Question about Bosch WFMC2100UC Nexxt Essence Washer
My bosch nexxt essence washer won't wash or spin
It fills with water but the tub won't move I removed but the back the belt is still inplace , do you know what alse it might be
SOURCE: My Bosch Nexxt Essence front
My Bosch Nexxt Essence front load washer will not drain. I changed the lint filter, and insured that the drainage hose was free of debris. I removed all the wet clothes, wrung out the excess water, and redistributed the clothes. Still, no draining or spinning. Initially there was a humming sound, but now there is no sound at all when I try to restart the drain or spin cycles. All the lights are appropriately "on".
Posted on May 24, 2008
  • 1462 Answers
SOURCE: Bosch WFR 2460 washer - Drum does not move during wash/spin cycles
possibly the motor brushes.
take back panel off and motor is held in by bolts which undo - also disconnect electrical plug and socket.
check condition of brushes
Posted on Oct 16, 2008
  • 1462 Answers
SOURCE: my bosch nexxt 500 series washer won't spin
take back panel off. disconnect motor. remove bolts holding motor in and take out motor. check condition of brushes
Posted on Oct 18, 2008
cjrepairs
  • 60 Answers
SOURCE: Bosch NEXXT 500 SERIES washer Makes knocking sound while spinning
during transport there are fittings installed to prevent damage to the machine. The shaft may have got bent but before panic sets in try to check 1. that there is a gap between the mahine and units
2. that the unit is leveled.
Posted on Aug 16, 2009
barkencoa
  • 3463 Answers
SOURCE: won't wash
You need to check and replace the brushes in the motor if they are less than 3 or 4mm long.
Access is usually from underneath the washer, this means laying it on its side.
Posted on Mar 01, 2010
Testimonial: "thanks for making me a hero with my wife, machine works great"
My Bosch next 300 washer doesn't spin as fast as it did. It leaves the clothes wet and some water in the drum. No error code comes up? How do we fix it?
If the tub still moves but it's just not spinning that fast (and the water is draining out), then that means your motor control board has just started to fail and it will need to be ordered and replaced to fix the issue. If you pull the washer out and remove the back panel, there is a control board mounted to the floor under the tub. This is the motor control board and it will need to be ordered and replaced to fix the issue.
Oct 28, 2012 | Bosch Nexxt 300 Series WFMC2201UC
Bosch nexxt essence won't spin
Either a blocked filter or worn carbon brushes
Oct 11, 2017 | Bosch Nexxt Premium WFMC6400UC Front Load...
My front loader fills with water, pumps and drains fine but the drum never moves or spins . Already cleaned pump, Checked belt and motor, belt is good and motor and drum spin freely.
Remove the back panel of the machine and operate it to check that the drive belts are being engaged to drive the drum. Observe the operation from a safe distance when you have the back off as there are live terminals within reach and you could be severely shocked if you come into contact with any one of them. Unplug the machine again before checking anything withing the workings.
May 21, 2011 | Bosch Nexxt 100 Series WFMC1001UC Front...
Bosch Nexxt Essence WFMC 2100 UC (washing machine) Water leak noticed on floor right in front after wash cycle is completed. This occurs every time I use the washer.
Bosch Nexxt Essence WFMC 2100 UC (washing machine) Water leak This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Oct 26, 2010 | Bosch WFMC2100UC Nexxt Essence Washer
Won't wash
Mar 01, 2010 | Bosch WFMC2100UC Nexxt Essence Washer
Bosch washing machine will not fill, spin, drain..has power and water to machine...perhaps circuit board?
If it won't fill it may not spin or drain unless the water level switch is bypassed. I would check the water valve & the water level switch and tube from level switch to tub must be air tight no holes.
The water level switch must kick in to agitate. I'm not sure on Bosch but some work like this..
Jun 09, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
I have a error code coming up saying E:04. Any solutions?
It has been 2 1/2 weeks since this was posted so it has already been solved probably. Open the basket on the pump to see if the water is draining freely from the wash tub. (You can access the basket by removing the round panel in the lower right corner of the front panel). If the water is freely draining, check for plugging of the drain line from the pump to the outside. If the water is not freely draining, remove the rubber boot between the wash tub and the pump and clean out the debris around the ball at the wash tub end.
Apr 11, 2009 | Bosch WFMC2100UC Nexxt Essence Washer
My Bosch Nexxt Essence front load washer is making a knocking and squeaking noise during the whole spin cycle. It sounds like it's coming from the drum mounts - what should we do?
Apr 13, 2008 | Bosch Washing Machines
Washing Machines Logo
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
