Question about Toshiba 50A61 50" Rear Projection Television
Will not stay powered on.
Last December we had the television serviced. A high voltage component was replaced that had something to do with the color. This past April the TV would turn off at random intervals. We would have to unplug the set and wait a few minutes then we could turn it on again. After a few weeks of this it would turn off almost as quick as it would turn on. When it turns off the power light will blink. Unplugging does not resolve the problem. Is there an easy fix or should I get a new one?
Unplug the convergence yokes and see if set comes on DO NOT leave set on for longer than 2 minites with the plugs out presumming the set comes on, if it does replace 2 x STK 392-110 convergence ICs
Posted on Aug 31, 2007
SOURCE:
Why dose the power light come on and will go off in ten to twenty seconds ?
Fault with main board. Damaged component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ .
Sep 16, 2014 | Sanyo DP32649 31.5 in. TV
High voltage want stay on
can you tell us what was the problem earlier and what all did you replace to solve it??
Aug 10, 2008 | Hitachi 53FDX20B 53" Rear Projection...
When we try to turn on the tv (toshiba model 32A43) it makes the sound of turning on then off and the screen stays black and a red light by the power button keeps binking
You're either losing high voltage or power supply is not producing the horizontal drive signal, Check for 130v on the collector of the horizontal output transistor, if you're missing your voltage, you have a power supply problem. If voltage is too high you have something open in the power supply such as a low value resistor. If its low, something is shorted in power supply, possibly voltage regulator ic.
Jul 31, 2011 | Toshiba 32A43 32" TV
I pressed something on my remote by accident and ever since the tv has been giving me a No Video Signal message (for 4 days now). I can get Menu visuals just fine. My Input is correct on HDMI 1. I get...
Dear,
It is problem you television High Voltage unite,It may be damage,So you can go to repair it by authorized service center.Some of component or high voltage transformer fuse which make high voltage, there are some power transistor also it damage.
Nov 27, 2009 | Toshiba Regza 32LV67U 32 in. LCD HDTV
The screen stays black when the power is turned on. the stand by/timer ligt blinks
There is a high voltage, and or scan failure. This can be the flyback assembly, and or other support components. If the CRT is defective, it can cause this type of shut-down.
The cost for servicing this would be fairly expensive. It would be best to start shopping for a new set.
Jerry G.
Oct 17, 2008 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Sharp 19"color tv
change the electrolytic capacitor in the high voltage section.and check the continuity if there are open resistor.
Sep 06, 2008 | Sharp Televison & Video
Blue color issue
can you replace the cable see if problem stay's or go's
if it comes back check for loose connection around that board.
Feb 07, 2008 | Toshiba 65HDX82 65" Rear Projection...
SyncMaster 551V poor colors
Hi, Based on your post/description and assuming that the CRT monitor does not have any failed component(s), it would appear that you have a weak picture tube. If relatively new, claim warranty and have it replaced; if in service for some time, it may require adjustment in the Screen and Focus controls of the FBT; if really old, you may need to boost the color drive transistors B+. The second and last suggestion above would require that you be familiar and comfortable working with TV/Monitor units, high voltage and working with the unit powered on. If you are not comfortable performing a do-it-yourself, perhaps your best bet would be to seek the services of a qualified professional. Hope this be of some help/idea. pls post back how things turn up or should you need further information. Good luck and kind regards.
Sep 16, 2007 | Samsung SyncMaster 551 15" CRT Monitor
Tv problem
It sounds like you have High Voltage arc, coming from back of set. Was there ever Horzontal lines in picture when this happen. Or did your picture ever get dark and miss some color? If any of this happen then it could be coming from High Voltage Transformer, and anodes leads coming from trans.I would say clean spark gap anode leads and make sure all are seated properly(tighten). It would help if you could have the back open and notice when the set does this to see if you see sparks and were from. Hope this helps. Remember be carefull around any Voltage.
Sep 06, 2007 | Hitachi 43FDX15B 43" Rear Projection...
Color problem
my guess would be a cold solder joint on the av board. when picture looks good go to connectors and wiggle them if the set acts up you have your answer.
Jun 08, 2006 | Mitsubishi LT-3020 30 in. HD-Ready LCD...
Toshiba 50A61 50" Rear Projection Television Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
