Question about Whirlpool Dryers
Gas go's on then shut off
The flame will come on for five min, then gos off, the igniter will come on and off trying to relight but on gas coming out. if you trun it off and let it sit for five min it will work but only for 4 to 5 min
something is shuting the gas valve off
Thank you
Joe
  • Whirlpool Master
  • 3,361 Answers
Check the exhaust for good air flow.
Remove the rear exhaust vent and run the dryer.
If that corrects the problem repair the vent blockage.
If it does not correct the problem replace the gas valve coils.
Posted on Mar 12, 2009
Burner won't come on or shut off have to manually hold contact open
On some gas-powered appliances -- such as gas ranges, water heaters, boilers and gas fireplaces -- the pilot light works to ignite the main flame when the gas is switched on to the burner by the regulating valve. If the pilot light is not lit, the gas burner will not ignite, which could cause a dangerous situation by letting highly flammable gas escape into the air. If the pilot light goes out, you can relight it after the gas is shut off using a match or the unit's electronic ignitor if it has one, following the proper safety precautions
Nov 12, 2017 | Heating & Cooling
Richmond gas w/htr. light pilot and main burner 15 seconds both flame out...relight pilot..it'll stay on five minutes .flames out..new thermo coupler
Make sure the thermocouple is deep into the blue part of the flame. If it is good, then the only part left is the defective main gas valve.
Sep 08, 2015 | Water Heaters
Relight combi pilot light?
These are designed not to light once the thermocouple fails.the thermocouple has a small wire that positions in to the pilot light which checks the pilot is on and keeps the gas governed.once the temperature drops it shuts off the gas to prevent a build up of gas in a room where a pilot light has gone out.this is why you need to hold the button in on reignition to allow the thermocouple to heat up so the gas keeps open.
Try to relight by turning on the gas ....pressing down and holding the button for at least 10 seconds whilst firing the piezo to ignite flame.do not release gas button for at least 10 seconds then slowly release.if the flame on the pilot will not stay alight....then it is likely the thermo has failed.try cleaning the metal wire that is above the pilot jet.still no joy then it needs replacing.hope my comment is of help...please vote.
Feb 19, 2015 | Water Heaters
Model 110 72712101 kenmore gas dryer will come on run about 2to3 minutes then goes off after a short the glow will come on again but will not relight.
Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time. Here is a link to the parts you need.
Jan 02, 2011 | Kenmore 63942 Dryer
Dryer starts hot surface ignitor comes on gas valve opens i get a flame 5 mins flame shuts off hot surface ignitor repeats and tries to ignite no flame after unit is off for 20 mins to 30 mins off unit...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 17, 2010 | Kenmore 77632 Gas Dryer
Dryer comes on in the beginning then flame shuts off and then
check your dryer vent for a clog let me know what you find
May 01, 2009 | Dryers
Whirlpool oven won't ignite
The good news for you is that your gas provider, the folks who bill you for the gas offer a free service whereby they will send out a technician to adjust your stove for no cost.
Apr 01, 2009 | Whirlpool GW395 Gas Kitchen Range
Gas log will not stay lit for more than 5 minutes
Sounds like the gas regulator has failed.
There will be sufficient gas flow to light the pilot and get a flame prove, then the main burner lights, you will probably see the pilot flame reduce somewhat, and no longer fully surround the flame prove sensor.
When the unit is relighted, the complete sequence starts all over again.
Have the gas regulator checked and adjusted (if adjustable) or replaced by a qualified technician.
Jan 20, 2009 | Heating & Cooling
L60AT wont relight
EE2 means no ignition. It could be No fuel or low fuel, dirty filter. You need to look at the flame when you try to start the stove. If you have flame then the igniter is good. If there is no flame and a bumping noise you have a fuel problem. No flame and no bumping you may have an igniter problem. Feel around the burner pot to see if it gets hot. A bad igniter will lead to a flooded stove if you continue.
Tom Hawkins
Bethel, Alaska
Dec 23, 2008 | Rinnai Toyostove Direct Vent Heater: Laser...
Lennox Gas Furnace that turns on and shuts off in minutes
After troubleshooting like mad, I found that the flame sensor (rod that sits within the flame) was fouled with carbon on the surface. I believe this shields the rod from proper heat detection and the sensor reports that there is no flame and to shut off the gas valve to avoid explosion. Once I pulled out the rod and cleaned it with a wire brush, I have no problem whatsoever--fixed.
Nov 10, 2008 | Heating & Cooling
Open Questions:
Dryers Logo
43 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
