Konica 7130 Conveyance Door
Hi -
We knocked off the conveyance door of our Konica 7130 copier and have been unable to reattach it. Can you offer any suggestions? Thanks.
Rob Huffman
  • sam gerban
    sam gerban May 11, 2010
    how about a picture..if you could scan it
  • Office Equip... Master
  • 6,359 Answers
Contact a Local Konicaminolta dealer order part
Posted on Aug 02, 2009
Bizhub 951how to remove code c-0104
Dear Noorul,
Your question seems to be related to a copier. It is categorized under tv & video. I hope this is the information you are looking for:
Code
C-0104
Description
Abnormality of the vertical conveyance motor (M8) power in the printer control board (PRCB). An error detection signal (blowout of ICP) of M8 is detected when M8 is turned ON.
Causes
• Vertical conveyance motor (M8) • Printer control board (PRCB)
Konica Minolta bizhub Pro 951 Error Codes
Sounds like you have some replacement of parts that are needed. Let me know if you need a service manual. I will look for that.
Blessings!
Jul 05, 2017 | Televison & Video
Where is the fns conveyance door on a konica 7020
Open the finisher should be to you up & right it would be where the paper comes out of the copier and into the finisher between both units is the conveyance
Jul 22, 2014 | Konica Minolta Office Equipment & Supplies
Help "Closing" Conveyance Door
Their is a switch letting it know that it is not closed.
find the switch and either adjust it so it closed the contacts ,when the
door is closed,. or temporarily jump it out to confirm that it is the switch. Sometimes switches can be shimmed up with tape etc.
Jun 03, 2014 | Konica Minolta Konica 7020 W/fax Kit...
Konica Minolta DF314
A document feeder what about it?????
Apr 28, 2014 | Konica Minolta DF314 ADF Middle Conveyance...
My knocia 7222 is always jamming it says open right side cover release lever 1 and remover paper open conveyance cover 6 fix guide 5 during depress fix guide 9 remove paper the paper always get stuck by no...
close right side cover is showing on the screen display but door is closed i have already replaced the door switch and power supply board and main mother board and tray control board.kindly advise what can i do to remove (close right side cover) sin?
Tariq E-Tech E-Mail : e_tech_pk @hotmail.com
cell : 03455235670.
Mar 15, 2013 | Konica Minolta Minolta 7222 Laser Printer...
Please close FNS conveyance door
Aug 31, 2009 | Office Equipment & Supplies
Paper jam
I strongly recommend a service tech. It sounds like you will need a PM kit,fuser claws and a few DFP rollers.
Mar 21, 2009 | Konica Minolta DiALTA Di200 Copier
Konica 7020
F26-1 at power up. [Description] F26-1 at power up.
[Solution]
PROBABLE CAUSES:
1. The TDS (Toner Density Sensor), in the developing unit, has detected a depletion of toner.
Note: This may have been caused by the customer making an excessive amount of copies while the machine was out of toner. It may also be caused by a bound toner addition system.
Clean all toner from the toner recycle and toner supply assemblies. Confirm that the gear mesh between the toner supply auger drive gear and toner supply motor (M4) is flush. If toner supply conveyance is normal and the toner cavity is empty, install a new toner cartridge (Item #950236) and then perform the following diagnostic mode to replenish the developing unit with toner:
a. Access the 47 mode (power the copier ON while pressing the 4 and 7 keys).
b. Enter output code 54.
c. Press the START button.
Note: Toner will now be added to the developing unit and stop automatically when target level is reached, although it will not run any longer than 3 minutes.
d. Power copier OFF/ON to return to normal copy mode.
Note: Perform the following 25 mode software switch settings to minimize the amount of copies that can be made, prior to copy inhibit, when the ADD TONER message is displayed:
- Access the 25 mode (hold down the 2 and 5 keys at power ON).
- Select [1] (SOFTWARE SW).
- Using the up and down arrows, scroll to the following software switches and set them as follows:
a. 4-0 set to 0
b. 4-1 set to 0
c. 4-2 set to 0
d. 4-3 set to 0
- Power OFF/ON to return to normal copy mode.
Notes:
A. These setting will allow the ADD TONER message to be displayed immediately and only allow 100 copies to be thereafter.
B. Copier inhibit will automatically be released when a new toner cartridge is installed.
2. The toner conveyance gear is worn. The toner conveyance gear is driven by the toner supply motor located on the toner supply unit.
Replace the toner conveyance gear (p/n 26NA32680).
I may be able to get the manuals for a nominal charge. bkbell@brianbell.net
Nov 20, 2007 | Konica Minolta DiALTA Di200 Copier
154 people viewed this question
jasbo
jasbo
