Question about Acer Aspire 1642ZWLMi Notebook
Takeing key board out
Cant get the plastic bit of
  • 211 Answers
Just pull it from different angles.
PS. possible there are screws on hinge covers.
Posted on Mar 12, 2009
Is it OK to superglue the key guide to to circuit board?
if the pin is plastic the try deforming the end bit so that it has to be pushed hard into the holes (one end only)
Apr 20, 2015 | Music
Spacebar problems
You need to reattach the rubber nipple facing up. It's the part that makes contact with the board to signal to the computer the spacebar has been pressed. Most of them are free floating under the key or even gluing it on would be fine. The keys can be a bit tricky to pop off. Use a plastic pry bar, you an find these online for a couple dollars.
Jun 21, 2013 | HEWLETT-PACKARD Hewlett Packard HP Mini...
3300 240-Channels Base CB Radio: intermitant when key mike /works for a bit then st...
sounds like you have a bad soilder joint on the board. If it quits and you hit the case and it starts again is a sure way to find out.
May 07, 2010 | Connex 3300 240-Channels Base CB Radio
Cant type
Check for a stuck key. Usually something like the shift or enter key catches a bit more air and gets stuck. Just push each key down and you should find one that sort of clunks down. It should work after that.
Apr 29, 2010 | Toshiba Satellite A105 Notebook
Keys not working for my n81
you have to change you mother board only
Sep 19, 2009 | Nokia N81
Inserting keys on HP Pavilion
yes. you will need to take the two clips off the back of the key itself. they combine together and when you put the two plastic pieces together you can manuever it to sit correctly. you should have one plastic retainer on the bottom hooks, the middle inside should go on the top hooks or vice versa. but you must put the plastic retainers on first. then take your key and press it down onto it. you will hear it click. then you are good. be mindful its not extremely easy, it takes a bit of practice and be careful with the plastic retainers they do break. so take your time and seat it correctly. but you can do it!
Good Luck!
Ruben
Jul 25, 2009 | Computers & Internet
How to replace a key on laptop keyboard
a pair of tweezers a small flat head screw driver and persistence along with being careful and if you get irritated or annoyed stop and have a break and come back to it.
Take one of the keys off near it to see which way around the plastic parts go ( not too hard as you dont want the other plastic clips snapping or breaking off ) and see if any little bits of plastic are snapped - if they are you will need replacements so contact asus - if not and they are still in tact then put the 2 plastic hinges together the correct way around and then put them back in place ( you may have to slightly bend the metal clips on the bottom of the keyboard where the plastic bits fit ) which is where the small flat head screw driver comes in handy.
When you are putting the plastic parts together you may need the tweezers or possibly a paif of needle nose pliers ( being very careful as you dont want to snap the plastic clips / hinges )
Once you get the plastic hinges back in / on you can bend the metal parts back slowly and gently so as to hold the plastic bits and then push the key back on.
You should then be able to push the other key back on and that should be it.
If you need any replacement parts then you will have to contact asus.
Apr 10, 2009 | ASUS M51SN-B1 15.4" Core 2 Duo 1.83GHz 3GB...
Key Broke for Ignition Need to Bypass until I can Get parts Any Ideas?
ok im not a thief but i hve done this as a joke stole mummys car on the ignition barrel at the back when the key is turned the barrel turns a lug that turns in a plastic bit u unscrew that and u can stick a screw driver in it and turn it manually no need to cut any wires here is a photo of the plastic bit http://wiki.r31skylineclub.com/images/9/97/Ibfcompare.jpg amnd here is a photo with the plastic bit off with the lug http://www.noelsautoparts.com.au/pics/Nice%20Products/nib40_small.gif if u have any more trobles just write back and ill help but do that it will work
Jun 19, 2008 | 1997 Nissan Pickup
My peugeot 206 center consul radio display is so dull i cant read it..its very faint but at a certain angle i can see it so it still working ...help please
Bit late but...
Its a poor connection between the pins that suplly power to the bulbs and the circut board.
Take the whole section apart, take the circuit board off the white plastic holder and solder 'blobs on the connections on the board, above and below the locating holes.
stick it back together and should stay lit now!
Mar 20, 2008 | Car Audio & Video
Key stick
okay first thing you want to do is unplug machine, get some rubbing alcohol and an old tooth brush. then dip the brush into alcohol do not make it too wet and brush the edges of the keys as well as you can. If that doesn't work then you need to take the control panel appart and remove the board from the plastic panel and wipe with alcohol and rag/brush. BE SURE TO THOROUGHLY DRY BEFORE PLUGGING IN POWER CORD.
Mar 15, 2008 | Office Equipment & Supplies
Acer Aspire 1642ZWLMi Notebook Logo
18 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
