Question about Kenmore Washing Machines
On the kenmore 80 series washer model #110.27822790, where are the agitator dogs and what do they look like?
Previously asked about washer stopped spinning after draining,but still had to wring out pair of pants. Huge noise and now washer won't start. was told it could be agitator dogs or transmission. i wanted to check agitator dogs first but don't know what and where i am looking for.
Maytag317
  • 1136 Answers
SOURCE: replacing the agitator dogs in a Kenmore 80 series washer
Hi, Remove the cap on the agitator and then remove the inside cover. There is a 7/16" bolt under the inside cover. Remove the bolt and the agitator will lift out. Seperate the 2 pieces of the agitator and replace the dogs. You might have to use a flat blade screw drive and punch out the 4 tabs around the bolt hole in the agitator if this applies.
I hope this helps you. Please let me know if I can assist you further.
Vic
Posted on Jul 03, 2009
SOURCE: Kenmore 80 series won't spin
If it agitates and drains. leaving your clothes clean but soaking wet. It is most likely the transmission/gearbox. the motor is working otherwise it would not agitate. it is stuck in agitate mode and cannot "shift" into spin mode. new transmission will cost 140-170 and takes 2 or so hours to replace depending on skill level. total repair cost parts+labor $300ish you may want to ante up for a new machine at this point. if you cant to the labor yourself.
part# should be this: tho double check using your own model#
Part # AP3096209
Posted on Dec 09, 2008
  • 6277 Answers
SOURCE: my kenmore washer 80 series
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jun 24, 2011
  • 643 Answers
SOURCE: I have a top loading Kenmore series 80 washer.
This is usually a door closed switch that is either a bad Lid switch It is number 11 on the diagram on this page http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11024032301/0582/0153200/K0403014/00001?blt=06&prst=&shdMod=
Hope this answers all your questions
Please remember to Rate/vote for any solution that helps you out.
Leave a comment if you need more help.
Thanks for using Fixya.
Posted on Aug 12, 2011
TheMobilian
  • 8220 Answers
SOURCE: Kenmore Series 70 Model # 110.82873120 washer quit working druring a wash. It won't drain, spin or agitate and makes a slight buzzing noise. I have checked the coupler and it appears to be fine. A
Look for a blown capacitor if the other components are all fine.
Posted on Jul 10, 2012
What part # for agitator dogs?
The parts number you seek is 80040 they should run about 5 bucks or so.
Good luck
Nov 20, 2015 | Kenmore Washing Machines
I have kenmore 80 series heavy duty/ super capacity plus washer that after it fills with water,hot or cold and it starts the wash cycle, I noticed that the agitator only moves once in awhile and stops
hum either a bad timer sticking the point contacts close. have u tried this in all cycles? and possibly a motor with bad windings not enough power to run agitation? try running in mild or gentle and see what happens? I was tempted to say the cam dogs in agitator but they dont work then stop then work, when they go out they go out.
Feb 17, 2015 | Kenmore Washing Machines
Kenmore 80 series washer agitates minimally but when you push down on agitator slightly it agitates more and is now having trouble starting to spin tub is it a belt issue?
Check out: http://www.appliance411.com/faq/agitator-dogs.shtml You can buy parts here: http://kenmore80serieswasher.com/whirlpool-kenmore-washer-agitator-cam-kit-285809/
Jun 25, 2011 | Kenmore Washing Machines
Kenmore Series 80 washer. Agitates too slow
check the dogs in the agitator take off the cap it should rachett if it turns free replace the dogs in the agitator
Jul 12, 2010 | Kenmore 24032\24036 Top Load Washer
80-series w/ broken top agitator
There is a video at www.appliancehelponline.com/servicemanual.html that will walk you thru the replacement of the agitator dogs, this is a common problem with this style washer.
Mar 28, 2010 | Kenmore Washing Machines
Agitator not spinning
agitartor stripped
you can order the dogs at sears
agitator dogs
Oct 04, 2009 | Washing Machines
Kenmore 80 series washer fills but does not wash/agitate. will spin and drain when manually turning dial to spin
The agitator dogs may be broken or the transmission could be bad. Try checking the agitator dogs first. They are an easy and inexpensive fix.
Aug 31, 2009 | Kenmore Washing Machines
Replacing the agitator dogs in a Kenmore 80 series washer
Vic
Jul 03, 2009 | Washing Machines
Kenmore series 80 washer: does not twist in the middle
Check the agitator by turning it back and forth. It should work like a ratchet (turns one way, locks the other way).If you're able to turn it in both directions, the agitator dogs are worn and need to be replaced.
Remove the agitator cap and the bolt that holds down the agitator. With the bolt out you can remove the top section of the agitator (auger) where you should see 4 small white or beige plastic gears (dogs). Replace those and it should be ok.
Part number is 80040
Let me know if you need more help.
Apr 01, 2009 | Kenmore Washing Machines
Kenmore series 80 model 1102983120 older top agitator gone
if just the dogs are gone you can replace them wim any agitaor dog kit. I usually use whatever kit was cheaper when i order abd put just the dogs on. never had a problem yet.
Jan 26, 2009 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
119 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
