Question about Samsung LN-R268W 26 in. HD-Ready LCD Television
Hdmi factory reset
Toshiba regza no longer receives a an hdmi signal.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Nov 02, 2016 | Toshiba Televison & Video
Samsung Plasma PN64D7000
Jul 17, 2016 | Samsung PN64D7000 64 plasma 1080p 3D HDTV
What board/part do I need to replace the only HDMI port HDMI (19 pin HDMI Type A) on a Panasonic TH-42PD50U EDTV.
Apr 20, 2016 | Panasonic Televison & Video
The hdmi wont work the av works I have tried all three hdmi plugs on the the tv and it says no signal could you please help everything I have is setup for hdmi
Tries tv and those cables or satalites boxes unplug,replug it back like about an hour later for those pay boxes to reboot and upgraded it softwares.Tv to do a whole resetting itself back to the factory setting.Than go into the tv Menu.Go into Video Setting,go down and do a resetting back to factory setting.By doing this steps for every components devices that hook to the tv HDMI hubs ports on the tv Tuner signal board to reboot and resetting too.Have very good chances all the HDMI hubs ports on the tv to work again.
Jun 26, 2011 | LG 42LC2D 42 in. LCD HDTV
When using hdmi outlet,,,the picture comes in for 1 second then screen turns all green
That HDMI port hub it properly shorted,tries used another HMI ports hub?Tries to reset the tv back to factory setting,by unplug,replug it an hour later,go to the tv menu go to PICTURE,go down to reset.So the Tuner board reset itself back to the factory setting,all the HDMI ports hubs,should work now or that HDMI port hub is shorted,or the Tuner board it dead.
Jun 11, 2010 | Sony KLV-S32A10 32 in. HD-Ready LCD...
HDMI port does not work
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
Apr 29, 2017 | Samsung HP-S4253 Television
I have the toshiba 42hl167 and the volume is not working. only works with play station. cant here cable or bose system.
I would reset the factory defaults on the TV, but some complicating information follows these instructions:
Reset Factory Defaults
To reset all settings and channels to their factory
default values:
1 Press Y and open the Setup menu.
2 Highlight Installation and press T. A new set of
Installation menu icons will appear.
3 Open the System Status menu, highlight System
Information, and press T.
4 Press C c to scroll through the menu bar to select
Factory Defaults.
5 Enter your PIN code (or 0000 if no PIN code has been set).
Because the PC and HDMI-1 inputs share the same set of analog audio inputs, the PC Audio menu setting influences the HDMI 1 Audio menu setting. If PC Audio is set to “No,” the HDMI 1 Audio setting changes to “Auto.” If PC Audio is set to “Yes,” the HDMI 1 Audio setting is set to “Digital” and is grayed out in the menu. (Also see item 5 on page 12 of manual and “Setting the HDMI™ Audio mode” on page 43 of manual).
There is also some good information on pp.20-22 and 54-57 of the manual - this one has a lot of audio hookups and settings.
-Tha Mp3 Doctor
Dec 17, 2008 | Toshiba 42HL167 42 in. LCD Television
Samsung LN-R268W 26 in. HD-Ready LCD Television Logo
Jerry Greenberg
Jerry Greenberg
