Question about HP Photosmart C5180 All-In-One InkJet Printer
Photosmart c5180 screen and scanner not working
Moved to new location. despite efforts to keep unit safe from being jarred, when reconnected to the computer in the new location, neither the onboard screen or the scanner would work. Printer worked until it ran out of paper, then would not register that paper had been replaced until unit was disconnected from power source, then reconnected. photosmart c5180 screen and scanner still not working Is there a reset? where can I get unit repaired. I was talked into purchasing unit from HP rep in store (Best Buy), now it goes belly up just after the warranty is up (of course). I am a graphic artist and need the unit as soon as possible for my job.
MerlinTech
  • 197 Answers
SOURCE: HP Photosmart Printer 3310 offline/can't configure
sure..it's possible...and it's an automatic when installed..follow the installation disk instructions
Posted on Jun 18, 2008
rockfixya
  • 679 Answers
SOURCE: Ink System Failure HP C5180
IssueAn 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
Press the On button to turn the printer off.
Unplug the power cord from the back of the printer.
Remove all the ink cartridges.
Wait two minutes.
Plug the power cord into the back of the printer.
Press the On button to turn the printer on.
Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved.
If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Posted on Feb 03, 2009
SOURCE: My HP Photosmart C5180 Keeps displaying an "out of Paper"
The printer shut itself down. I turned it back on and it has worked since. thanks
Posted on Jun 04, 2009
SOURCE: hp c5180 printer: While printing a job, the
switch off the power, press and hold the ok and help buttons then restore power this will do a reset on the printer and cure this problem
Posted on Jul 12, 2009
princegh158
  • 56 Answers
SOURCE: on HP Photosmart C5180 Error Message 0xc18a0201
call hp total care 1800 4746836
u knw i cn tell u the steps but if u do even 1 of the steps wrong ,ur printer wont work anymre so contact them
...hp technicians will be able to take care of u
thanhks
Posted on Aug 08, 2009
The printer doesn't switch on anymore
Most likely dead. Also FYI 99.9% of inkjet printers are not economical to repair. Just replace them.
Jan 09, 2012 | HP Photosmart C5180 All-In-One InkJet...
Hp photosmart c5180 erreur oxc18a0001
hi
That may be, so try thie you have nothing to lose.
Try updating your printer drivers:
Create a new folder on your desktop and name it newhpdrivers(substitute your manufacturer in new name). Un-intall printer and printer software completely. Go to manufacturers website and navigate to their drivers/downloads or support menu. Select your model, choose the relevant software and download to the new folder you created on your desktop. Power down your computer. Reconnect the printer to the computer and turn printer on. Windows will detect new hardware and ask if you have the manufacturers install cd or a location to check for install files. Direct the wizard to your new software, follow the rest of the setup instructions and your done
Jan 09, 2011 | HP Office Equipment & Supplies
My HP C5180 all-in-one printer/scanner used to
try to off and on the hp photosmart let scan if not work re-install driver. let me know if still not work for further trouble shooting.
Apr 10, 2010 | HP Photosmart C5180 All-In-One InkJet...
HP C5180 photosmart keep turning off and on. Will
This is due to ON/OFF switch is having the issue. Repair/replace the switch with the help of expert engineer/service center experts will resolve your problem.
Revert back for more assistance.
Jan 29, 2010 | HP Photosmart C5180 All-In-One InkJet...
My Inspiron 531 has vista os. recently, i had to
You would need to download the software for your printer again and then install it on your computer. You can download it from here. Once it is installed, look for the scanner icon or HP Director which would have scanner icon.
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=2093&lc=en&dlc=en&cc=us&product=1153481
Download the first link from the list.
Nov 18, 2009 | HP Photosmart C5180 All-In-One InkJet...
Just installed my HP photosmart C5180 all in one, I connected threw a USB I have uninstalled then reinstalled. Same problem scanner and copier does not work. there is a screen that said there is a DDE...
I would search for latest drivers for the photosmart and download them. Than turn on machine before connecting to computer.
Also you should go to control panel, printers, and see if your machine is listed there and set as default printing device.
Jun 05, 2009 | HP Photosmart C5180 All-In-One InkJet...
Scan to computer not working
Google, enter "HP Photosmart C5180 All-in-One" and you can reinstall the scanner into computer...free.  Under the black apple in the upper corner of screen find "recent Items" and you will find the Photosmart Studio where the scanner icon is used to scan and create a file in thecomputer.
Mar 26, 2009 | HP Photosmart C5180 All-In-One InkJet...
HP Photosmart C5180 - Ink System Failure. Error Oxc18a0306
Try updating your drivers first:
Create a new folder on your desktop and name it newhpdrivers. Un-intall printer and printer software completely. Go to manufacturers website and navigate to their drivers/downloads or support menu. Select your model, choose the relevant software and download to the new folder you created on your desktop. Power down your computer. Reconnect the printer to the computer and turn printer on. Windows will detect new hardware and ask if you have the manufacturers install cd or a location to check for install files. Direct the wizard to your new software, follow the rest of the setup instructions and your done
anaanymous
Oct 07, 2008 | HP Photosmart C5180 All-In-One InkJet...
HP Photosmart C5180 All-In-One InkJet Printer Logo
60 people viewed this question
Seeker5211
Seeker5211
