Kenmore washer model 110.4756, I push the start button and the washer goes off
  • 36 Answers
SOURCE: kenmore elite washer won't start
Dear Customer
Please perform the following
unplug the washer for 5 minutes and then plug it back in,This can resets the system
Please rate this,Thank u
Posted on Dec 17, 2008
SOURCE: I have a Kenmore HE3t
There is a black plastic piece that sticks out from the machine. It is located at about
2 o'clock. You probably broke off the piece as I did with mine. If you have a wooden skewer (or something like it), stick it in and depress the button. You can glue the skewer in place.
That should fix your problem.
Posted on Aug 17, 2009
Testimonial: "the post on August 17th fixed my machine. It was the button on the door that was broken off."
supernova278
  • 1932 Answers
SOURCE: Push Start button on our
F33 error code indicates Pump drive system error. Try running the unit empty, set to a cold/cold cycle. If this does not help, you will need to have the unit checked by a service technician.
thank You
Posted on Sep 10, 2010
blueextc3221
  • 15935 Answers
SOURCE: shuts down when start button is pushed
There is likely a short on the ECU and it must be replaced. Further testing should be conducted by a professional in this case.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
blueextc3221
  • 15935 Answers
SOURCE: Not starting when button pushed
It appears your timer/main controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Posted on Sep 14, 2010
How to reset a Kenmore model 2661532210 washing machine
try this.if it does not work then go to this link and see if it helps you out...... Programmable Washing Machine Certain programmable washers have a reset function. This function clears an unintentional "Delay Start" command and resets controls in the case of a program error when the machine won't start. The method of resetting varies by make and model. In certain models, turn the knob to reset with the power button "Off." Select the desired program. Press the power button to restart the washer. In other cases, if the machine has a "Cancel" button, push it to clear the error and then push the "Pause" or "Stop" button to reset it. Consult the handbook for the washing machine for the correct procedure that applies to your model. You can often find washing machine handbooks or troubleshooting instructions on the manufacturer's website............
Reset Buttons for Washing Machines
Dec 08, 2016 | Kenmore Washing Machines
Self cleaning button sequence want start
you need to see in the bottom of your washer or take the back panel and some of this washers have a reset button, try due that, make sure is unpluged while you due this, clean all the contacts inside and check all the wires make sure they okay
Oct 17, 2012 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
My Kenmore Elite washer model 110.27062600 stopped working. All the front panel lights are flashing on and off for 7 times then pauses and starts blinking again. The machine will not do anything. No...
if this is an oasis model. Try pushing other buttons you should get a touch tone (beep) as a good response. if no sound you seem to have a interface problem. not a main ctrl.
Sep 19, 2017 | Kenmore Elite Oasis 27052 Top Load Washer
Hello I need your help my Kenmore washer my
Unplug the washer and wait for 30-45 seconds before pluggin it back in. That should clear any "cycle codes" that were initiated by the button pushing daughter.
The washer will then allow you to reset and start a new wash cycle. It'll figure out there's water in the tub and act accordingly (either pump it out and refill, etc.)
IF this doesn't solve the problem, just leave a comment back on the original post and please provide me with the full model number of the washer so I can get the info for further troubleshooting steps.
Hope you find this Very Helpful and best regards!
Aug 18, 2009 | Kenmore HE3T Washer
Kenmore dish washer lights up but will not start wash cycle.
turn off your dishwasher then try it again ok
Feb 27, 2009 | Kenmore Dishwashers
Kenmore front load washer won't start. Lights just blink
I had same problem........push options and select button at same time, hold for 5 sec.......choose option.....machine stuck inbetween cycles.
at least it worked for me!
Dec 26, 2007 | Washing Machines
HE3 Front loader Controls Locked
Try 'end of cycle' pushed down till the light goes off. Or locate the button with diagram of 'lock', & push down till the light goes off.
Dec 24, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Washing Machines Logo
141 people viewed this question
Top Washing Machines Experts
