Question about Burgess Propane Insect Fogger 1443
Propane won't stay lit - Burgess Propane Insect Fogger 1443
CAN YOU MANUALLY LIGHT A DOMETIC RM2652 PROPANE FRIDGE IN A 2006 TRAILER
It will not light manually as the ignition probe is electronically controlled. If it doesn't stay lit normally then it will more then likely not stay lit when trying to light manually.
b2d344ab-6ceb-4320-bc24-f6c38ab91df8.jpg ArctiCold Refrigeration We keep it cold
Jul 24, 2014 | Dometic RM2652 Refrigerator
Heater won t stay lit
check gas pressure sounds like running out of gas meter might be too small
Jun 23, 2013 | Hayward Pool & Spa
Pilot won't stay on
Burners don't have anything to do with the problem of pilot not lighting. Is the problem that flame will not 'stay' lit? Or you can't even get a flame to ignite? If former: possible bad pilot generator or bad gas valve. If latter, possible bad gas valve or no fuel to ignite.
Dec 23, 2012 | Hayward H Series Pool & Spa Heater 400k...
The pilot light on my propane furnace will not stay lit. I replaced the thermocouple, but it won't stay on. Any suggestions?
Hi, with a new thermocouple, the only other thing it can be is the valve. Replace the valve.
Sep 03, 2011 | Heating & Cooling
Propane torpedo lights but doesnt stay lit
I'm confused. First you listed this as a propane torpedo heater. Second, it's a problem with and All Pro PK115 T Forced Air Kerosene Space Heater. And finally, you say "propane torpedo lights but doesn't stay lit."
Which is it? To really help you, I'll need the correct manufacturer's name & model number. And whether it's propane or kerosene fired?
Thanks.
Mar 02, 2011 | All-Pro Kerosene Garage Shop Heaters - All...
Gas oven won"t stay lit
you eaither have a bad regulator from the tank to the house or you have a bad appliance regulator behind your appliance you would need to check the pressure at the appliance if it is propane you should have between 10-14'' of water colum or if it is nat-gas it should be 4-7'' of w/c
Feb 20, 2009 | Magic Chef CGR3742 Gas Kitchen Range
Burgess Propane Insect Fogger 1443 Logo
140 people viewed this question
Top Burgess Garden Experts
Jay Finke
Jay Finke
Dennis Key
Dennis Key
john h
Are you a Burgess Garden Expert? Answer questions, earn points and help others
