Question about Kenmore Microwave Ovens
F-9 Error on Kenmore Ultrawave Microwave Model 721.64682300
Our Kenmore Ultrawave Microwave Model 721.64682300 has a F-9 error on it. Does anyone know what the problem could be? Sears has been out 4 times and still has not fixed the problem! I bought an extended warranty and have tried to get them to replace the microwave but they refuse. The cost of the repairs so far has been about $800.00, much more than replacing the microwave.
From everything I have read it is a 1100w inverter, I am having the same problem.
Posted on Jun 09, 2009
Kenmore microwave displaying SE error message. How do I fix it?
That error indicates a bad keypad. You will have to replace the keypad/control console assembly.
Apr 22, 2014 | Kenmore Microwave Ovens
Kenmore microwave model 63792 displays F2 error message
The F2 error code on your microwave oven is a membrane failure.
It is recommended that you replace the membrane first & if you still have problems to replace the control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 21, 2009 | Kenmore 63792 Microwave Oven
Kenmore elite ultrawave model 72180863400
F9 is almost always an error related to a bad door switch or door switch mount or misaligned door hinges.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switchor mount trouble can be caused by slamming the door or by opening thedoor while it's cooking without hitting the Stop pad first.
There areplastic mounts inside the microwave which hold the door switches andonto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it'sa broken tab on the switch holder, allowing the switch to rotate justout of position. This tab can be hard to see, since it is under thebottom edge of the switch.
One test that sometimes helps is togently lift up (and/or push down) on the door or handle as you try tostart it. If it works or tries to work, then it's a door switch mount ordoor alignment issue.
If you or someone you know decide to lookinto it, we have critical information on safety, disassembly and doorswitches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Theremay also be a "mini-manual" hidden inside the unit behind the controlpanel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
Sep 05, 2008 | Kenmore 63663 Microwave Oven
Kenmore elite ultrawave microhood combination error code F9
F9 is normally a bad door switch or door switch mount.
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa.
You can probably find exploded views and order parts by entering your model number here at the Sears parts site.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Aug 22, 2008 | Kenmore Microwave Ovens
F9 error
Your Microwave uses "UltraWave technology"
I'll explain a few things about this wonderful technology...
The control board (accepts the pushbutton commands) has to talk to the inverter board to tell it how much power should be applied to the magnetron. The inverter board will then power the magnetron and inform the control board if the magnetron is working OK.
If there is something wrong with the magnetron or inverter board or a there is a communication breakdown between the control board and the inverter board...WA-LA-----F9----
A pretty reliable test for the Magnetron is to operate the oven and listen for a ticking sound 5-6 times about a second apart. If you can hear the ticking....The magnetron has failed..if no ticking, the control or inverter board failed.
The Magnetron sells for about $78.00 and is simple to replace. Check your owners manual for limited warranty on the MAG and electronic parts.
Jun 10, 2008 | Kenmore 62622 Microwave Oven
Microwave Ultrawave with Hood fan
You are right. f4 means shorted oven temperature sensor (RTD). Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Apr 04, 2008 | Microwave Ovens
Kenmore ultra elite microwave hood combination
F9 code can mean something different depending upon the particular model.....
1.) IF your Microwave uses "UltraWave technology"/"SmartWave technology"...Then either the Magnetron has failed or the Inverter board has failed OR maybe the control board has failed (HUH?).
2.) IF your Microwave does NOT use "UltraWave technology"/"SmartWave technology" then one or more of the door switches has failed.
** "UltraWave technology"/"SmartWave technology" **
Note: This 'technology' may come in other flavors as well
Jan 19, 2008 | Kenmore 62622 Microwave Oven
CHANGING LIGHTBULB ON MICROWAVE
they should be torx # 15 0r # 20 this is not aifficult tool set to get unless the manufacturer put high security type torx and those have a small nipple in the middle of the screw so the tool has a small hole in the middle of the end. Good Luck
May 21, 2006 | Kenmore Brew 'n Wave 63992/63999 Microwave...
Microwave Ovens Logo
496 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
