Question about Ricoh Office Equipment & Supplies
Savin 3030 We moved our savin 3030 to a different office. I don't have the users manual. I need to know how to change the ip addess, so we can network it for this office location???
"user tools"
"System settings"
"interface settings"
Press the "ip address" button and set.
The model cross references to a Ricoh MP C3000 (Ricoh builds all Savin machines). You can get all the manuals here:
Posted on Mar 12, 2009
How to connect this ir3300 xerox machine to computer plz tell me sir i request u
you need to have a driver installed on each P.C
You need an ethernet network of computers
You need to set up the ip addess and subnet mask in the printer via its setup menu . At the very least a ethernet network Switch with static ip addesses for each device , or A router with DHCP server to dynamically assign ip addresses.
you need an rj45 socket on the ir3300 which it should have 802.3 ethernet 10/100 tbase ethernet according to ir3300 specs if it is missing you need a network card to be added to ir3300 by Xerox / Cannon
Sep 05, 2015 | Xerox Office Equipment & Supplies
Most times this is because the computers have differing sub-net masks and/or IP addresses have differing roots. A simple solution is to set all computers to use DHCP to get their network addresses.
If you post the IP addesses and sub network fields for each machine I can be more precise.
Nov 19, 2013 | Computers & Internet
Savin c2824 wont print pdf files
If its showing drivers for a different machine then the first step should always be to completely remove and reinstall the drivers for the correct unit.
Mar 02, 2012 | Savin Office Equipment & Supplies
My computer can't see the router.
you will have to set the ip addess for the computer to see the router and the router to see the computer
log into the router from your web browser
this should open the user interface
user name - admin
password 1234 or admin
go to add new user
also add new user password
write them both down
add your computers ip address to the router
save and test
if nothing then run your network and internet wizard to give you access
need more help let me know your operating system and model and make of your computer
Thanks Misterdj
Apr 25, 2010 | D-Link Xtreme N DIR-655 Wireless Router
I have a Savin 8045e connected with USB and can't scan
its needs to be connected via network to scan and not usb i believe
Apr 12, 2010 | Savin 8035e Copier
Mac os dual network config on the wireless nic
Go to system preferences then to network on the network configuration that is working go to location and then click and scroll down to edit locations click on the gear wheel icon and rename the location to e.g. home or work. Then apply
Then at the bottom left hand corner click on the plus sign and then setup say your wireless network (or as apple calls it airport and once this is done rename that location to what you prefer.
Hope this helps
Dec 12, 2009 | Apple Mac OS X 10.4
Trouble mapping Savin to network folder on computer
you will need to have the folder shared on the desktop. you will need user name and password. go to user tools. system settings. administrator. address book. create new user. in new user program, go to folder. enter computer name. browse network. you then enter user name and password for pc. should be done
Oct 21, 2009 | Savin Office Equipment & Supplies
How to network a Canon Imagerrunner 3030 copier
Set the Ip address on the copier to match your network's Ip - only use different last 3 digits (3 digits that aren't currently in use on your network. Set the Subnet to the same as your network's Subnet. Set gateway to your Router's IP address.
Then install printer driver on your server, or all individual PC's if you are not using a server . When prompted select "create new port", then select Tcp/Ip port from the drop down menu, then type in the Ip you set on your copier, and continue to follow prompts.
If you are using a server, then you should select "share this printer" when prompted, and after installation is complete, go to each PC, and go to the "add printer wizard, and select network printer, then select "browse" to find it on the network, and select it.
that's it.
good luck!
Jul 21, 2009 | Office Equipment & Supplies
Ricoh 2035/Savin 4045
what kind of op. systems are you running on your computer. Besides the IP address is the gateway and the subnet mask right?
Dec 09, 2008 | Office Equipment & Supplies
Need to reset savin 3740 fax to factory defaults
Found documentation of Ricoh's website. They are the manufacturor of Savin products. The default access code is 2222. Entering this allowed me to get into the network settings and change the IP scheme.
Jul 25, 2008 | Office Equipment & Supplies
245 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
