Question about Samsung 25.5 Cu. Ft. Side-by-Side Refrigerator with Bottom-Mount Freezer - Black
Compressor is not running, poping sound when electricity supplied
Compressor is not running, poping sound when plug in cord, part of a letter flashing on door control panel
Samsung model RS2556SH
serial no. 954243CX501340 N
  • wclan Mar 12, 2009
    Thanks.....I reset the control board {hold top 2 buttons in for 10 seconds} that stoped the poping noise....now after doing some
    research I could have a problem with the condenser coil icing up.
  • wclan Mar 13, 2009
    yes the problem is the evaporator coil icing up, will try replacing
    the defrost element and thermostat...
  • 400 Answers
The popping sound could be a direct short circuit, in which case you need to try to see where exactly the sound is coming from. You should then be able to correct it. Second thing is that it is possibly a bad starter relay and can easily be replaced. ratemeplease
Posted on Mar 12, 2009
  • Shane Seaman Mar 13, 2009
    You mean the evaporator coil (inside) condenser coil is on the outside at the back. You can do a forced defrost or manual defrost and if it freezes up within a week or even couple of days, you should check out the defrost system. Including the pc board and the defrost element and defrost thermostat.
I was burning a movie and my computer flash off than on than shut off.. it spelled like electrical wire burning. now it will not even turn on
Sounds like the power supply died. This is where your power cord plugs into the pc. It is a metal box inside the pc. Smell the back of the pc, at the fan opening closest to the power cord. If it smells burnt there, then you need a new power supply.
Hope this helps!
Joe
Apr 08, 2012 | Sony Computers & Internet
While watching my LG 55LW5600 this morning, loud popping sounds came from the TV followed by heavy smoke. What happened?
The tv power supply board,have blown capacitors components parts most likely.Don't tries to repair this power supply board though,because a loud poping sounds and heavy smoking have many more other components dies also just not easy to be seen as capacitors parts.The tv power supply board that the board,where the tv power a/c cord plug into it.Take the tv aparts.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish power supply board for the replacement.
Jun 13, 2011 | LG 55 55LW5600 3D LCD TV
I have a compressor that is wired for 220v however I only have 110v receptacles in my garage. This is a rental and running a 220v receptacle isn't an option. My plan is to change the cord from the...
The link below explains the extension cord requirements / amps. According to the chart, 14 gauge is good for about 50 feet, however you could bump-it up to 12 to be on the safe side. If you have a dryer plug in the garage or close, you could share that plug when not in use. Go to electrical supply house (or Lowes) with drawing of the plug /outlet needed and buy the components to make cord. If you have a 115v plug in the garage with its own breaker at the panel (plug with direct wiring to the panel) you could have an electrician convert it to 220 very easily. Good luck with your future projects.
http://electrical.about.com/od/wiringcircuitry/a/extensioncordchart.htm
May 27, 2011 | Campbell Hausfeld Air Tools & Compressors
I want to run this compressor "RITIN RT2012" 2HP 12L (1.5kW) compressor. It's a 110V AC drive unit and I have 240V. Can I run it or do I need to convert the Power supply.
You can't just run it on the 240 Volt supply. Check the motor nameplate. If it says it is rated for 110/220 or 115/230, or 120/240 Volts, then it is capable of running at 240V. This will require a wiring change, and you may need a larger size power cord.
The electrical diagram should be on the motor name plate or under the cover to the electrical terminals on the motor.
May 25, 2011 | Air Tools & Compressors
I have a Campbell Hausfeld oil type direct drive 7 gallon compressor. It often works fine but it frequently locks up until the internal circuit breaker cuts off the electricity to the motor. When the...
In our shop we have found the conditions you describe are almost always attributable to the power supply. First, never run a compressor on an extension cord, you are always better off running longer air lines. If you absolutely have to run an extension cord use a least a 12 guage cord no longer than 25 feet. If possible plug the compressor in as close to the circuit box as possible. Lastly the circuit the compressor is plugged into should be rated at least 15 amps, 20 amps is recommended for most compressors. Low amp lines cause the motor to overheat trying to get enough power and usually blow the circuit breaker at the motor and not at the circuit breaker. Lastly, use only compressor oil in the pump and make sure it's not overfull. This will also cause the motor to work harder and trip the circuit breaker.
Dec 17, 2010 | Campbell Hausfeld 2 - Gallon Direct Drive...
I pluuged in & it tripped the breaker. I pulled the oil plug (grren palstic) & looks like very little oil. Stick was oily but not dripping off at all. I notices there is no fill mark on the oil...
Are you hooking within 5ft of the outlet? If you are running a cord, then the cord can't keep the amp rating needed to run the compressor. I have one that does the exact thing. Try plugging it in close.
Oct 09, 2010 | Hitachi EC12 Portable Electric 2hp Air...
The on led flashes but will not come on
The power supply board is dead.The board that the power a/c cord go into it.That the power supply board.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Jun 07, 2010 | Akai LCT2715 27 in. LCD Television
Got a craftsman 1.5hp 12gal air compressor, model# 919.155612. when I fill it up it works fine, but when the compressor kicks back on after i used it, it sounds like it doesnt want to work it runs real...
Hello. This sounds like the power supply to the motor is insufficient. Eliminate any extension cord you may be using and plug directly into a recepticle. If this doesn't work you may need to run a new circuit.If your compressor has a relief valve pull the valve to release pressure while it is trying to start.This should help it by lowering the pressure it has to over come.
builderdale
Feb 28, 2010 | Air Tools & Compressors
Air compressor won't stay running even with resetting
How quickly does it shut off? Is it reaching the turn off psi? or is it immediate.
If it is immediate then it is probably a power supply issue.
Air compressors are power hogs. For instance, a compressor may work fine on an outlet using the supplied power cord, but plug it into an extension cord that is insufficient for it and a repeat of your problem will occur. If you use an extension cord make sure it is made just for this kind of application. Also, if possible, give the compressor a dedicated circuit.
Another problem might be your unloader valve not working correctly. This reliefs the pressure inside the pump after the motor has stopped. it would sound like the pump is working extra hard at start-up.
May 19, 2009 | Dewalt 2 Hp 4 GAL Air Compressor
Dell speakers making a poping noise
may be problem with correct socket
Mar 14, 2009 | Audio Players & Recorders
Samsung 25.5 Cu. Ft. Side-by-Side Refrigerator with Bottom-Mount Freezer - Black Logo
373 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
