Question about Ricoh Aficio 450 Copier
Black smudge marks on our prints.
We seem to be having a problem with the our print outs. Everytime we print off something the page comes out with black smudgemarks on. I am aware that this has something to do with thr toner but am not sure what exactly. we recently changed the toner.Does it just need a clean? if so, where and how do we do that?
If you are using a generic brand of toner, this could be the problem, and if so, your developer is shot, and the drum unit will need a thorough service.
Otherwise, it is very likely that the Drum (PCU) needs replacing, or fuser is failing.
Whatever the cause, it requires a technician.
Posted on Mar 12, 2009
1) The first problem is the paper jam. first page go through but creased and slant badly. second copy stuck at the roller. Try many time. at first i suspect is the feeder, but is not.
2) Always on the end paper of one side is smeared with toner. I use the blue plastic which is inside the machine to pull out and in to clean as these was told by the previous techinician. it works on one copy but not the rest.
Posted on Apr 20, 2009
How do I fix my Samsung Multi-function laser printer which has started to print smudged pages.
try to stop the sheet just before it enters the fuser and see if the marks are on the paper already. if not then it has to be the fuser if they are them you have another issue.
Jan 15, 2015 | Samsung CLX-3175FN Color Laser All-in-One...
I'm getting black smudge marks on copies. After
I also had this issue, waste tone was comming from the transfer belt, had a good clean out been good for months now.
Aug 11, 2009 | Samsung CLP 300 Laser Printer
Black lines or smudge marks\running down the prints
Hello sir;The streak line from printing also should be from copy, because the line come from imaging unit, check the meter count if close to or over 50,000 then replace drum and drum blade, it will take care the problem.
The brother printer you need to replace imaging unit( drum unit).
Jun 01, 2009 | Brother Office Equipment & Supplies
Poor quality smudge and ink blotting marks in the centre of any printed document
Try performing a test by printing a test page from Tray 1 and open the top cover as soon as the paper is 60% inside. The paper would jam below the toner cartridge before it reaches the fuser. Remove the toner cartridge carefully and verify if the smudges occur. This would eliminate the fuser. If the print quality is fine, then you need to swap the fuser.
Oct 30, 2008 | HP LaserJet 4250n Printer
Black ink smudges for color print mode only, not for grayscale
- Try to reallign the cartridge, run a print test, after that if the issue still persist - uninstall and reinstall software - run test and re-allign again the cardtridge using software. run print test again.
Oct 08, 2008 | Samsung CLP 300 Laser Printer
Printing Black Smudges
You could print a few more out and see if it goes away.
Check the drum and see if there are any black marks on it. If there is, it could be a scratched drum or the cleaning blade isn't working in it anymore.
Is this a new toner cartridge?
Be careful when you look at the drum at it to keep the light out of it as much as possible.
Where did it jam at?
Jun 13, 2008 | Samsung CLX-3160 All-In-One Laser Printer
Smudge marks on paper; otherwise normal
fuser is usually replaced as a assembly, it's the hot bit a back.
Can only be two things the drum or the fuser as our headstrong friend has correctly explained.
More than likely it is the drum they last about 4 toners i think.
Learn the art of getting a page to stop halfway threw printing, you want to stop the page after the drum has put a image on the paper but before paper has gone threw the fuser (hotbit).
Once you have mastered the position correctly by stopping the printing by opening the door and removing drum/toner cartridge, to reveal the paper that is printed but can be rubbed off, we will know if marks are coming from the drum (you will see them) or from the fuser, if print is fine
Jan 07, 2008 | Brother HL-2040 Laser Printer
OKI C5250 Printer
My informed guess without seeing print sample is that your oki needs fuser unit replaced. Look at orange rollers should br smooth no wrinkles.
Dec 20, 2007 | OKI C5200n Laser Printer
Black smudge streaks on rightside of printed/copied material
Can only be two things the drum or the fuser. More than likely drum they last about 4 toners i think.
Once you have mastered the position correctly by stopping the printing by opening the door and removing drum/toner cartridge, to reveal the paper that is printed but can be rubbed off, we will know if marks are coming from the drum (you will see them) or from the fuser, if print is fine.
Dec 17, 2007 | Brother MFC 7420 All-In-One Laser Printer
Ricoh Aficio 450 Copier Logo
264 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Bernard D'Souza
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
