Question about Air Tools & Compressors
Hammer does not pound very well
I think I need a seal kit
  • 463 Answers
Yes
Posted on Mar 12, 2009
What gear lube to use
1 bottle of 50ml oil BOSCH 1 615 437 511
But also a special kit thats neccesary if it had its working hours and was leaking in the front .
Not only a seal and o-rings to change is not enough
1 special kit BOSCH 1 617 000 430 if all parts are replaced don,t forget also to change the O-ring 1 617 000 430 on the right place see first how its fitted its included in the kit with seals but remarkable the oil is not allways in the kit
Feb 06, 2016 | Bosch 11241EVS SDS-Max Rotary Hammer
What part grease to use for makita hm1500?
30 grams needed order nr its a grease with ordernumber 181490-7
And 193403-6 is the service kit for this machine.
Jul 02, 2014 | Makita Hm1500b 42-pound Demolition...
Usb pin config
You need some expensive equipment to do this.
1. Electronically Erasibale Programmable Read Only Memory Programer 840 pounds minimum for a decent one.
2. Digitally Controlled Interfered Re-Work Station 3740 pounds
3. Computer Aided Design Software 1000 pounds +
4. Computer Aided Manufacture Software 1000 pounds +
5. Specialist Micro Electronics Tools 130 pounds
6. Specialist Digital Systems Tool Kit 322 pounds
You need to first remove 3 IC controllers from the motherboard using the Re-Work station, than insert them in to the EEPROM Programer and reprogram them using the software that cam with it. DO NOT touch these IC's as 1 spec of dust on a pin and they will never work again unless you have Concentrated Sulfuric Acid and Acetone which you you can mix for 12hours in a sealed high pressure chamber with argon (I doubt), or you could spend 4000 pounds sending the IC's off to be cleaned (not likely when you can buy them for 16 pound.
Sep 20, 2013 | ASUS P5S800-VM Motherboard
What tool is needed to install a rear main seal on a 4.3l chevy s10 motor
There are seal drives . you might be able to get one at your local parts store . they may loan or rent this type of tool to you . Just ask them when you buy the seal or the gasket kit .Now to replace the seal you will need to remove the transmission to gain access to the rear main seal
Mar 06, 2011 | 1995 Chevrolet S-10 CA Edition
Hi I am having problems with my porter cable air nailer.. 2" brad nailer.. The hammer is not retracting far enough to hit the next nail.. I have taken it all apart and cleaned it and re oiled it but...
This is usually a sign that the hammer is slightly bent or the o-ring seal is going bad. You have to replace the hammer. If replacing the hammer doesn't work, the barrel it rides in is out of round and will need replaced. These pull out hard and you need allot of grease and patience to get them back in square to keep the seals intact.
Mar 03, 2011 | Porter Cable PorterCable FNBNNS3TB Factory...
Motor works,but no impact at bit
It soulds like either the striker is stuck or the ram. Unless you are mechanically inclined I would recommend taking to a repair shop. If you are give me the exact model number and I will see if they make a repair kit and get you a schematic for this tool before you start dissassembly.
Aug 17, 2009 | Makita Hm1500b 42-pound Demolition...
Bosch Breaker Hammer Service Kit Install
The grease in the upper drive area used to be a purple looking grease and the grease in the barrel was a different color and weight. If you ordered the rebuild kit with the O rings and bolts I would use it in the barrel (light film coat on the parts )
May 10, 2009 | Bosch Brute Breaker Hammer 11304
2002 chevy 1500 4X4 pickup front wheel bearing assembly
Just to make sure they are a sealed hub and bearings...remove the brakes and rotor and on the back side of the hub there is four bolts remove them, remove outer nut on CV shaft, then pull hub from housing. clean hub seating area then reinstall.
Was thinking that's what i did on mine, just becareful when you place the ABS sensor back. line it up so you don't have to take the wheel back off. Good luck and hope this helps
Apr 10, 2009 | 2002 Chevrolet Silverado 1500
Hammer Drills differnces
Hammer Drills combine the rotation of a regular drill with a pounding action. These two actions enable the hammer drill to bore holes in masonry quickly without burning the bit.
Aug 27, 2008 | Dewalt DC2PAKCA Heavy Duty Xrp 18V...
Luminox
You can use a 3 pound hammer to take it apart or you can send it in for service. The watch will need new reseals once it is opened in order to keep it water proof. Send it in for service, evern if it is just in need of a new battery.
Jun 20, 2007 | Luminox Navy SEAL Dive II Wrist Watch
Air Tools & Compressors Logo
247 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
