Question about Sewing Machines
Sewing a buttonhole with a Bernina 1030 - Sewing Machines
  • 4 Answers
SOURCE: buttonhole lever
If you remove the cover on the upper left portion of the machine, while looking from the left to the right.....Above the BH lever area, you will see a round cam with a post through the middle. Rotate the round can ( with fingers on it), and try again. This will change the angle position on the lever, and hopefully correct your problem. You may have to go a couple of clicks in either direction.
Posted on Nov 26, 2007
PABLOCSA
  • 1124 Answers
SOURCE: Trying to sew a buttonhole
You can get all the info of alignments and features of your machine here:
Manual of your machine:
http://www.sewingmanuals.net/bernina-910-sewing-machine-service-man.html
https://www.sew4less.com/product/140/Bernina_910_Instruction_Manual
http://sewingwishlist.com/bernina.html
This information is available online but not for free.
Thank you for using FIXYA!
Dont forget to rate my help!
Have a great day!
Pablo :-)
Posted on Oct 18, 2008
SOURCE: machine will not complete a buttonhole, keeps showing error code 6L. No error code listed in manual. Machine will only do first half of buttonhole and then shows code and stops.
I've been looking too and I found here http://sewing.patternreview.com/cgi-bin/sewingclasses/board.pl?t=18328that you need to put the bar behind the needle threader down. I think they call it a button hole stop? I don't know, but it worked. I didn't even know it existed. But it solved my problem. On my Kenmore it looks like a black lever and you pull it down. It tells the button-holer that you are at the end of the hole and it needs to backup. nifty, kind of.
Posted on May 27, 2009
  • 8 Answers
SOURCE: buttonhole problem
When doing the button hole....after installing the button hole foot and lowering the foot....and adding the button so the automatic button hole size is determined...you lower the button hole lever it will touch the back of the button hole foot. this holds the button hole foot in the proper position...if this lever is not all the way down...the machine blips at you...check to see that it is down all the way...I hope this helps you..It truly does all that it advertises and is a great machine...BBill01
P.S. you can adjust width and length of the stich also...see instruction manual. pg 28-30
Posted on May 30, 2009
Zenqi
  • 208 Answers
SOURCE: I have a Bernina Sewing Machine with a Control Board that smoked
Bernina does not sell individual components for PCBs, rather they have an exchange program for the entire board. But you have nothing to lose and much money to save if you can obtain the parts and replace them yourself. You should be able to get the caps and resistors from any electronics supply.
Posted on Oct 01, 2009
Testimonial: "Terrific- that sorted that out as I could not easily find Bernina Service. I will go and buy the bits."
How to sew buttonholes
Do you have a manual? If not, here is one that may help:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=8&ved=0CFYQFjAHahUKEwjt_Pq0sZDJAhUCV4gKHWIiDSc&url=http%3A%2F%2Fwww.itsastitchonline.com%2Fmastery_on_the_web%2Fmastery_153qe_163_1-4-02.pdf&usg=AFQjCNHHww3jbxbLXZYNj6vuCZE4-kVa8g&bvm=bv.107467506,d.cGU&cad=rja
However, it appears from some user reviews that this model seemed to have some issues with the buttonhole:
http://sewing.patternreview.com/SewingDiscussions/topic/45400/1
Nov 14, 2015 | Bernina Virtuosa 160
How do I make a new buttonhole on my 1260? B
Hi Karen,
Sew two parallel lines of overlock stitches very close together. Then see overlock stitches accros the ends of the first lot of stitches to close them off. Finally, carefully cut the fabric between the first set of stitches. Try this out several times on some scrap fabric. You'll need to get the spacings sorted out.
Jul 19, 2015 | Sewing Machines
Which old Singer buttonholer fits the Bernina 807?
the bernina should have that built in as an automatic thing
Apr 27, 2015 | Bernina Sewing Machines
Bernina Bernett 55 is stuck in reverse
make sure it's not in the buttonhole setting, and if the machine
isn't in the buttonhole setting and the buttonhole lever isn't down
then it would be a good idea to have the machine checked to see
why the machine ins stuck in reverse.
Dec 13, 2012 | Bernina BERNETTE 65 Mechanical Sewing...
Bernina Buttonhole foot #3A
Difficult to say whether your current foot can be repaired or even if a new foot is the answer. I believe the auto buttonhole needs to be calibrated to the machine, but not sure that is the issue with your machine.
You can sew a buttonhole without using a buttonhole foot--not really difficult as that's how it was done for many years before the manufacturers developed the specialty foot. (My machine came with a buttonhole foot but I still make mine the old-fashioned way because I determine how they will look rather than the machine making that choice for me.)
Practice a few times on scrap fabric and write down the stitch widths & lengths that work the best for you so you can replicate each stitch to look alike.
How to make button hole
l Until Wednesday Calls How To Manual Machine Buttonholes
Manual Buttonhole Settings
How to sew buttonhole with an old machine
How to Sew Button hole tutorial (this is my least favorite method)
Sew Buttonhole without Buttonhole Foot by Create Kids Couture
(also don't care for this type--don't like the look when the fabric is rotated and stitched across the end of the buttonhole--the bartacks on the other buttonholes is much more professional)
Sewing Buttonholes Without Buttonhole Foot
Buttonholes without using special feet or cams YouTube
How to Sew Buttonholes with Regular Foot Sewing Tutorial with Alison Smith (this creates a much more professional looking buttonhole)
Apr 16, 2017 | Bernina Sewing Machines
Hi, you must have an 1130S which means it could also be a circuitboard issue. If the LED/LCD light for the buttonholer does not flash you either need a new RET-Print (circuitboard) or a new buttonhole foot. Sorry to say that you DO more than likely need a new buttonhole foot according to my manual on this machine. No way to repair the foot that I know of.
You should bring the machine in and try it first.
Guess not all news is good news. Sorry.
Rick (Bernina tech)
Aug 18, 2008 | Bernina Virtuosa 160
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
