Question about Daewoo DSL-17DW3 17.1 in. HD-Ready LCD Television
No picture at all on daewoo lcd tv
I have an LCD Daewoo TV solely connected to an Xbox360 games console. The problem is when i turn tv & console on the console works fine & the tv stays on a black screen (no picture at all). The tv is connected to the console via a component lead which i have never had a problem with. I have tried another lead & this does not help. The tv is definently on the correct setting, the same setting it has always been on. The tv is 2 years old & again this problem has never happened before. The console has recently been repaired & has been working fine, so as the leads & the console are ok maybe the problem is the tv. Can you help please. Many thanks Dean Blunt
  • Anonymous Mar 18, 2014
    my ps3 wont work through my hmdi tv it says out of range and the picture flickers to the game then off again
I have a problem that looks similar. After some research and troubleshooting, I believe that the problem with my TV is the A/D decoding chip that takes care of the component video inputs. These chips are not simple analog to digital converters. They understand the component video (YPbPr) signals and need to sync to them at the various transmission frequencies and convert them to 3 digital YUV data streams with the correct number of pixels and dimension. I am only a computer engineer, but I guess these chips probably aren't very reliable or last very long... Try to use your TV with different input connectors and resolutions. If some of them work correctly, it is likely the A/D thing.
Posted on Aug 11, 2007
Vertical line on daewoo tv 14"
If that is an LCD screen, you need a new one. The edge connection on the LCD has come loose at one solder point. You could take it apart and see if you can locate it.
Oct 21, 2013 | Daewoo Cars & Trucks
Tip
DLT-32C3FTB
Hi.
This comment applies to Daewoo DLT32C3FTV. The system had in list only the model DLT-32C3FTB . Parts for the smaller model DLT-32C3FTB are available from the same sellers listed below. Troubleshooting is the same.
The stand by light flashing means that a fault had been detected, and the TV protection circuit had started.
Whenthis happen, the protection circuit will shut down all PSU highervoltages, keeping the low +5V to supply the flashing led on, and warnabout the fault.
The TV does not respond to control when in protect mode.
All you can do is checking all connections, and leaving the TV disconnected for a while, to drain charge held on PSU capacitors.
A short in a cable or connector will also cause the unit going on protection.
You can follow the instructions on this article, it refers mostly to DLP, but the troubleshooting is the same on LCD TV2_bing.gif: Why my TV does not start up and remains in.
If you have done that already, that means that there is an internal fault.
Inthat case the best thing to do is contacting manufacturer at the numberlisted on the owners manual, and getting a quote on repair.
Onan LCD like this there are only few parts, a main controller, aninverter, a PSU board, an audio board, an LCD controller board, abutton and IR assembly, cables and the display.
The parts must be accessed and tested by a technician.
If the unit is less than one year cold, the repair will be covered bymanufacturer. In any case, if the TV does not wake up from protectmode, then it is faulty. Always better contacting Daewoo at the numberlisted on the owners manual.
Parts are available from Daewoo. A spare PSU, that is a common fault, is about £60 in UK. Here the spare:
Power Board FEL-3226H Daewoo DLT32C3FTV . Naturally that is not necessarily the fault.
Try first the troubleshooting procedure suggested above. If that does not work, contact Daewoo.
on Feb 11, 2010 | Daewoo DLT22W4T 22 in. LCD TV
Our Daewoo LCD DLV-42C7LMB has sound but no picture? We can hear the TV perfectly but the picture is blank completely. We have no Austar and no normal TV stations. We have checked all of the connections...
Chances are you have LED lamps in the panel that are bad and need replacing..look at spending at least $150 to get it repaired, for this TV 3 yrs is longer then they typically last, they aren't exactly high quality sets
Mar 06, 2018 | Daewoo DSC-30W60N 30" TV
My Daewoo LCD TV (DLT-32C3FTB) will not come off standby.
Common problem on power supply board, replace dried out electrolytic capacitors
Apr 22, 2009 | Daewoo DLP3212 32 in. LCD Television
Daewoo lcd dlt 20w2
Hi this is warjis ahmed,
I can solve your problem of DLT-20W2
My email> warjisahmed@hotmail.com
Oct 29, 2008 | Daewoo DSL-17DW3 17.1 in. HD-Ready LCD...
Xbox360
is your 360 set to 1080i
Sep 13, 2008 | Microsoft Xbox 360 Console
Connected My Xbox360 To My LCD Getting Picture No Sound (Used Xbox360 VGA Connector)
On your output cable there is a smal switch that says HD or TV. Make sure that is on the correct spot!
Jan 09, 2008 | Video Game Consoles & Games
Daewoo DSL-17DW3 17.1 in. HD-Ready LCD Television Logo
596 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
