Question about Echo Rapid Loader, Trimmer Head
How to replace string on echo weed eater srm-225
2 Suggested Answers
#1 Taper
  • 1041 Answers
SOURCE: Don't know how to install new string on Echo SRM 2400
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position.
Jim
Posted on Jul 03, 2009
My echo srm 225 string trimmer line will not advance. Have rewound line and clear out grass from inside head.
Sometimes the spring may need extending as over time the bumping makes the spring lose its push tension causing no line advance
May 07, 2017 | Echo Garden
How to check fuel needle setting in Echo 2100 weed eater
Jack, Check the attached links for trimmer carb. tuning,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Tune Up an Echo Trimmer
http://www.echo-usa.com/getattachment/e8f287f6-0f5c-4f36-b0fa-ea8fa4a550b9/SRM2400241025012501S2510es_120194
echo srm 2100 weed eater
May 07, 2016 | Echo Garden
Echo srm225 grass trimmer will not start
Search Results
    Echo String Timmer/Weed Eater Model SRM-225 Won't ...
    ? 2:50
    www.youtube.com/watch?v=uFN82KDj3a8
    Nov 1, 2013 - Uploaded by mountainbikekayak So this is Part I of showing it want start but adding prime it wants to. Part II will show replacing the fuel filter did not fix it and then replacing the ...
Sep 16, 2015 | Echo Garden
How do I fix an echo srm 230 weed eater carburetor
Get the carb kit and replace all. Make sure that you tighten all the screws so there are no air leaks and cross your fingers.
Those cards are a royal pain in the ----
Aug 25, 2015 | Echo Garden
Why won't the string advance?
many times it is because the string has welded itself inside the head . and we have to use pliers to help it get loose again .
Jun 17, 2015 | Echo New String Trimmer SRM-225 2 Stroke...
How can I remove Echo 230 SRM trimmer head?
Don't know for sure, but I found manual on amazon, Amazon com echo srm manual so take a look if you want. have a nice day
Jul 21, 2009 | Echo Rapid Loader, Trimmer Head
Jim
Jun 29, 2009 | Echo Rapid Loader, Trimmer Head
Echo Rapid Loader, Trimmer Head Logo
62 people viewed this question
Top Echo Garden Experts
Jim Parker
Jim Parker
Jim London
Jim London
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
