Question about Whirlpool Duet GHW9150P Front Load Washer
GHW9150PW0 DUETTE WASHER CONTROL LOCK IS ON. CAN'T GET IT TO GO OFF. CAN'T USE WASHER.
  • 478 Answers
Have you held it down for the required 5 seconds?
Posted on Mar 13, 2009
Getingcodef71onwasherwasherwillnotstart
An F71 error indicates that the control panel (the buttons you press) is not communicating with the central control unit. Open the panel and check if there is continuity to the control panel wiring harness. Make sure that the wiring harness is fully connected to the user interface panel and the central control unit. Depending on if the drum rotates, you need to replace the user interface or the central control unit. (If the drum rotates, then it's probably the user interface. Otherwise it's the central control unit.)
Whirlpool has the parts diagram for the GHW9150P on their site in the Manuals and Literature section. The direct link to the parts list for the GHW9150PW0 is: https://www.whirlpool.com/digitalassets/MLPDF/Repair%20Part%20List%20-%208180440.pdf . For other models, enter the model number and click search on this page: https://www.whirlpool.com/webapp/wcs/stores/servlet/OCManualsLiteratureSearchView?catalogId=10561&langId=-1&storeId=10211&krypto=5QgxQhneFliXuEuX564wSQ%3D%3D&ddkey=http:OCManualsLiteratureSearchView . This site has the parts for the GHW9150PW0: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5136839&diagram_id=28192106 . If you have a different model, start here: http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=ghw9150p .
I hope this helps.
Oct 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washer model GHW9150PW0 control lock light on will not start a cycle
Hi
Thanks for using FixYa. To unlock the controls you’ll need to press and hold the END OF CYCLE button for 10-15 seconds. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 22, 2010 | Washing Machines
Water goes into the washer (model GHW9150PW0)
your inlet vaulve is sticking and allowing water to trickle through, only solution is to find if it is your hot or cold vaulve and replace it
Feb 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How do I lock the tub on the Whirlpool Duet GHW9150PW0 for moving?
Replace the basket locking pins that were removed when you first got the dryer.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 17, 2009 | Whirlpool Duet GHW9150P Front Load Washer
CONTROL LOCK LIGHT ON. CAN'T USE WASHER
Hold down the 'end of cycle' button for 3 seconds.
Mar 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Control lock light will not go off.
Do you have any error codes?
Does water remain in the washer after the final spin?
If water remains in the washer after the final spin, then the door will not unlock. Drain/Spin or Spin Only to remove any remaining water from the washer. The door should unlock at the end of the cycle.
Is the door locked and the Add A Garment light on?
If the Add A Garment light is on, then the washer door will unlock after the Pause/Cancel button is pressed once. Pressing the Start button will restart the washer at the same point where it left off in the cycle.
Is the door locked and the Add A Garment light off?
If the Add A Garment light is off, then the washer door will unlock after the Pause/Cancel button is pressed twice. The door will not immediately unlock while the cycle is running due to a possible high-water level in the washer, high-water temperature, tumbling or spinning. It may take up to five minutes for the washer to stop spinning and draining before the door will unlock. You will hear the door click when it unlocks.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Steady tone coming from ghw9150pw0
could be problem in control bd not necessarily a problem with function but something in sound circuit ck for a sound control button on keypad it may say something like alarm volume or on off try holding it down after turning power on if you notice any change in volume or tone of sound shows you're on right track only thing is solution may mean new control bd
Sep 04, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
622 people viewed this question
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
prem mathew
