Question about Exercise & Fitness
Have error 2 code on york t13i and treadill wont start
3 Suggested Answers
  • 1196 Answers
SOURCE: when switching on my York
I will advice you try re-calibrate your treadmill, follow the procedure below to re-calibrate it,
Step 1 Stand on the side rails of the treadmill for safety purposes. Remove the safety key. Step 2 Press and hold the two incline buttons. The incline buttons are blue and on the left side of the display. Hold the up and down button simultaneously. Release the buttons when the display reads "Calibration."
Step 3 Press the green start button located either above or below the large, red stop button (depending on your model). Stay on the side rails as the treadmill belt begins to move. Both the speed and incline should go through their full range from lowest to highest, and then back down again.
Step 4 Repeat the process if the display does not read "Calibration Successful." Contact the business where you purchased your treadmill if repeating the calibration process does not result in a successful calibration.
Posted on Jul 17, 2011
ercupa190
  • 12223 Answers
SOURCE: my york treadmill t13i keeps displaying err 2 code
see the details and fix it. God bless you
This is probably a faulty speed sensor see the diagram attached, clean it and tight the connector . 2)test the input voltage motor, if there are voltage the motor need repair. 3)test the output voltage board for input voltage motor, if there are NOT a faulty control board or lower board. The error codes will differ between makes and models but could be e1.
see the diagrams
Posted on Nov 16, 2012
Hi have you got a York fitness T13i motor
we do not we sell nothing here and only give advise
Mar 09, 2017 | York Exercise & Fitness
Hi have you got a York fittness T13i
as before , no we do not as we do not sell anything
Mar 09, 2017 | Miscellaneous
5 u code is on how to fix it
Gas furnace fault or error codes for common furnaces - Gray ...
www.grayfurnaceman.com/-ifc-failure-codes.html
Here are error codes found on many York, Trane, Luxaire, Lennox, Carrier, ... If younotice 5 red colored flashes on your York Furnace, it signifies that your
Oct 03, 2015 | Cars & Trucks
Im fitting a new pcb board in my york t13i the upper board the incline has gone has the lights on it are not working ive taken the wires off the up down and cpu terminals but i cant remeber which way the...
please remember the wires before. wires again the old board, and make a wiring diagram. After you did , you must try again with the new board, and repeat the process, very Important.
If the problem persist, call to the supplier board, and tell them if the can send some wiring diagram, or see if with the new board there are some schematic wiring diagram. Otherwise, you must make some errors and additional problem you will find it.Contact them inmediately.
God bless you
Nov 22, 2012 | York Barbell Home Use Fold-Up Treadmill
My york treadmill t13i keeps displaying err 2 code
see the diagrams
Nov 15, 2012 | Exercise & Fitness
My york treadmill pacer 3700 show error
I have just got a pacer 3700 off a friend and she had no manual for it. it keeps saying error 1 and wont do anything. what can i do to make it run again?
Oct 27, 2009 | York Exercise & Fitness
York t101 treadmill ls error
York treadmill T101 will not run has a error L5
May 11, 2009 | York Exercise & Fitness
York t500 treadmill model no:LQ6010 showing err07 when turned on
Error 7 is a Safety Key Error..
that's the red magnetic circular thingy on the console.
Simply secure the safety key in place and try it again
Jan 19, 2009 | York Barbell Home Use Fold-Up Treadmill
Exercise & Fitness Logo
61 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
