Question about Garden
Craftsman 42 inch 19 hp turbo cool briggs & stratton riding mower manual
Manual for 42 inch deck sears craftsman 42a707 briggs & stratton ic platinum 19 hp turbo cool riding lawn mower manual
wadembly
  • 462 Answers
SOURCE: 42 inch Craftsman blades won't engage
is the belt spinning & smoking when blades are engaged or the belt won't spin if the belt spins but blades wont go then there is something stuck under the deck or the bearings are gone out do to not being greased
Posted on Jun 14, 2009
  • 148 Answers
SOURCE: need a manual for a LT1000 craftsman 19 1/2 HP 42 inch mower deck
You can download a free copy at www.managemyhome.com or you can go to www.searspartsdirect.com and buy a copy along with look at the diagram that you need.
Posted on Jul 23, 2009
  • 474 Answers
SOURCE: 15.5/42 manual & oil filter
may not have a filter.try briggsand sratton.com. you will need all the info off the data plate on the engine
Posted on Sep 14, 2009
mickey813
  • 472 Answers
SOURCE: Poulan 42-Inch Steel Deck 17.5 HP Briggs &
SOUNDS LIKE YOU HAVE A BENT BLADE TRY PUTING A 2X4 UNDER THE DECK THEN LOWER IT TO HOW IT LOOKS IF ITS THE SAME ON BOTH SIDES THAN YOR BLADE IT BENT
Posted on Sep 30, 2009
The GR8 1
  • 7 Answers
SOURCE: Craftsman 42 inch deck mower.
That model number des not show up as a good number on the http://www.searspartsdirect.com site. Are you sure you have the belts on correctly? If it has 2 belts on the deck & 1 is not installed correctly they work against each other. Safely make sure that each blade will turn by hand. did you take the blades off? If they are too long by just a fraction, they will hit ach other, but that usually makes quiet a noise. Get your book out & systematically go over everything you touched or changed. It sounds like something really simple you have overlooked. you can go to http://www.searspartsdirect.com & enter a good model number & view all of the parts diagrams. Sometimes they are a big help, & at other times they just confuse you more:). Let me know what you find!!
Posted on Aug 13, 2010
What spark plug for a 19.5 hp briggs & stratton
what is the settings for the spark plug gaps in a Briggs and Stratton 19.5 engine 46 in riding lawnmower
Jul 26, 2012 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Mower deck belt diagram for poulan 42 inch ride mower
Go to Craftsman, Order Tree or Parts Tree.com and input your model number. Choose the correct tab and go to the mower deck. It will give you a good over view of how the belt routes. Hope this helps.
Nov 02, 2011 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
WHAT WEIGHT OF OIL IS NEEDED FOR A YS4500 W/ A 21 HP BRIGGS AND STRATTON MOTOR
I have used 30 WT oil in all my 4 cycle engines. You could google Briggs & stratton to get some info. Sears will sell you an operators manual. Try googling Sears, you might get lucky & get the manual for free..
Louie Almond
Mar 27, 2011 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
I have a craftman 42 inch silver lawn tractor and would like to change the oil what typpe do i use
Briggs & Stratton engines use 48 ounces of SAE 30 oil & Kolher engines use 2 quarts of 10w30 oi. Be sure not to over fill the engine will smoke like a banshee!! Verify the level with the dipstick. Oil can be gotten from Sears or from your favorite auto parts store.
Oct 28, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
10 A Fuse blows each time I shut off engine. Short somewhere? Suggestions? Craftsman 19 hp Briggs & Stratton 42 inch deck. Probably 10 years old. Thanks! Mike
Yes, probably a short, and I think you should look at the ignition switch as the first suspect. It has two switches inside - one to send battery power to the various components, and a separate one to ground out the magneto when the mower is turned off. Could be a short between the two parts of the switch. Test it if you have the tools, otherwise try replacing it. Good luck! If this is helpful, please take a moment to rate my solutions, thanks!
Jun 10, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
What is the belt number for a 38 inch Poulan riding lawn mower
Assuming you mean the deck belt, since you don't specify, it is part number 144200 The same as Craftsman. AYP, Poulan, and several others. You can purchase it at most sears stores or order it on line
Sep 28, 2009 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Mower cutting off when the engine heats up (Sears Craftsman)
sounds like you have magneto getting hot,,, next time it do it,, let it cool off for about 2 hours see if crank and run again till shut off,, if if does replace magneto,, hope this help,, good luck
Aug 11, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
How do I clean the flywheel on my Craftsman/ Briggs & Stratton lawn tractor
What is on the flywheel?
You can wash it off with water spray or clean with soapy water. Let engine cool down before cleaning it. Let it dry before running the engine.
Aug 03, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Garden Logo
415 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
