Goodman furnace will not start
I have a goodman model gmpn080-4reva that is putting out a code 11 what does this mean
    Guru:
  • 462 Answers
CONSULT THE WIRE DIAGRAM THE LEGEND SHOULD BE NEXT TO THE WIRE DIAGRAM Sorry about the caps. Hope this helps please rate me accordingly and good luck.
Posted on Mar 12, 2009
I HAVE A GOODMAN FURNACE AND IT Has a standing red light on the control board. power is on, but furnace wont start. what to do?
If it’s a steady red light then that means it’s functioning properly. Flashing red is when there’s a problem. Check to make sure your blower door is on properly. If it’s not it is like a fail safe for the furnace to not start.
Apr 21, 2018 | Goodman Heating & Cooling
Replaced the gas valve in my goodman furnace now it won't light and red status light stays solid
solid means it is on stand by, no call for heat, put jumper wire between r and w it should start, if it does check t- stat
Oct 27, 2015 | Goodman Heating & Cooling
Goodman furnace model gmp125-4 constant fast blinking red light on circuit board, furnace dont work, have moisture in bottom from seeping drip pan under acoil
There should be a chart pasted to the inside of the front access panel of the furnace. It will tell us what that particular blinking sequence means. Goodman isn't listing a gmp125-4 furnace so I need to assume it is a condensing gas furnace. I water has backed up into the draft inducing fan, the furnace will shut down. There is no reason for water dripping from the drain pan unless your A/C is running and the drain on the pan is plugged. Give me all the info. you can and exactly what is happening. Please look up the coded problem for me. I'll watch for your reply. I hope this is not too late to help.
Oct 07, 2013 | Heating & Cooling
Goodman furnace GMP075-3 The thermostat was in the off position over night and sometime during the night, the induced blower and blower motor came on. The trouble light on board blinks 5 times. I checked...
Need your model # to check the codes but, this coming back on after turning the t-stat off is rare. You may have been in a lockout and the furnace re-started. Some furnaces try to start three times , then lock out. Time out, then re-start. The codes should be on your furnace blower door. Write back with this info and i could help.
Oct 12, 2011 | Goodman GMS90703BXA Heater
Goodaman furnace MODel #GMP075-3 work well yesterday and today won`t start, what should I do?
look in the little window for flashing light.count the flashes.take front covers off .on cover is a list of what codes mean.
Dec 24, 2010 | Goodman GMS90703BXA Heater
Goodman furnace model # GMNT100-4B On vacation, neighbor checked house, house filled with gas. He shut off main and furnace. came home turned on gas to everything except furnace. All good. Furnace will...
Solid red typically means bad controller. Try unplugging the furnace, wait about 30 secs, then plug it back in. The possibility that the controller was sending voltage to the valve even when there was no flame is a bad sign. If the controller starts the furnace, watch it very closely and see what it does. If the solid light comes back on, it's time for a new board.
Mar 24, 2010 | Goodman GMS90703BXA Heater
What is the model number for the Draft Inducer Motor Goodman GNP075-2REVB Furnace
I think you must mean GMP075-2rev8 check this link for parts listing:
http://site.famousparts.com/goodman/PDF/RP-169C.pdf
Johnstone supply which has many locations in many cities sells Goodman and stocks parts, and available mailorder http://www.johnstonesupply.com/corp/Default.aspx
Feb 18, 2010 | Goodman Furnace Draft Inducer Blower ...
I have a Goodman GMPN080-4 furnace. The light on the board blinks 3 times. The furnace won't light at all. What could be the problem?
Hi 3 blinks should mean it is the pressure switch there should be a code in the manual or inside of the door
Jan 30, 2010 | Goodman Heating & Cooling
Heating & Cooling Logo
209 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
