Question about NexxTech 611-8212 Handheld Wet/Dry Vacuum
Where in Halifax NS can i buy the nextech ultima 14.4v wet dry hand vac
I need a manual for a Sop-vac 1.5 gallon.
Have a look at this page and if it matches your product, you can click "user manual" on the right hand side to download a PDF version of the manual.
Shop Vac 1 5 Gallon 2 0 Peak HP All Around EZ Wet Dry Vac
Sep 19, 2017 | Vacuums
Where can I get another power supply for Ultima 14.4v Wet/Dry Vac?
battery packs can be rebuilt by battery shops using better quality batteries or they may even have a new battery pack for your machine
go on line to e-bay and there may be battery packs there for your machine
Nov 07, 2015 | Vacuums
My rigid shop vac 4 gal 5.0 WD4070 wont start
Check elecrical connection, or switch may be bad.
Apr 14, 2013 | Ridgid Wet/Dry Vacuums Wd4070 4 Gal...
Do I take off the dry bag and the fome cover when picking up moisture ???
dont know what model you have, but, as a rule, the dry bag is for dry vacuuming and the foam is for wet vacuuming.
Feb 12, 2011 | Shop Vac Shop-Vac& Mini Hang Up Wet/Dry...
Change shop Vac Model LM500 from dry to wet pick
To change from dry to wet, remove the paper filter and install ball float if not already attatched
May 16, 2010 | Shop Vac 925-13 Canister Wet/Dry Vacuum
How do I change my Shop Vac QPV 10.5 from a wet to
you need to go get some bags and srew on the nozel and then put the bag inside the vac it will then act like a dry vac.
Nov 04, 2009 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
How do you change the ridgid 9 gallon wet/dry shop vac from a dry to wet vac? Is it simply changing the hose to the back fitting?
all you have to do is open it up and take the paper filter off and then it's a wet vac. If it has a foam over filter you leave that on
Oct 13, 2009 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Moto Brushes Problem... Who could help?
where can i fine moter brushes for my ridgid 5.25 hp 16 gal. wet dry vac.
Oct 02, 2008 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
NexxTech 611-8212 Handheld Wet/Dry Vacuum Logo
Top NexxTech Vacuums Experts
Are you a NexxTech Vacuum Expert? Answer questions, earn points and help others
