Question about ViewSonic E70b 17" CRT Monitor
MEMORY RECALL OK? problem mine is view sonic monitor .from the past one month its showing problems in display.its giving "MEMORY RECALL OK?" and this whether i press any of the two buttons asked for ,is appearing very frequently.this is continuing for some hours and then itself vanishing. Till then i m unable to do my work on the sys...as i m find it in d middle...
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 135 Answers
From the Users Manual for this monitor: "Memory Recall returns the adjustments back to factory settings if the display is operating in a factory Preset Timing Mode listed in the Specifications of this manual. - Exception: This control does not affect changes made with the User Color control, Language Select or Power Lock setting." When the monitor is asking "Memory Recall OK?" it either wants to initiate a settings Recall, or it's asking if the Recall was successful. In either case, the "Memory Recall OK?" message is supposed to go away when you push either button 1 or button 2. If it does this when you are adjusting settings then it's likely just doing what you told it to, even if you don't realize you told it to do that. It's also possible for one of the settings buttons to be stuck down and this is causing it to try and change the Recall settings. Push each of the buttons on the monitor and pay attention to what each one feels like as you push on it. If one of them feels different from the others, it's likely stuck. Tapping lightly on the settings buttons or on the panel beside them will usually free up a stuck button. If a button is stuck and won't loosen up by tapping beside it, you might need to pry up on the edges of the button VERY gently with the sharp tip of a pointy kitchen knife. If it's doing this when you did not touch any of the settings buttons at all, then this is likely being caused by a dendrite whisker or faulty circuit trace inside the monitor and you'll need to take the monitor to a service technician for repair. But remember to contact Viewsonic first and go to whatever Service Center that they advise, since a repair of this type may be covered under warranty. One other thing you could try before spending money on it is simply to change the Timing mode in the Windows display settings. Go to "Control Panel > Display", then select the "Settings" tab and click the "Advanced" button. Select the "Monitor" tab and change the screen timing to a different Hertz value in the "Screen refresh rate" menu box. Don't forget to save these settings by clicking "Apply" and "OK" to close all of the Windows settings windows. Hope that helps solve your problem...
Posted on Aug 03, 2007
SOURCE:
Plz i have msg in my screen view sonic e70f 17 tell me memory recall ok ? plz tell me ansewr for this proplem ty
throw ur system in top floor to ground floor buy new one it sure il work
Thanks & Regards
sasi
Mar 17, 2011 | ViewSonic E70f 17" CRT Monitor
My view sonic VA712 monitor doesn't display any picture even after power supply light shows green.
Hello Dear I also have the same problem and finaly I found its power adopter faulty which gives the same voltage as mentioned above it but on load they dropped to 17 volts instead 19. I used another supply and the monitor works normaly.so try this
Dec 19, 2010 | ViewSonic VA712 17" LCD Monitor
View sonic -E70fB monitor displaying H.V frequency out of range when ever i play a game on the monitor screen it is displaying h.v frequency out of range....how to solve this problem
view sonic -E70fB monitor displaying H.V frequency out of range
Jun 06, 2009 | ViewSonic G70F 17'' Monitor + Wyse Winterm...
Some green color patch in the middle of the screen
Looks like you have an LCD. I was guessing it may be magnetic related in which case I would recommend you degaussed your display using the degauss function but your monitor won't have it since it's not a CRT by the looks of it. I would recommend contacting your dealer or where you purchased the monitor at a retail store. Since it's only 8 months old, you may be able to return it under warranty. If your retail store doesn't let you do that, talk to View Sonic directly and see if you can RMA your product for returning to the manufacturer and receiving a new or repaired unit.
Check out Viewsonic's website for more information.
Mar 24, 2009 | ViewSonic VX922 19" Monitor Flat Panel
'memory recall ok' displayed always on the screen. Does not go even if selected yes or no. Why?
I got the problem solved. The other day i called up the viewsonic tech support, service engineer visited and changed the switches inside. the problem got solved. So call up the tech support of view sonic at (india)
We need the following details to create an RMA Request for your Product.
Once an RMA request is created our service Engineer will contact you within 2 Business Days to attend the call.
1.Customer Name
2.Phone no with STD code
3.Complete Address
4.Model and Serial No of Product
5.Description of problem
We can be reached on this email address or through phone on our Toll free No1800-11-9999 or Toll No:-011-26990006
Have a Great Day Ahead.
Thanks & Regards
ViewSonic India Technical Support
bye
Nov 04, 2007 | ViewSonic G90fb 19" CRT Monitor
Moniter problem
Sep 16, 2007 | Computers & Internet
or you have a "crazy" micro or have a stucked push-button (or two) , first I try is change them or at least disconnect it to see what happen.
Jul 11, 2007 | ViewSonic E70b 17" CRT Monitor
Memory recall
Oct 31, 2006 | ViewSonic E70 17" CRT Monitor
Memory recall
Oct 30, 2006 | ViewSonic E70b 17" CRT Monitor
Open Questions:
See all ViewSonic E70b 17" CRT Monitor Questions
ViewSonic E70b 17" CRT Monitor Logo
812 people viewed this question
Top ViewSonic Computers & Internet Experts
Steve Allison
Steve Allison
Ekse
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
