I have a front load frigidaire washing machine the door latch wouldnt work . so i bought a new one and it still doesnt work. could it be the start switch? fridgidaire model ltf 214oeso
  • mike albin Jan 07, 2013
    Did you just wash or a few loads ago wash an area rug or something with a lot of debris? If so, there is a filter just before the pump. You will see a rubber hose/housing for the filter. Take off the hose clamps and clean out the filter and put all back together. The hose clamps are a bit of a pain to get off and on but should work perfect after that
  • 294 Answers
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse. hope this helps
Posted on Mar 12, 2009
  • 744 Answers
Go to searspartsdirect.com and type in your model number. The door latch assembly can be found under the "Door and Latch Parts" heading as item number 7 (part #8181700). If you need instructions on how to replace, just follow this link:
http://www.fixya.com/support/r587965-door_latch_replacement_fdl_error
the above link is from fixya and this provide u better help....
thank u!!
    Novelist:
  • 117 Answers
  • 916 Answers
Check the switch on the opening for the door, that may be the problem
Frigidaire Affinity ATF7000 installed new door switch now says cd
The main control board thinks the door switch circuit is "open" - you would need a professional to . Is the loading door closed? No, close the door. Yes, go to step (2). 2. Disconnect the plug from J2 on the Main Control Board and check for continuity between the pins in the plug. Open, check the door strike. If good, replace the door switch assembly. Closed, replace the Main Control Board.
Aug 22, 2012 | Frigidaire Affinity ATF7000E Front Load...
I have a Frigidaire Front Load washer Model#ATF6000FS2 washer . It will not start and seems to be experiencing a problem with the door. There is 'DOOR LOCK' light that does not turn on and th
Sounds like the door is not latching correctly. Check the door for any sagging problems and then check the door latch itself for any damages, cracks, or issues with the door itself connecting to it.
Jul 21, 2012 | Frigidaire ATF6000ES Front Load Washer
Door handle broke
This is not an identical one but is another LG that has the same latch setup. Hope these pics help.
Mar 07, 2012 | LG WD-16115FD Front Load Washer
Fridgaire FTF530fs3 door lock buzzing and not locking, washer won't start
fit a new door lock as if it doesnt engage it wont allow the machine to start the washing cycle
May 31, 2011 | Frigidaire FTF530FS Front Load Washer
Can I reverse the door on my new Frigidaire Affinity front loader?
Hi, as far as i know you can only reverse the dryer, the wiring for the door latch doesnt allow you to reverse it on this washer.
Sean
Mar 26, 2011 | Frigidaire Affinity ATF7000ES Front Load...
How do I replace a handle on a Frigidaire front loading washer
This was easy when I really looked at it--2 screws on the inside of the door and it was off. Apparently it was designed to break easily to prevent damage to the latch and was made easy to replace.
Mar 19, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire washing machine fwt449gfs1
Check to see that the switch is actully being activated when door is closed. I wiggled the door upward to notice the machine started working. I then wedged a piece wood or wooden pencil in the botton of the door crack and that caused the switch to activate.
Switch is okay but the door alignment needed to be fixed.
Aug 09, 2008 | Frigidaire FWTBB30DS Front Load Washer
Frigidaire washer will not start. Get err and LOC codes.
All the lights are on, but the door lock. We have unplugged it, doesn't help. Our washer is the front load, model LTF 2140ES0.
May 18, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Error Codes
Door Open. if it does this when running or door closed, probably the door lock asm. also check latch on door, this plastic wears and breaks
Feb 21, 2008 | Frigidaire GLTF2940ES Front Load Washer
Washing Machines Logo
44 people viewed this question
Top Washing Machines Experts
