Question about Zyxel Simultaneous 450Mbps Dual-Band Wireless N Media Router, P/N: NBG5715. ds-s
Windows 8 wireless not connecting - Zyxel Simultaneous 450Mbps Dual-Band Wireless N Media Router, P/N: NBG5715. ds-s
  • Zyxel Master
  • 7,733 Answers
Need more error info.Although sometimes your antivirus app maybe is blocking the router.
Posted on Apr 24, 2013
How do i connect hp 1050v compaq laptop to wifi
It depends on the version of Windows you are running but for Windows 7/8, on your Desktop you'll see a notification icon in the task bar alerting you to the fact that there are wireless networks present. Click on that and select the wireless network you want to connect to. Note that many wireless networks require a password to connect.
Mar 10, 2015 | HP Computers & Internet
Tip
Configure Wireless Zero Configuration to configure wireless connection on XP...
Configure Wireless Zero Configuration to connect to wireless network on your wireless XP computer.
Below mentioned steps will help enable Wireless Zero Configuration on your XP computer and achieve wireless connectivity. These steps applies to your XP wireless computer (Desktops and laptops) with external or built in wireless cards.
Please perform the following steps on your wireless computer to enable WZC (Wireless Zero Configuration):
1. Right click on My Computer icon and go to Manage.
2. Go to Services then go to Service and Applications.
3. Double click on Wireless Zero Configuration.
4. Change the Start Up Type to Automatic and click on Apply
5. Click on Start and press OK to close the window.
6. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
7. Right-click on the wireless Network Connection icon and select 'Properties'.
8. Go to the 'Wireless Networks' tab .
9. Check the option 'Use Windows to Configure this Wireless Connection' and click 'OK'.
Now please perform the following instructions to connect to the wireless network:
1. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
2. Right-click on the wireless Network Connection icon and select 'Properties'.
3. Click on the 'wireless network' tab.
4. Under Preferred networks if you see any name in the list then highlight the name and click remove.Click OK.
5. Right-click on the wireless Network Connection icon and select 'View Available Networks'.
6. Look for the SSID (aka Network Name) of the Wireless router or access point.
7. Highlight the SSID from the list that you want to connect to.
8. Type the security Key here and click on the 'Connect' button. You should have successfully established a wireless network connection.
The above steps will help you in the configuration of wireless connectivity if you are not aware about the settings of wireless connection utility installed on the computer.
on Mar 18, 2010 | Computers & Internet
Tip
Enable WZC (Wireless Zero Configuration) and connect to wireless network on...
Windows XP has built in wireless utility which can be used to connect to the wireless network. Though, you can still use the wireless utility software that came with the wireless adapter. Please perform the following steps on your XP wireless computer to enable WZC (Wireless Zero Configuration):
4. Change the Start Up Type to Automatic and click on Apply.
8. Go to the 'Wireless Networks' tab.
4. Under Preferred networks if you see any name in the list then highlight the name and click remove. Click OK.
7. Highlight thee SSID from the list that you want to connect to.
9. You should have successfully established a wireless network connection.
These steps will help enable wireless zero configuration on your XP wireless computer and you can connect to your wireless network using it.
on Feb 13, 2010 | Microsoft Windows XP Professional SP2
How to find wireless network name?
Check the wireless router is set to broadcast the ssid .If it is not you will not see the name of the Wireless Network. It should be listed unless the wireless router has gotten hung up try down powering the router for about 10 seconds and power it up again. Check if Windows 8 is in Aeroplane mode.
http://www.7tutorials.com/how-connect-wireless-networks-windows-8
http://www.7tutorials.com/how-connect-hidden-wireless-networks-windows-8
I am listing the above as Windows 8 if not straight forward in a lot of its settings
Sep 01, 2014 | Computers & Internet
Smc 802.11g adapter doesnt show in wlan utility
update the wireless drivers for your network card. also check the spec sheet for your wireless card and make sure it's compatable with your OS and system.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_d799f810c7212a78
May 01, 2014 | SMC EZ Connect g SMC2862W-G 802.11g/b...
Windows 8 will not connect
windows 8 is bit tricky try deleting all existing wireless profiles and refresh the router search option now it should connect or reset the router to factory defaults and put a new wifi password or try without wifi password by removing the wifi security.
Feb 25, 2014 | D-Link AirPlus Xtreme G DI-624 Wireless...
Updated to Windows 8, printer does not work
you need to download the drivers so it will be recognized by the computer. go to lexmark support.go to downloads section,find model number and look for win8 driver..
Jun 12, 2017 | Lexmark Prevail Pro705 Wireless All-In-One...
DOESN'T DETECT WIFI
The wireless feature on a Gateway computer allows you to connect to a network without the hassle of cables. This allows you to browse the Internet conveniently wherever you are. Gateway computers rely on Windows operating systems, which come with a built-in feature to manage your wireless connection. This feature makes turning off your wireless connection an easy process if, for a moment, you prefer to connect to the Internet using a wired connection.
Click the Windows "Start" menu and click the "Control Panel." Click Network and Internet Connections > Network Connection, if you are using a Windows XP Gateway computer. You should see your wireless connection. For Windows Vista and 7 Gateway computers, click "Network and Sharing Center" from the Control Panel and click "Manage Wireless Connections." You should see your wireless connection. Right-click your wireless connection and click "Disable" to turn it off. Close "Network Connections" when you are done.
Mar 03, 2013 | Gateway ONE GZ7108 All-in-One Desktop PC
How to turn on wireless network for aspire 4250
1. On your laptop turn ON the wireless switch, it may be on the side or in front.
2. After turning ON the wireless switch the wireless light will turn ON
3. Click on "Start" and click on "Run" type "ncpa.cpl" and click "OK"
4. "Network connections" window will open
5. In "Network connection" right click on "wireless network connection" and left click on "view available wireless networks"
6. You will get a window showing all the wireless networks in range
7. Click on the wireless network you want to connect to and click "connect"
8. If it is a secured wireless network you will be prompted to enter the password or else you will be connected directly
9. If it prompts you for a password, type the password and reconfirm the same in the 2nd box and click connect.
10. After a few seconds you will be connected to the wireless network.
Sep 18, 2010 | Acer Aspire 4520-5582 Notebook
I cannot connect to the internet using wifi
1. Go to START
2. select MY COMPUTER
3. Once in the new window, click MY NETWORK PLACES under the "OTHER PLACES" section
4. select the VIEW NETWORK CONNECTIONS link under the NETWORK TASKS section
5. RIGHT CLICK on your wireless network connection and choose PROPERTIES
6. click the WIRELESS NETWORKS tab.
7. make sure the "USER WINDOWS TO CONFIGURE MY WIRELESS NETWORK SETTINGS" box is checked
8. Click OK and close the window
9. RIGHT CLICK on your wireless network connection (the name of it) and choose REPAIR
10. if windows detects the wireless connection, you should see a bubble near the task bar
11. in order to begin using the wireless connection, open your web browser then enter your username and password (if required)
Dec 01, 2008 | Computers & Internet
Zyxel Simultaneous 450Mbps Dual-Band Wireless N Media Router, P/N: NBG5715. ds-s Logo
51 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
