Question about Antennacraft TDP2 TV/FM TV Antenna Rotator TDP-2
Rotor will not turn.
Controller box works but antenna does not turn
I have a Magnavox tv.. and I brought a ematic AT 103B converter box.. I can only get 11-1 and 11-2 and 11-3, I did a channel search.. and still can not get other channel's.. Katrina
Usually this means that you need a different antenna or to move your antenna. If you are using an indoor antenna, you may need an external antenna. Make sure that the antenna is pointing to the transmitters. If you have an amplifier on the antenna, it may be damaged and could be blocking some frequencies. In that case, you may need to replace the antenna or the amplifier. In some places, surrounding objects can block the signal; trees and buildings are the frequent problems.
Please use http://www.tvfool.com to check where the local stations transmitters are located and the recommended antenna to receive each station. ( http://www.antennaweb.org is a similar resource but usually is too conservative in the list of available stations.)
I hope this helps.
(In my case, I point a large external antenna towards the local stations farthest away. This lets me receive those stations and the ones from closer transmitters. If the antenna rotates, I lose some local stations but may gain access to stations that are outside my area. Then I have to climb up and turn the antenna. I tried an antenna rotor but it eventually burned out.)
Dec 09, 2015 | Televison & Video
Why will my digital antenna not rotate using either the remote or manual button?
If the motor has not been turned for a long time the grease on the gears may dry out and freeze the motor.
Mar 19, 2015 | Lava HD-2605 Ultra with G3 Control Box...
I have a BUH 49inch TV, 2 weeks old..Ive retuned it numerous times, but still unable to ge channel 3(ITV) as a perfect channel..Keep getting interference onit.
You must locate any source of interference, including any within your house . . . such as electronic appliances and computers. But tuning relates to reception and not to interference; and the TV that is immune to broadcast directionality has not been invented. You might want to try a higher, exterior antenna with directionality rotor and inside controller. First try to find out whether all Transmission antennas are colocated in you region as typically required by regulation. If not then its probable that your antenna is miss-pointed for the "degraded signal." Or some other means to rotate in inside antenna.
Mar 14, 2015 | Televison & Video
First seventh lights flashing
130. (10000010) Phase 1 to 6 Single Rotor Position Sensor Error
The Motor Controller has found an error in the pattern received from the Rotor
Position Sensor. Likely causes of this fault are a bad connection on the harness
between the Rotor Position Sensor and the Motor Controller, or a faulty Rotor
Position Sensor.
Primary Source: Wiring.
Action:
1) Check for corrosion on the edge connector of the Rotor Position Sensor and
the Motor Controller module connector.
2) Check the contacts on the rotor positional sensor end of the hall harness to
see if any have been damaged. (Each set of contacts in the socket has two
wipers. If the distance between these wipers varies between different
contacts, replace the rotor positional sensor harness).
Secondary Source: Rotor Position Sensor.
Action:
Check the Rotor Position Sensor with an R.P.S. tester. Replace if faulty.
Tertiary Source: Motor Controller module.
Action:
Replace Motor Controller module.
Aug 22, 2013 | Fisher and Paykel Washing Machines
Mw612 not working
It looks like Error Code 130,
The Motor Controller has found an error in the pattern received from the Rotor Position Sensor.
or a faulty Rotor Position Sensor.
Action:
Action:
Replace if faulty.
Action: Replace Motor Controller module.
Jun 12, 2013 | Fisher and Paykel GWL11 Top Load Washer
Antenna remote not working
If its outside the rotor or the connections somewhere, The TV listed does not have its own antenna, more information is needed in order to help you.
Dec 10, 2012 | Mitsubishi WD-62528 62" LCD HDTV
The 1st and 7th light are on and beeping, does anyone know what this means?
(10000010) Phase 1 to 6 Single Rotor Position Sensor ErrorThe Motor Controller has found an error in the pattern received from the RotorPosition Sensor. Likely causes of this fault are a bad connection on the harnessbetween the Rotor Position Sensor and the Motor Controller, or a faulty RotorPosition Sensor.Primary Source: Wiring.Action:1) Check for corrosion on the edge connector of the Rotor Position Sensor andthe Motor Controller module connector.2) Check the contacts on the rotor positional sensor end of the hall harness tosee if any have been damaged. (Each set of contacts in the socket has twowipers. If the distance between these wipers varies between differentcontacts, replace the rotor positional sensor harness).Secondary Source: Rotor Position Sensor.Action:Check the Rotor Position Sensor with an R.P.S. tester. Replace if faulty.Tertiary Source: Motor Controller module.Action:Replace Motor Controller module.
Oct 18, 2011 | Fisher and Paykel GWL11 Top Load Washer
Cant get jvc car stereo to work a sony cd changer
Does your sony cd changer have a separate controller and rf modulator interface? It's a wire from the cd changer with a little box close to the end and an antenna plug at the tip? If you do just plug it into the back of your radio where the antenna goes in, then plug the car antenna jack into the other side of the little box and turn your radio to the marked setting on the box. IF NOT , you can not interface the din plug from a sony into a jvc radio because the sony radio that has a md controller built in will control all of the functions of the matching cd change.
I hope this helps...
Oct 15, 2008 | JVC Car Audio & Video
Antennacraft TDP2 TV/FM TV Antenna Rotator TDP-2 Logo
87 people viewed this question
Top Antennacraft Electronics - Others Experts
Are you an Antennacraft Electronics - Other Expert? Answer questions, earn points and help others
