first move. Now what you see in the display will not be correct but stand up and look at the display lights horizontal and veritcal and you will see that they indicate the correct piece to be moved but the alphabetical and numerical information on the LCD or the display will not match.
Follow the display lights and look the the piece symbol and you will see what I am talking about.
I haven't figured out how to make the computer show the correct information yet but when I do I will let you know immediately.
Have fun
Jul 17, 2011 | Mephisto Master Chess Computer
My nexter mp3 turns on but cant listen to music
Not sure if either of these helps, but hope so:
1-After you boot up/turn on, is the word "Music" showing in the window? If not, use the right arrow button to move the menu to Music, then hit the M button and it will start playing.
2-Mine (797) has a bad headset hole so only plays one ear unless I push up in the plug wire. I just put a rubberband tightly around the plug and pull the band up over the top to pull it into a position where I can hear both earsets.
Aug 04, 2010 | Nextar MA7151B MP3 Player
How do you program so that when the phone rings you are able to pick up the call without hitting a button. Also when you make an outgoing call and you pick up the phone you get an active line instead of...
Sets that are programmed to ring should automatically have ringing line preference.
Programming is done on M7310, M7324 and T7316 sets.
To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS.
The 4 top line/feature keys are now used for programming2.gif.
At the terminals&sets prompt, press the show key (top right arrow).
The display should now ask for an extension number. Enter extension number you wish to program ringing on.
Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should say line 001: appear only
press the Chng key till it says appear & ring
press next key (lower right arrow)The display should say line 002: appear only
repeat procedure for remailing active lines
press the heading key (top left arrow) til the screen says terminals&sets again
Prime line assignment is also programmed at the terminals&sets prompt.
press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you want to change the prime line on.
The display should say Line Access
The display should say Line Assignment
Press the next key (bottom right arrow) .
The display should say Line Pool Access.
Press the next key (top right arrow)
The display should say Prime Line
Press the Chng soft key till you get to the desired line or pool to pick up on
Press the release key when finished
Oct 19, 2009 | NorStar Meridian M7310 Phone
T30 always comes up with record-ready display screen
T30 defaults to an opening display screen based on where you were when you last used the device. When leaving from the record folder and record mode, you will always open with the record-ready screen. If you left your T30 while in the music folder playing a music file, you will be returned to that.
This record-ready display screen has a numeric and bar time line. The numeric values of the line are in hrs:min:seconds. This line is also split: the right half of the line indicates the total amount of available recording time, while the left half indicates your time as you record. If you compare the values of the right and left sides of the numeric bar while you are recording, you will see that the right side is diminishing as the left side increases in numeric value. When you complete your recording and save your track, the right side will now indicate the new total time (the amount your screen first displayed LESS the time value of the track just recorded).
When you are playing a music file, if you watch the time display, you will see the numeric information changing in the same way. The left side indicates how may hrs:min:seconds your track has played while the right side indicates the total time value for that file and will be correspondingly decreasing while you play your music file.
So in the short, you don't need to worry much about your display screen unless you open in the wrong folder or you need more recording time than is available. Then it has a message for you.
Nov 06, 2008 | iRiver T30 MP3 Player
Sony Bean 1gb "Format Error"
I have the solution. Push the menu button (the one ne with the file folder) until "search" is displayed. push the down arrow key on the jog button,10 times, until "advanced menu" is displayed. Pushe the right button on the jog until "format" is displayed. Use the jog buttons until "format ok" is displayed. Then push the play button and the problem is sorted. Good luck.
Apr 28, 2008 | Sony Walkman Bean NW-E305 MP3 Player
Muvo v100 no music
if u put ur music in a library then u have to push the wheel down then move it right or left til u find skip folder push wheel down when u find it then move the wheel left or right till u find the folder u put the music in it then it will say please wait and wala u got music
Mar 31, 2008 | Creative Labs Muvo V100 MP3 Player
Delstar ds 801 mp4 1gb
For the 10 second play problem the player has been set to intro mode, which only will play the first 10 seconds of each song. While it is playing, press the mode button ( bottom right ) once. This brings up the play sub-menu. It should show " repeat" as the first item. Press mode button again and it should show "intro". Now press either the top or middle buttons on the right side once, this shows all repeat choices again, using the same buttons scroll through them till "normal" is highlighted. Then press the bottom right button again. This shoudl put it back in normal play mode and return to the music screen.
Dec 26, 2007 | Delstar DS 917 Digital Media Player
Sony F55 Recorded Display
The filename (e.g. DSC0012.jpg) shows the image number, the filespec shows the date and time recorded. Most software will give you document info about resolution of the image. I wouldn't worry about what the battery status was when the shot was taken or how many other images were on the Mstick. I guess I'm not sure what you need.
Sep 11, 2005 | Sony Cyber-Shot DSC-F55 Digital Camera
Apple iPod nano Logo
50 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
