Question about D-Link Xtreme N DIR-655 Wireless Router
No wireless (init failed) but wired works fine
we just bought us a dir-635
connected and wired works perfect,
but the wireless doesnt. when we setup the wireless trough the wizard, it seems fine, but when i save the settings, and go to the status page, it gives us this error message: wireless radio: init failed
we see no mac adress on the status page either, SSID isnt shown there either, tbh. the only thing filled in in the wireless section is the error message, and the WISH: is active ...
no idea what could be wrong, i dont know wish maybe the problem is there.... if anyone got an idea, please help us out,
thanks
Sander I have the same problem and I called Dlink went through all their steps including turning off the power doing a hard and soft reset as well as updating the firmware nothing worked they pretty much told me too bad there's nothing they can do.
  • 3 more comments
  • cotestephan Mar 15, 2009
    No effect as soon as I turn on WPA it stops broadcasting
    Something strange to add may be connected thought something with wifi protected setup might have been the problem but when I tried changing the settings it said only the admin could do that thing is I am logged in as admin an
    Also tried setting up an admin pswd in case that might be why after reboot pswd is not set up kinda weird
  • Anonymous May 17, 2009
    I have the exact same problem, running 1.21eu firmware version.
  • Anonymous May 18, 2009
    Same problem on two routers (first one RMAed becuase Dlink tech support couldnt fix it) (on the phone again with them now)
    Tried the 192.168.2.1 and multiple other 192.168.x.1 addresses to see if that fixed the problem with no luck.
    Any other thoughts?
    Dlink people seem to think it is a hardware failure (and will RMA based upon this failure).
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 167 Answers
- Kindly try to change the LAN IP Address of your router to 192.168.2.1
Posted on Mar 14, 2009
2 Suggested Answers
SOURCE: no wireless (init failed) but wired works fine
Turn off all power supplies to the router. turn off internet Source. Leave everything for about 10 seconds. Turn all equipment back on including the router and it should sort it. You are reseting the router and loosing its memory basically.
hope this helps you
Posted on Feb 15, 2008
How can i change the password of my D-link DIR-635 router
To change any settings on the router, you will need to access the router set up.
Do you have any computer connected to the router with the cable?
If not then you will need connect the computer to the router.
open the setup page and change the settings.
Click Here for step by step instruction
Dec 05, 2009 | D-Link / RangeBooster N 650 / DIR-635 /...
No WIFI on D-link Router
If the wifi light is off its a sign that there's something wrong with it, so the first thing you can do here is to reset the router, To reset it press and hold the reset button of the router for 30 seconds and then power off the router for 10 seconds....
Aug 09, 2009 | D-Link / RangeBooster N 650 / DIR-635 /...
Work as acsess point
first let's back up and get the terminology right (otherwise you will not find any information on the internet.)
Your 655 will be the Access point, because it gives access to the wired WAN (ISP, Internet, etc.), or 'outside world".
Your 635 will be called a Bridge, because it bridges the connection from the access point to other wired or wireless clients inside your own network.
If this mode is accessible for you depends on the firmware you have installed. Look at this posting.
Your D-Link 635 is unfortunately not compatible with other firmware, which would be necessary to convert it into a bridge. (See here)
Sorry - but that's the reason why so many people get a Linksys or Buffalo router.
Also - the distance of 500 meters (open air or not) requires an increased transmitting power from the access point (655) and you will have to use different antennas. Third-party firmware also allows you to modify the standard power settings, but you have to make sure that you stay within legal limits of the place where you set this up. If your signal interferes with someone else's, you might get into trouble or even get a fine.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
May 30, 2009 | D-Link Xtreme N DIR-655 Wireless Router
D Link DIR 635 - need to reset user name and password !
You can press the reset button on the DIR-635 which will reset the device back to it's factory defaults. Then connect using the factory default user id and password. (ID: Admin password is blank)
Mar 17, 2009 | D-Link / RangeBooster N 650 / DIR-635 /...
Problem with the wireless d link DIR- 635
I'd try doing a power cycle. Power off all the equipment. Plug in the Modem untill the online light is solid, then plug in the router, then i'd turn on your laptop.
Ensure that your connecting to the right network. Under the network settings the SSID is your Network name. Make sure it's not a generic name.
If you have a cable provider, you can just bring it to Geek Squad. They'll setup the router and setup all the security features in the store within about 10-15minutes.
Jun 19, 2008 | D-Link / RangeBooster N 650 / DIR-635 /...
D-link range booster N650series is out of range
If the wireless device your trying to connect to is right there in front of the router and your getting out of range an antenna could be lose or bad.
Check here to make sure your setup is correct
DLINK support pages
Dec 13, 2007 | D-Link / RangeBooster N 650 / DIR-635 /...
hope this helps you
Nov 02, 2007 | D-Link / RangeBooster N 650 / DIR-635 /...
D-Link DIR-635 - wireless not working
Hello GEMD,
There may be different reasons why your wireless network is not working properly, let me ask you few questions in order to narrow down the problem.
  1. Is your D-Link DIR-635 brand new therefore we are talking about a new installation?
  2. Are you able to connect via wireless your two laptops in other locations?
  3. Could it be that the wireless has not been enabled yet in your router settings? To check this you will have to log on to your router by typing 192.168.0.1 in the address bar of Internet Explorer then select Admin as Username and leave the password field blank. Go to the Wireless Settings and Setup tab in order to enable  the "radio" signal.
  4. Could it be that an SSID has not been assigned yet to your wireless network?
You can download the complete product manual from the following page.
http://www.dlink.com/products/?pid=487
Regards,
GiBi
Oct 19, 2007 | D-Link / RangeBooster N 650 / DIR-635 /...
Hi, I am assuming that you can connect to your router's web based interface (192.168.0.1). On a PC LAN wired to the router, open a browser; Type "192.168.0.1"; Log-in username/admin and password/(blank); Go to Tools > Misc and the option to select the WAN speed (bottom); Lock the speed down on the WAN port of your router to 10Mbps (Some versions do not have this feature). Hope this works for you. If not pls post back with your modem brand/model. You may also want to log the IP settings (IP Add, Subnet Mask, Default Gateway, DNS Servers) of the PC that is directly connected to the modem when you can access the Internet when not using the router. Good luck and kind regards.
Oct 02, 2007 | D-Link / RangeBooster N 650 / DIR-635 /...
D-Link Xtreme N  DIR-655 Wireless Router Logo
2,928 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
