Question about Canon Office Equipment & Supplies
Does canon pc-6re have hard drive?
Does this copier have a hard drive or memory?
  • 186 Answers
SOURCE: canon pc-6re
have you tried adjusting the image density dial located inside the front door?
Posted on Jan 02, 2008
Cogz
  • 1326 Answers
SOURCE: Older Canon Copier PC-6re
Then Error code means that the fuser / fixing Lamp is blown or it could be the thirmal fuse is blown. It could also a bad thirmister, that may have caused the fuse to blow. One thing you can look at, will the fixing unit get warm or hot. Do you know any copier techs, as a friend. It is not a easy job to fix this problem. You have to fix it to clear it.... Good Luck
Posted on Mar 15, 2009
  • 66 Answers
SOURCE: Serving my Canon PC-6RE Copier.
there are some things better left for others to do. copiers is one of them. you cant explain in a paragraph what needs to be done and how to do it. there are alot of things that can be broken by people who dont know what they are doing. your machine is so old that you cant get parts for it anyway. you would be better off getting a new machine.
Posted on Apr 23, 2009
SOURCE: I need a user guide for an old Canon copier model PC-6RE
You'll have difficulty finding that one, but really..... what is there you need to know?...it's as basic a machine as there ever was.
Posted on May 03, 2009
  • 1297 Answers
SOURCE: I got a new toner cartridge for my Canon pc 6re
The clening blade is located under OPC drum,fixing 2 or 3 scrw.
Posted on Oct 04, 2009
I have a print job stuck with the status of formatting. i tried deleting with no luck.
Sounds like an issue with the hard drive. Try disconnect the hard drive and boot up the machine, see if the message is gone. Then put back in the hard drive and reboot. If message persists you can try a memory clear in diagnostics, but it erases some settings. If problem still there replace hard drive.
Sep 23, 2015 | Xerox Phaser 3635MFP/X Multifunction...
How did solve the error code 041-348
Hi
This is showing as a memory failure, either check your memory is correctly fitted and not loose, or if it is not then you might have to replace the memory. hope this helps
Nov 25, 2014 | Xerox Workcentre 7435 Color Multifunction...
How to delete the memory?
Memory is over written as each page is formed. There is no function available to erase the memory. If your printer is fitted with a hard drive, remove it and put it into an external hard drive case, connect it to a pc and delete files there.
Jul 17, 2014 | HP Office Equipment & Supplies
How to remove hard drive in xerox pro 245 copier
Hard drives in printers? Never heard of such a thing. Memory maybe but not hard drives. Go to the Xerox website and enter your model and they should be able to help you. Unable to help with this one. Good luck.
Jul 06, 2014 | Xerox Office Equipment & Supplies
How can i remove the memory or wipe it clean before disposing of the machine?
There is a hard drive in the machine just like a computer that can be removed.
Jun 04, 2014 | Panasonic Workio DP-4530 Copier
Konica runs out of memory
Print and copy jobs are ripped to your hard drive on this machine. Your hard drive may be failing. You can try a logical format through service mode.
Apr 10, 2014 | Konica Minolta bizhub Office Equipment &...
Xerox 4150 hard disk problem
First off you can only use a hard drive intended for the copier. Also when you put in the new one you will need the firmware fro the copier. THis has to come from Xerox. If you ordered the HHD from them it may already have it on them.
Nov 05, 2012 | Xerox 4150/XF WorkCentre Multifunction,...
How do you remove the hard drive (memory) from a Lanier model 5635 copier?
FT 5832 is analog copier their is no hard drive for analog it just present digital copier.
Jan 07, 2011 | Ricoh FT5832 Copier
I am looking for the owner's manual for a Canon PC-6RE personal cartridge copier.
YOU CAN GET IT FROM WW.GETMANUAL.COM FOR SMALL FEE PAID VIA CREDIT CARD.YOU EVEN CAN DOWNLOAD THE SERVICE MANUAL/USER MANUALGUIDE EVEN THE MAINTAINANCE REPAIR FOR CANON PC-6RE
Mar 28, 2010 | Office Equipment & Supplies
I have a Canon PC-6re copier. It is jamming
Use a thin but strong piece of card board (such as the back of a standard yellow pad notebook) and easily force feed it through machine. I had to use this method with our Canon Pixma MP190 printer. Hope this helps, Good luck!!
Feb 21, 2010 | Canon Office Equipment & Supplies
old marine
old marine
